Date/Time: Mon, 29 Apr 2024 05:46:17 +0000
Вопрос оплаты платформы
View Count: 897
[2014-07-02 19:32:38] |
User60651 - Posts: 6 |
Здравствуйте, недавно установил платформу, использую соединение Т4 на реальном сервере. Как узнать когда нужно оплачивать платформу? Сейчас платформа работает в полном режиме, с профилем рынка и т.д.
[2014-07-02 19:43:09] |
ganz - Posts: 1048 |
User60651 Help -> About |
[2014-07-03 00:13:51] |
You can check your Sierra Chart usage time ending date by selecting Help >>Account Control Panel. On the displayed webpage in your web browser, you will see the ending date. You will need to pay for additional usage time before it expires. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-03 00:14:00
