Date/Time: Sat, 04 May 2024 16:05:55 +0000
autotrading multiple strategies
View Count: 1066
[2014-07-02 16:05:12] |
User021827 - Posts: 174 |
Do you have to open a different instance of Sierra Chart in order to run a strategy on multiple instruments ? Like wise; do you have to run multiple instances of Sierra in order to run several different strategies on one instrument ? thank you shane |
[2014-07-03 04:09:55] |
This is documented here: http://www.sierrachart.com/index.php?l=doc/doc_AutoTradeManagment.php#MultipleAutomatedTradingSystems You do not need a separate instance of Sierra Chart unless you want to. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
