Date/Time: Mon, 29 Apr 2024 10:40:33 +0000
Trading Option Using Chart trading Window or Dom
View Count: 890
[2014-07-03 03:57:56] |
User22591 - Posts: 133 |
Can you provide me some information or direction on how to use the Chart trading Window or DOM for trading options. Where to You place the Option symbol?
[2014-07-04 01:48:47] |
You just need to open a chart or Trade DOM for the option symbol itself . Just like any other symbol. Here are the instructions to change the symbol of the chart: http://www.sierrachart.com/index.php?page=doc/doc_SwitchingSymbols.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
