Date/Time: Mon, 29 Apr 2024 10:01:26 +0000
Parabolic SAR Indicator
View Count: 1990
[2014-07-02 18:48:46] |
drywater0 - Posts: 85 |
SC Support, I am familiar with this indicator from other charting packages. SC has additional input parameters called "Input Data High" and "Input Data Low". I could not find any documentation on the site or on the internet as to how these might be used. Could you please guidance with an example? SC is also unique in providing an additional input parameter of "Start Acceleration Factor". I assume this simply allows the first period Acceleration Factor to be different than the Acceleration Increment that is added each time a new Extreme Point (higher high in uptrend / lower low in downtrend) is made. Please confirm. Many thanks in advance. |
[2014-07-03 09:36:54] |
We will be working on the Parabolic study documentation today.
[2014-07-04 06:27:11] |
The documentation for the Parabolic study has now been updated. Refer to: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s66 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-04 06:27:17
