Date/Time: Mon, 06 May 2024 16:08:50 +0000
error..
View Count: 1403
[2014-07-02 12:37:06] |
mayerrs - Posts: 70 |
there must be something wrong with new relace and prerelace. i have some problem with study, alerts, and data. and, i havve no backups files so i am not able to open ma chartbooks in older version. when do you think you are going to put newer version on the website? thank you |
[2014-07-02 15:32:32] |
What is the specific problem you are encountering? This is not clear for us. What happens when you try to open a Chartbook in an older version. You should have no trouble with this. Backup files are maintained by Sierra Chart. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_Chartbooks.html#BackupChartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-02 19:47:57
[2014-07-02 19:28:23] |
sierra is not able to open any of my studies. i use CCI and other but it is not able open anything. here is a log: Software version: 1154 | 2014-07-02 15:22:24 Enabled for: Advanced Features. | 2014-07-02 15:22:24 Enabled for: Sierra Chart Historical Data Service. | 2014-07-02 15:22:24 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-07-02 15:22:24 Active service: TransAct Trading | 2014-07-02 15:22:24 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-07-02 15:22:24 2014-07-02 15:22:24 Local computer clock time | 2014-07-02 15:22:24 2014-07-02 19:22:24 GMT time | 2014-07-02 15:22:24 2014-07-02 15:22:24 Time zone adjusted time | 2014-07-02 15:22:24 Time difference to server time: 0 seconds. | 2014-07-02 15:22:24 Program path: C:\SierraChart\SierraChartTransActMA\ | 2014-07-02 15:22:24 Data Files path: C:\SierraChart\SierraChartTransActMA\Data\ | 2014-07-02 15:22:24 OS Version Number: 5.1 | 2014-07-02 15:22:24 Checking for new symbol settings for ta | 2014-07-02 15:22:24 Requesting symbol settings for ta. Overwrite = off. | 2014-07-02 15:22:24 Symbol settings received. | 2014-07-02 15:22:27 Processed received symbol settings | 2014-07-02 15:22:27 Unable to read newer Chartbook file format. Update ATCharts by selecting 'Help >> Download Current Version'. | 2014-07-02 15:22:27 Unable to read newer Chartbook file format. Update ATCharts by selecting 'Help >> Download Current Version'. | 2014-07-02 15:22:27 Unable to read newer Chartbook file format. Update ATCharts by selecting 'Help >> Download Current Version'. | 2014-07-02 15:22:27 Unable to read newer Chartbook file format. Update ATCharts by selecting 'Help >> Download Current Version'. | 2014-07-02 15:22:27 Unable to read newer Chartbook file format. Update ATCharts by selecting 'Help >> Download Current Version'. | 2014-07-02 15:22:27 Unable to read newer Chartbook file format. Update ATCharts by selecting 'Help >> Download Current Version'. | 2014-07-02 15:22:27 Unable to read newer Chartbook file format. Update ATCharts by selecting 'Help >> Download Current Version'. | 2014-07-02 15:22:27 Unable to read newer Chartbook file format. Update ATCharts by selecting 'Help >> Download Current Version'. | 2014-07-02 15:22:27 Unable to read newer Chartbook file format. Update ATCharts by selecting 'Help >> Download Current Version'. | 2014-07-02 15:22:27 Unable to read newer Chartbook file format. Update ATCharts by selecting 'Help >> Download Current Version'. | 2014-07-02 15:22:27 Unable to read newer Chartbook file format. Update ATCharts by selecting 'Help >> Download Current Version'. | 2014-07-02 15:22:27 Unable to read newer Chartbook file format. Update ATCharts by selecting 'Help >> Download Current Version'. | 2014-07-02 15:22:27 Unable to read newer Chartbook file format. Update ATCharts by selecting 'Help >> Download Current Version'. | 2014-07-02 15:22:27 Unable to read newer Chartbook file format. Update ATCharts by selecting 'Help >> Download Current Version'. | 2014-07-02 15:22:27 Unable to read newer Chartbook file format. Update ATCharts by selecting 'Help >> Download Current Version'. | 2014-07-02 15:22:27 Unable to read newer Chartbook file format. Update ATCharts by selecting 'Help >> Download Current Version'. | 2014-07-02 15:22:27 Unable to read newer Chartbook file format. Update ATCharts by selecting 'Help >> Download Current Version'. | 2014-07-02 15:22:27 Unable to read newer Chartbook file format. Update ATCharts by selecting 'Help >> Download Current Version'. | 2014-07-02 15:22:27 TransAct Trading - Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2014-07-02 15:22:29 TransAct Trading: Connecting to the server 127.0.0.1. Port 1869 | 2014-07-02 15:22:31 Socket (1576) - Connected. | 2014-07-02 15:22:31 TransAct Trading: Connected to server. | 2014-07-02 15:22:31 TransAct Trading: Sending logon request message. | 2014-07-02 15:22:31 TransAct Trading Server Info - Server Name: TransactToSierraBridge. Server Version: 1.2.3.0. Provider Name: Transact Futures. | 2014-07-02 15:22:42 TransAct Trading - Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-07-02 15:22:42 TransAct Trading - Successfully connected. Operation Successful. | 2014-07-02 15:22:42 TransAct Trading: Requesting Trade Positions data. | 2014-07-02 15:22:47 Requesting data files from remote instance: RJ#.dly | 2014-07-02 15:24:40 Remote instance requested data files: RJ#.dly | 2014-07-02 15:24:40 Requesting data files from remote instance: CLQ4.scid, ESU4.scid, FDAXU4.scid, GCQ4.scid, HGU4.scid, HOQ4.scid, NGQ4.scid, NQU4.scid, PLV4.scid, RBQ4.scid, SIU4.scid, TFU4.scid, YMU4.scid, ZCU4.scid, ZSX4.scid, ZWU4.scid | 2014-07-02 15:24:54 Remote instance requested data files: CLQ4.scid, ESU4.scid, FDAXU4.scid, GCQ4.scid, HGU4.scid, HOQ4.scid, NGQ4.scid, NQU4.scid, PLV4.scid, RBQ4.scid, SIU4.scid, TFU4.scid, YMU4.scid, ZCU4.scid, ZSX4.scid, ZWU4.scid | 2014-07-02 15:24:56 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:24:57 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:24:57 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:24:57 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 HD Request # 2 - Downloading Historical Daily chart data for RJ#. Starting date: 2014-07-01. Service: ta | 2014-07-02 15:24:58 HD Request # 2 - Requesting historical Daily Continuous data for RJZ10 starting at 2014-06-30 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:59 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:59 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:59 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:59 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:59 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:59 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:59 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:59 HD Request # 3 - Downloading Intraday chart data for CLQ4 to the file CLQ4.scid. Service: ta | 2014-07-02 15:24:59 HD Request # 3 - Download start Date-Time: 2014-07-02 11:13:55.0 | 2014-07-02 15:24:59 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:59 HD Request # 3 - Using server: ds4.sierracharts.com port 10149 | 2014-07-02 15:24:59 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:59 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:59 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:59 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:59 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:59 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:59 Socket (0) - Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-07-02 15:24:59 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:59 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:59 TransAct Trading - Starting real-time market data updates for: RBQ4. ID: 2 | 2014-07-02 15:24:59 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:24:59 TransAct Trading - Starting real-time market data updates for: HOQ4. ID: 3 | 2014-07-02 15:24:59 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:24:59 TransAct Trading - Starting real-time market data updates for: CLQ4. ID: 1 | 2014-07-02 15:24:59 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:24:59 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:24:59 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:24:59 Socket (2152) - Connected. | 2014-07-02 15:24:59 HD Request # 3 - Sending historical data logon request message. | 2014-07-02 15:24:59 HD Request # 2 - Receiving historical Daily data for RJ# starting at 2014-06-30 | 2014-07-02 15:24:59 Writing historical Daily data for RJ# to the file RJ#.dly | 2014-07-02 15:24:59 HD Request # 2 - Received 3 records from 2014-06-30 00:00:00 to 2014-07-02 00:00:00 (3.0 days) and wrote 2 records for RJ# | 2014-07-02 15:24:59 HD Request # 2 - Daily download COMPLETE for RJ#. Completion time: 1s | 2014-07-02 15:24:59 HD Request # 4 - Downloading Historical Daily chart data for CL#. Starting date: 2014-07-01. Service: ta | 2014-07-02 15:24:59 HD Request # 4 - Requesting historical Daily Continuous data for CLZ10 starting at 2014-06-30 | 2014-07-02 15:24:59 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:24:59 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:24:59 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:24:59 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:24:59 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:24:59 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:24:59 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:24:59 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:24:59 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:00 HD Request # 4 - Receiving historical Daily data for CL# starting at 2014-06-30 | 2014-07-02 15:25:00 Writing historical Daily data for CL# to the file CL#.dly | 2014-07-02 15:25:00 HD Request # 4 - Received 3 records from 2014-06-30 00:00:00 to 2014-07-02 00:00:00 (3.0 days) and wrote 2 records for CL# | 2014-07-02 15:25:00 HD Request # 4 - Daily download COMPLETE for CL#. Completion time: 1s | 2014-07-02 15:25:00 TransAct Trading - Starting real-time market data updates for: TFU4. ID: 4 | 2014-07-02 15:25:00 HD Request # 5 - Downloading Historical Daily chart data for RJ#. Starting date: 2014-07-01. Service: ta | 2014-07-02 15:25:00 HD Request # 5 - Requesting historical Daily Continuous data for RJZ10 starting at 2014-06-30 | 2014-07-02 15:25:00 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:00 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:00 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:00 HD Request # 3 - Requesting Intraday data. Start Date-Time: 2014-07-02 11:13:55. Record interval: 0. Symbol: CLQ4 | 2014-07-02 15:25:00 TransAct Trading - Starting real-time market data updates for: FDAXU4. ID: 5 | 2014-07-02 15:25:00 TransAct Trading - Starting real-time market data updates for: ZWU4. ID: 6 | 2014-07-02 15:25:00 TransAct Trading - Starting real-time market data updates for: ZSX4. ID: 7 | 2014-07-02 15:25:00 TransAct Trading - Starting real-time market data updates for: ZCU4. ID: 8 | 2014-07-02 15:25:00 TransAct Trading - Starting real-time market data updates for: YMU4. ID: 9 | 2014-07-02 15:25:00 TransAct Trading - Starting real-time market data updates for: NQU4. ID: 10 | 2014-07-02 15:25:00 HD Request # 3 - Decompressing data. | 2014-07-02 15:25:00 HD Request # 3 - Receiving Intraday data for CLQ4 starting at 2014-07-02 11:13:55 | 2014-07-02 15:25:00 HD Request # 3 - Timestamp of first Intraday data file record written: 2014-07-02 11:13:58 | 2014-07-02 15:25:00 TransAct Trading - Starting real-time market data updates for: ESU4. ID: 11 | 2014-07-02 15:25:00 HD Request # 5 - Receiving historical Daily data for RJ# starting at 2014-06-30 | 2014-07-02 15:25:00 Writing historical Daily data for RJ# to the file RJ#.dly | 2014-07-02 15:25:00 HD Request # 5 - Received 3 records from 2014-06-30 00:00:00 to 2014-07-02 00:00:00 (3.0 days) and wrote 2 records for RJ# | 2014-07-02 15:25:00 HD Request # 5 - Daily download COMPLETE for RJ#. Completion time: 0s | 2014-07-02 15:25:00 TransAct Trading - Starting real-time market data updates for: HGU4. ID: 12 | 2014-07-02 15:25:00 TransAct Trading - Starting real-time market data updates for: PLV4. ID: 13 | 2014-07-02 15:25:00 TransAct Trading - Starting real-time market data updates for: SIU4. ID: 14 | 2014-07-02 15:25:00 TransAct Trading - Starting real-time market data updates for: GCQ4. ID: 15 | 2014-07-02 15:25:00 TransAct Trading - Starting real-time market data updates for: NGQ4. ID: 16 | 2014-07-02 15:25:00 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:00 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:00 HD Request # 6 - Downloading Historical Daily chart data for ZW#. Starting date: 2014-07-01. Service: ta | 2014-07-02 15:25:00 HD Request # 6 - Requesting historical Daily Continuous data for ZWZ10 starting at 2014-06-30 | 2014-07-02 15:25:00 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:00 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:00 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:00 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:00 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:00 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:00 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:00 SC Market Stats - Starting real-time market data updates for: TICK-NYSE. ID: 17 | 2014-07-02 15:25:01 SC Market Stats: Connecting to the server ds5.sierracharts.com. Port 443 | 2014-07-02 15:25:01 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:01 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:01 HD Request # 6 - Receiving historical Daily data for ZW# starting at 2014-06-30 | 2014-07-02 15:25:01 Writing historical Daily data for ZW# to the file ZW#.dly | 2014-07-02 15:25:01 HD Request # 6 - Received 3 records from 2014-06-30 00:00:00 to 2014-07-02 00:00:00 (3.0 days) and wrote 2 records for ZW# | 2014-07-02 15:25:01 HD Request # 6 - Daily download COMPLETE for ZW#. Completion time: 0s | 2014-07-02 15:25:01 Socket (0) - Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-07-02 15:25:01 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:25:01 HD Request # 7 - Downloading Historical Daily chart data for ZS#. Starting date: 2014-07-01. Service: ta | 2014-07-02 15:25:01 HD Request # 7 - Requesting historical Daily Continuous data for ZSZ10 starting at 2014-06-30 | 2014-07-02 15:25:01 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:01 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:01 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:01 Socket (2152) - Shutdown and closed. | 2014-07-02 15:25:01 The network socket for historical data has been closed. | 2014-07-02 15:25:01 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:01 HD Request # 3 - Received 57556 records from 2014-07-02 11:13:55 to 2014-07-02 15:24:56 (4.2 hours) and wrote 57552 records for CLQ4 | 2014-07-02 15:25:01 HD Request # 3 - Intraday download COMPLETE for CLQ4. Completion time: 2s | 2014-07-02 15:25:01 Real-time Intraday chart data file updates started for CLQ4 | 2014-07-02 15:25:01 HD Request # 8 - Downloading Intraday chart data for ESU4 to the file ESU4.scid. Service: ta | 2014-07-02 15:25:01 HD Request # 8 - Download start Date-Time: 2014-07-02 11:13:58.0 | 2014-07-02 15:25:01 HD Request # 8 - Using server: ds3.sierracharts.com port 10149 | 2014-07-02 15:25:01 Socket (0) - Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-07-02 15:25:01 Requesting data files from remote instance: RJ#.dly | 2014-07-02 15:25:01 Remote instance requested data files: RJ#.dly | 2014-07-02 15:25:01 Socket (2760) - Connected. | 2014-07-02 15:25:01 SC Market Stats: Connected to server. | 2014-07-02 15:25:01 SC Market Stats: Sending logon request message. | 2014-07-02 15:25:01 HD Request # 7 - Receiving historical Daily data for ZS# starting at 2014-06-30 | 2014-07-02 15:25:01 Writing historical Daily data for ZS# to the file ZS#.dly | 2014-07-02 15:25:01 HD Request # 7 - Received 3 records from 2014-06-30 00:00:00 to 2014-07-02 00:00:00 (3.0 days) and wrote 2 records for ZS# | 2014-07-02 15:25:01 HD Request # 7 - Daily download COMPLETE for ZS#. Completion time: 0s | 2014-07-02 15:25:01 Socket (2152) - Connected. | 2014-07-02 15:25:01 HD Request # 8 - Sending historical data logon request message. | 2014-07-02 15:25:01 HD Request # 9 - Downloading Historical Daily chart data for ZC#. Starting date: 2014-07-01. Service: ta | 2014-07-02 15:25:02 HD Request # 9 - Requesting historical Daily Continuous data for ZCZ10 starting at 2014-06-30 | 2014-07-02 15:25:02 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:25:02 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:02 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:02 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:02 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:02 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:02 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:02 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:02 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:02 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:02 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:02 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:02 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:02 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:02 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:02 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:02 HD Request # 9 - Receiving historical Daily data for ZC# starting at 2014-06-30 | 2014-07-02 15:25:02 Writing historical Daily data for ZC# to the file ZC#.dly | 2014-07-02 15:25:02 HD Request # 9 - Received 3 records from 2014-06-30 00:00:00 to 2014-07-02 00:00:00 (3.0 days) and wrote 2 records for ZC# | 2014-07-02 15:25:02 HD Request # 9 - Daily download COMPLETE for ZC#. Completion time: 0s | 2014-07-02 15:25:02 SC Market Stats Server Info - Server Name: . Server Version: . Provider Name: . | 2014-07-02 15:25:02 SC Market Stats - Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-07-02 15:25:02 SC Market Stats - Successfully connected. | 2014-07-02 15:25:02 SC Market Stats - Restarting real-time data updates for symbol: TICK-NYSE | 2014-07-02 15:25:02 HD Request # 10 - Downloading Historical Daily chart data for YM#. Starting date: 2014-07-01. Service: ta | 2014-07-02 15:25:02 HD Request # 10 - Requesting historical Daily Continuous data for YMZ10 starting at 2014-06-30 | 2014-07-02 15:25:02 HD Request # 8 - Requesting Intraday data. Start Date-Time: 2014-07-02 11:13:58. Record interval: 0. Symbol: ESU4 | 2014-07-02 15:25:02 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:02 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:02 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:02 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:02 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:02 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:02 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:02 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:02 HD Request # 8 - Decompressing data. | 2014-07-02 15:25:02 HD Request # 8 - Receiving Intraday data for ESU4 starting at 2014-07-02 11:13:58 | 2014-07-02 15:25:02 HD Request # 8 - Timestamp of first Intraday data file record written: 2014-07-02 11:13:58 | 2014-07-02 15:25:02 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:03 HD Request # 10 - Receiving historical Daily data for YM# starting at 2014-06-30 | 2014-07-02 15:25:03 Writing historical Daily data for YM# to the file YM#.dly | 2014-07-02 15:25:03 HD Request # 10 - Received 3 records from 2014-06-30 00:00:00 to 2014-07-02 00:00:00 (3.0 days) and wrote 2 records for YM# | 2014-07-02 15:25:03 HD Request # 10 - Daily download COMPLETE for YM#. Completion time: 0s | 2014-07-02 15:25:03 HD Request # 11 - Downloading Historical Daily chart data for RJ#. Starting date: 2014-07-01. Service: ta | 2014-07-02 15:25:03 HD Request # 11 - Requesting historical Daily Continuous data for RJZ10 starting at 2014-06-30 | 2014-07-02 15:25:03 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:03 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:03 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:03 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:03 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:03 HD Request # 11 - Receiving historical Daily data for RJ# starting at 2014-06-30 | 2014-07-02 15:25:03 Writing historical Daily data for RJ# to the file RJ#.dly | 2014-07-02 15:25:03 HD Request # 11 - Received 3 records from 2014-06-30 00:00:00 to 2014-07-02 00:00:00 (3.0 days) and wrote 2 records for RJ# | 2014-07-02 15:25:03 HD Request # 11 - Daily download COMPLETE for RJ#. Completion time: 0s | 2014-07-02 15:25:03 HD Request # 12 - Downloading Historical Daily chart data for SI#. Starting date: 2014-07-01. Service: ta | 2014-07-02 15:25:03 HD Request # 12 - Requesting historical Daily Continuous data for SIZ10 starting at 2014-06-30 | 2014-07-02 15:25:03 Requesting market depth updates for: CLQ4 if supported. | 2014-07-02 15:25:03 Requesting market depth updates for: ESU4 if supported. | 2014-07-02 15:25:03 Requesting market depth updates for: FDAXU4 if supported. | 2014-07-02 15:25:03 Requesting market depth updates for: GCQ4 if supported. | 2014-07-02 15:25:03 Requesting market depth updates for: HGU4 if supported. | 2014-07-02 15:25:03 Requesting market depth updates for: HOQ4 if supported. | 2014-07-02 15:25:03 Requesting market depth updates for: NGQ4 if supported. | 2014-07-02 15:25:03 Requesting market depth updates for: NQU4 if supported. | 2014-07-02 15:25:03 Requesting market depth updates for: PLV4 if supported. | 2014-07-02 15:25:03 Requesting market depth updates for: RBQ4 if supported. | 2014-07-02 15:25:03 Requesting market depth updates for: SIU4 if supported. | 2014-07-02 15:25:03 Requesting market depth updates for: TFU4 if supported. | 2014-07-02 15:25:03 Requesting market depth updates for: YMU4 if supported. | 2014-07-02 15:25:03 Requesting market depth updates for: ZCU4 if supported. | 2014-07-02 15:25:03 Requesting market depth updates for: ZSX4 if supported. | 2014-07-02 15:25:03 Requesting market depth updates for: ZWU4 if supported. | 2014-07-02 15:25:03 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:03 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:03 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:03 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:03 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:03 HD Request # 12 - Receiving historical Daily data for SI# starting at 2014-06-30 | 2014-07-02 15:25:03 Writing historical Daily data for SI# to the file SI#.dly | 2014-07-02 15:25:03 HD Request # 12 - Received 3 records from 2014-06-30 00:00:00 to 2014-07-02 00:00:00 (3.0 days) and wrote 2 records for SI# | 2014-07-02 15:25:03 HD Request # 12 - Daily download COMPLETE for SI#. Completion time: 0s | 2014-07-02 15:25:03 HD Request # 13 - Downloading Historical Daily chart data for RB#. Starting date: 2014-07-01. Service: ta | 2014-07-02 15:25:03 HD Request # 13 - Requesting historical Daily Continuous data for RBZ10 starting at 2014-06-30 | 2014-07-02 15:25:03 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:03 HD Request # 13 - Receiving historical Daily data for RB# starting at 2014-06-30 | 2014-07-02 15:25:03 Writing historical Daily data for RB# to the file RB#.dly | 2014-07-02 15:25:03 HD Request # 13 - Received 3 records from 2014-06-30 00:00:00 to 2014-07-02 00:00:00 (3.0 days) and wrote 2 records for RB# | 2014-07-02 15:25:03 HD Request # 13 - Daily download COMPLETE for RB#. Completion time: 0s | 2014-07-02 15:25:03 HD Request # 14 - Downloading Historical Daily chart data for PL#. Starting date: 2014-07-01. Service: ta | 2014-07-02 15:25:04 HD Request # 14 - Requesting historical Daily Continuous data for PLZ10 starting at 2014-06-30 | 2014-07-02 15:25:04 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:04 Socket (2152) - Shutdown and closed. | 2014-07-02 15:25:04 The network socket for historical data has been closed. | 2014-07-02 15:25:04 HD Request # 8 - Received 71923 records from 2014-07-02 11:13:58 to 2014-07-02 15:25:02 (4.2 hours) and wrote 71921 records for ESU4 | 2014-07-02 15:25:04 HD Request # 8 - Intraday download COMPLETE for ESU4. Completion time: 3s | 2014-07-02 15:25:04 Real-time Intraday chart data file updates started for ESU4 | 2014-07-02 15:25:04 HD Request # 14 - Receiving historical Daily data for PL# starting at 2014-06-30 | 2014-07-02 15:25:04 Writing historical Daily data for PL# to the file PL#.dly | 2014-07-02 15:25:04 HD Request # 14 - Received 3 records from 2014-06-30 00:00:00 to 2014-07-02 00:00:00 (3.0 days) and wrote 2 records for PL# | 2014-07-02 15:25:04 HD Request # 14 - Daily download COMPLETE for PL#. Completion time: 0s | 2014-07-02 15:25:04 HD Request # 15 - Downloading Intraday chart data for FDAXU4 to the file FDAXU4.scid. Service: ta | 2014-07-02 15:25:04 HD Request # 15 - Download start Date-Time: 2014-07-02 11:13:58.0 | 2014-07-02 15:25:04 HD Request # 15 - Using server: ds4.sierracharts.com port 10149 | 2014-07-02 15:25:04 Socket (0) - Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-07-02 15:25:04 HD Request # 16 - Downloading Historical Daily chart data for NQ#. Starting date: 2014-07-01. Service: ta | 2014-07-02 15:25:04 HD Request # 16 - Requesting historical Daily Continuous data for NQZ10 starting at 2014-06-30 | 2014-07-02 15:25:04 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:04 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:04 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:04 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:04 Socket (2520) - Connected. | 2014-07-02 15:25:04 HD Request # 15 - Sending historical data logon request message. | 2014-07-02 15:25:04 HD Request # 15 - Requesting Intraday data. Start Date-Time: 2014-07-02 11:13:58. Record interval: 0. Symbol: FDAXU4 | 2014-07-02 15:25:04 HD Request # 15 - Decompressing data. | 2014-07-02 15:25:04 HD Request # 15 - Receiving Intraday data for FDAXU4 starting at 2014-07-02 11:13:58 | 2014-07-02 15:25:04 HD Request # 15 - Timestamp of first Intraday data file record written: 2014-07-02 11:13:58 | 2014-07-02 15:25:04 HD Request # 16 - Receiving historical Daily data for NQ# starting at 2014-06-30 | 2014-07-02 15:25:04 Writing historical Daily data for NQ# to the file NQ#.dly | 2014-07-02 15:25:04 HD Request # 16 - Received 3 records from 2014-06-30 00:00:00 to 2014-07-02 00:00:00 (3.0 days) and wrote 2 records for NQ# | 2014-07-02 15:25:04 HD Request # 16 - Daily download COMPLETE for NQ#. Completion time: 0s | 2014-07-02 15:25:04 HD Request # 17 - Downloading Historical Daily chart data for NG#. Starting date: 2014-07-01. Service: ta | 2014-07-02 15:25:04 HD Request # 17 - Requesting historical Daily Continuous data for NGZ10 starting at 2014-06-30 | 2014-07-02 15:25:04 Socket (2520) - Shutdown and closed. | 2014-07-02 15:25:05 The network socket for historical data has been closed. | 2014-07-02 15:25:05 HD Request # 15 - Received 4361 records from 2014-07-02 11:13:58 to 2014-07-02 15:25:01 (4.2 hours) and wrote 4359 records for FDAXU4 | 2014-07-02 15:25:05 HD Request # 15 - Intraday download COMPLETE for FDAXU4. Completion time: 1s | 2014-07-02 15:25:05 Real-time Intraday chart data file updates started for FDAXU4 | 2014-07-02 15:25:05 HD Request # 17 - Receiving historical Daily data for NG# starting at 2014-06-30 | 2014-07-02 15:25:05 Writing historical Daily data for NG# to the file NG#.dly | 2014-07-02 15:25:05 HD Request # 17 - Received 3 records from 2014-06-30 00:00:00 to 2014-07-02 00:00:00 (3.0 days) and wrote 2 records for NG# | 2014-07-02 15:25:05 HD Request # 17 - Daily download COMPLETE for NG#. Completion time: 1s | 2014-07-02 15:25:05 HD Request # 18 - Downloading Intraday chart data for GCQ4 to the file GCQ4.scid. Service: ta | 2014-07-02 15:25:05 HD Request # 18 - Download start Date-Time: 2014-07-02 11:13:59.0 | 2014-07-02 15:25:05 HD Request # 18 - Using server: ds5.sierracharts.com port 10149 | 2014-07-02 15:25:05 HD Request # 19 - Downloading Historical Daily chart data for HO#. Starting date: 2014-07-01. Service: ta | 2014-07-02 15:25:05 HD Request # 19 - Requesting historical Daily Continuous data for HOZ10 starting at 2014-06-30 | 2014-07-02 15:25:05 Socket (0) - Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-07-02 15:25:05 Socket (2272) - Connected. | 2014-07-02 15:25:05 HD Request # 18 - Sending historical data logon request message. | 2014-07-02 15:25:05 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:05 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:05 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:05 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:05 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:05 HD Request # 19 - Receiving historical Daily data for HO# starting at 2014-06-30 | 2014-07-02 15:25:05 Writing historical Daily data for HO# to the file HO#.dly | 2014-07-02 15:25:05 HD Request # 19 - Received 3 records from 2014-06-30 00:00:00 to 2014-07-02 00:00:00 (3.0 days) and wrote 2 records for HO# | 2014-07-02 15:25:05 HD Request # 19 - Daily download COMPLETE for HO#. Completion time: 0s | 2014-07-02 15:25:05 HD Request # 20 - Downloading Historical Daily chart data for HG#. Starting date: 2014-07-01. Service: ta | 2014-07-02 15:25:05 HD Request # 20 - Requesting historical Daily Continuous data for HGZ10 starting at 2014-06-30 | 2014-07-02 15:25:05 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:05 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:05 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:05 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:05 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:05 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:05 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:05 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:05 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:05 HD Request # 18 - Requesting Intraday data. Start Date-Time: 2014-07-02 11:13:59. Record interval: 0. Symbol: GCQ4 | 2014-07-02 15:25:06 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:06 HD Request # 20 - Receiving historical Daily data for HG# starting at 2014-06-30 | 2014-07-02 15:25:06 Writing historical Daily data for HG# to the file HG#.dly | 2014-07-02 15:25:06 HD Request # 20 - Received 3 records from 2014-06-30 00:00:00 to 2014-07-02 00:00:00 (3.0 days) and wrote 2 records for HG# | 2014-07-02 15:25:06 HD Request # 20 - Daily download COMPLETE for HG#. Completion time: 0s | 2014-07-02 15:25:06 HD Request # 18 - Decompressing data. | 2014-07-02 15:25:06 HD Request # 18 - Receiving Intraday data for GCQ4 starting at 2014-07-02 11:13:59 | 2014-07-02 15:25:06 HD Request # 18 - Timestamp of first Intraday data file record written: 2014-07-02 11:13:59 | 2014-07-02 15:25:06 HD Request # 21 - Downloading Historical Daily chart data for GC#. Starting date: 2014-07-01. Service: ta | 2014-07-02 15:25:06 HD Request # 21 - Requesting historical Daily Continuous data for GCZ10 starting at 2014-06-30 | 2014-07-02 15:25:06 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:06 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:06 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:06 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:06 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:06 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:06 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:06 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:06 HD Request # 21 - Receiving historical Daily data for GC# starting at 2014-06-30 | 2014-07-02 15:25:06 Writing historical Daily data for GC# to the file GC#.dly | 2014-07-02 15:25:06 HD Request # 21 - Received 3 records from 2014-06-30 00:00:00 to 2014-07-02 00:00:00 (3.0 days) and wrote 2 records for GC# | 2014-07-02 15:25:06 HD Request # 21 - Daily download COMPLETE for GC#. Completion time: 0s | 2014-07-02 15:25:06 HD Request # 22 - Downloading Historical Daily chart data for DY#. Starting date: 2014-07-01. Service: ta | 2014-07-02 15:25:06 HD Request # 22 - Requesting historical Daily Continuous data for DYZ10 starting at 2014-06-30 | 2014-07-02 15:25:06 Socket (2272) - Shutdown and closed. | 2014-07-02 15:25:06 The network socket for historical data has been closed. | 2014-07-02 15:25:06 HD Request # 18 - Received 11874 records from 2014-07-02 11:13:59 to 2014-07-02 15:25:04 (4.2 hours) and wrote 11861 records for GCQ4 | 2014-07-02 15:25:07 HD Request # 18 - Intraday download COMPLETE for GCQ4. Completion time: 2s | 2014-07-02 15:25:07 Real-time Intraday chart data file updates started for GCQ4 | 2014-07-02 15:25:07 HD Request # 22 - Receiving historical Daily data for DY# starting at 2014-06-30 | 2014-07-02 15:25:07 Writing historical Daily data for DY# to the file DY#.dly | 2014-07-02 15:25:07 HD Request # 22 - Received 3 records from 2014-06-30 00:00:00 to 2014-07-02 00:00:00 (3.0 days) and wrote 2 records for DY# | 2014-07-02 15:25:07 HD Request # 22 - Daily download COMPLETE for DY#. Completion time: 1s | 2014-07-02 15:25:07 HD Request # 23 - Downloading Intraday chart data for HGU4 to the file HGU4.scid. Service: ta | 2014-07-02 15:25:07 HD Request # 23 - Download start Date-Time: 2014-07-02 11:13:54.0 | 2014-07-02 15:25:07 HD Request # 23 - Using server: ds3.sierracharts.com port 10149 | 2014-07-02 15:25:07 Socket (0) - Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-07-02 15:25:07 HD Request # 24 - Downloading Historical Daily chart data for ES#. Starting date: 2014-07-01. Service: ta | 2014-07-02 15:25:07 HD Request # 24 - Requesting historical Daily Continuous data for ESZ10 starting at 2014-06-30 | 2014-07-02 15:25:07 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:07 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:07 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:07 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:07 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:07 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:07 Socket (2704) - Connected. | 2014-07-02 15:25:07 HD Request # 23 - Sending historical data logon request message. | 2014-07-02 15:25:07 HD Request # 24 - Receiving historical Daily data for ES# starting at 2014-06-30 | 2014-07-02 15:25:07 Writing historical Daily data for ES# to the file ES#.dly | 2014-07-02 15:25:07 HD Request # 24 - Received 3 records from 2014-06-30 00:00:00 to 2014-07-02 00:00:00 (3.0 days) and wrote 2 records for ES# | 2014-07-02 15:25:07 HD Request # 24 - Daily download COMPLETE for ES#. Completion time: 0s | 2014-07-02 15:25:07 HD Request # 23 - Requesting Intraday data. Start Date-Time: 2014-07-02 11:13:54. Record interval: 0. Symbol: HGU4 | 2014-07-02 15:25:07 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:07 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:07 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:07 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:07 HD Request # 23 - Decompressing data. | 2014-07-02 15:25:07 HD Request # 23 - Receiving Intraday data for HGU4 starting at 2014-07-02 11:13:54 | 2014-07-02 15:25:07 HD Request # 23 - Timestamp of first Intraday data file record written: 2014-07-02 11:14:02 | 2014-07-02 15:25:07 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:08 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:08 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:08 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:08 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:08 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:08 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:08 Socket (2704) - Shutdown and closed. | 2014-07-02 15:25:08 The network socket for historical data has been closed. | 2014-07-02 15:25:08 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:08 HD Request # 23 - Received 9544 records from 2014-07-02 11:13:54 to 2014-07-02 15:25:01 (4.2 hours) and wrote 9543 records for HGU4 | 2014-07-02 15:25:08 HD Request # 23 - Intraday download COMPLETE for HGU4. Completion time: 1s | 2014-07-02 15:25:08 Real-time Intraday chart data file updates started for HGU4 | 2014-07-02 15:25:08 HD Request # 25 - Downloading Intraday chart data for HOQ4 to the file HOQ4.scid. Service: ta | 2014-07-02 15:25:08 HD Request # 25 - Download start Date-Time: 2014-07-02 11:13:54.0 | 2014-07-02 15:25:08 HD Request # 25 - Using server: ds4.sierracharts.com port 10149 | 2014-07-02 15:25:08 Socket (0) - Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-07-02 15:25:08 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:08 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:08 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:08 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:08 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:08 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:08 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:08 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:08 Socket (2888) - Connected. | 2014-07-02 15:25:08 HD Request # 25 - Sending historical data logon request message. | 2014-07-02 15:25:08 HD Request # 25 - Requesting Intraday data. Start Date-Time: 2014-07-02 11:13:54. Record interval: 0. Symbol: HOQ4 | 2014-07-02 15:25:08 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:08 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:08 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:08 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:08 HD Request # 25 - Decompressing data. | 2014-07-02 15:25:09 HD Request # 25 - Receiving Intraday data for HOQ4 starting at 2014-07-02 11:13:54 | 2014-07-02 15:25:09 HD Request # 25 - Timestamp of first Intraday data file record written: 2014-07-02 11:14:08 | 2014-07-02 15:25:09 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:09 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:09 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:09 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:09 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:09 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:09 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:09 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:09 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:09 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:09 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:09 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:09 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:09 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:09 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:09 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:09 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:25:09 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:09 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:09 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:09 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:09 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:09 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:09 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:09 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:09 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:09 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:09 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:09 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:09 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:09 Socket (2888) - Shutdown and closed. | 2014-07-02 15:25:09 The network socket for historical data has been closed. | 2014-07-02 15:25:09 HD Request # 25 - Received 13995 records from 2014-07-02 11:13:54 to 2014-07-02 15:24:59 (4.2 hours) and wrote 13994 records for HOQ4 | 2014-07-02 15:25:09 HD Request # 25 - Intraday download COMPLETE for HOQ4. Completion time: 0s | 2014-07-02 15:25:09 Real-time Intraday chart data file updates started for HOQ4 | 2014-07-02 15:25:09 HD Request # 26 - Downloading Intraday chart data for NGQ4 to the file NGQ4.scid. Service: ta | 2014-07-02 15:25:09 HD Request # 26 - Download start Date-Time: 2014-07-02 11:13:58.0 | 2014-07-02 15:25:09 HD Request # 26 - Using server: ds5.sierracharts.com port 10149 | 2014-07-02 15:25:09 Socket (0) - Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-07-02 15:25:09 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 Socket (2564) - Connected. | 2014-07-02 15:25:10 HD Request # 26 - Sending historical data logon request message. | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:10 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:10 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 HD Request # 26 - Requesting Intraday data. Start Date-Time: 2014-07-02 11:13:58. Record interval: 0. Symbol: NGQ4 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 HD Request # 26 - Decompressing data. | 2014-07-02 15:25:10 HD Request # 26 - Receiving Intraday data for NGQ4 starting at 2014-07-02 11:13:58 | 2014-07-02 15:25:10 HD Request # 26 - Timestamp of first Intraday data file record written: 2014-07-02 11:14:05 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:10 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:10 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:10 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:25:11 Socket (2564) - Shutdown and closed. | 2014-07-02 15:25:11 The network socket for historical data has been closed. | 2014-07-02 15:25:11 HD Request # 26 - Received 19462 records from 2014-07-02 11:13:58 to 2014-07-02 15:24:51 (4.2 hours) and wrote 19451 records for NGQ4 | 2014-07-02 15:25:11 HD Request # 26 - Intraday download COMPLETE for NGQ4. Completion time: 2s | 2014-07-02 15:25:11 Real-time Intraday chart data file updates started for NGQ4 | 2014-07-02 15:25:11 HD Request # 27 - Downloading Intraday chart data for NQU4 to the file NQU4.scid. Service: ta | 2014-07-02 15:25:11 HD Request # 27 - Download start Date-Time: 2014-07-02 11:14:02.0 | 2014-07-02 15:25:11 HD Request # 27 - Using server: ds3.sierracharts.com port 10149 | 2014-07-02 15:25:11 Socket (0) - Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 Socket (1804) - Connected. | 2014-07-02 15:25:11 HD Request # 27 - Sending historical data logon request message. | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 HD Request # 27 - Requesting Intraday data. Start Date-Time: 2014-07-02 11:14:02. Record interval: 0. Symbol: NQU4 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 HD Request # 27 - Decompressing data. | 2014-07-02 15:25:11 HD Request # 27 - Receiving Intraday data for NQU4 starting at 2014-07-02 11:14:02 | 2014-07-02 15:25:11 HD Request # 27 - Timestamp of first Intraday data file record written: 2014-07-02 11:14:02 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:11 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 Socket (1804) - Shutdown and closed. | 2014-07-02 15:25:12 The network socket for historical data has been closed. | 2014-07-02 15:25:12 HD Request # 27 - Received 31892 records from 2014-07-02 11:14:02 to 2014-07-02 15:25:10 (4.2 hours) and wrote 31886 records for NQU4 | 2014-07-02 15:25:12 HD Request # 27 - Intraday download COMPLETE for NQU4. Completion time: 1s | 2014-07-02 15:25:12 Real-time Intraday chart data file updates started for NQU4 | 2014-07-02 15:25:12 HD Request # 28 - Downloading Intraday chart data for PLV4 to the file PLV4.scid. Service: ta | 2014-07-02 15:25:12 HD Request # 28 - Download start Date-Time: 2014-07-02 11:14:03.0 | 2014-07-02 15:25:12 HD Request # 28 - Using server: ds4.sierracharts.com port 10149 | 2014-07-02 15:25:12 Socket (0) - Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 Socket (1804) - Connected. | 2014-07-02 15:25:12 HD Request # 28 - Sending historical data logon request message. | 2014-07-02 15:25:12 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:12 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:12 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 HD Request # 28 - Requesting Intraday data. Start Date-Time: 2014-07-02 11:14:03. Record interval: 0. Symbol: PLV4 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:12 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 HD Request # 28 - Decompressing data. | 2014-07-02 15:25:13 HD Request # 28 - Receiving Intraday data for PLV4 starting at 2014-07-02 11:14:03 | 2014-07-02 15:25:13 HD Request # 28 - Timestamp of first Intraday data file record written: 2014-07-02 11:14:06 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 Socket (1804) - Shutdown and closed. | 2014-07-02 15:25:13 The network socket for historical data has been closed. | 2014-07-02 15:25:13 HD Request # 28 - Received 1968 records from 2014-07-02 11:14:03 to 2014-07-02 15:23:19 (4.2 hours) and wrote 1967 records for PLV4 | 2014-07-02 15:25:13 HD Request # 28 - Intraday download COMPLETE for PLV4. Completion time: 1s | 2014-07-02 15:25:13 Real-time Intraday chart data file updates started for PLV4 | 2014-07-02 15:25:13 HD Request # 29 - Downloading Intraday chart data for RBQ4 to the file RBQ4.scid. Service: ta | 2014-07-02 15:25:13 HD Request # 29 - Download start Date-Time: 2014-07-02 11:14:03.0 | 2014-07-02 15:25:13 HD Request # 29 - Using server: ds5.sierracharts.com port 10149 | 2014-07-02 15:25:13 Socket (0) - Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 Error filtered for FDAXU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 9917.000000, Time Difference = 1 seconds, Percentage = 15.001442% | 2014-07-02 15:25:13 Socket (1804) - Connected. | 2014-07-02 15:25:13 HD Request # 29 - Sending historical data logon request message. | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:13 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:13 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 HD Request # 29 - Requesting Intraday data. Start Date-Time: 2014-07-02 11:14:03. Record interval: 0. Symbol: RBQ4 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:13 HD Request # 29 - Decompressing data. | 2014-07-02 15:25:13 HD Request # 29 - Receiving Intraday data for RBQ4 starting at 2014-07-02 11:14:03 | 2014-07-02 15:25:13 HD Request # 29 - Timestamp of first Intraday data file record written: 2014-07-02 11:14:11 | 2014-07-02 15:25:13 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:14 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:14 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 Socket (1804) - Shutdown and closed. | 2014-07-02 15:25:14 The network socket for historical data has been closed. | 2014-07-02 15:25:14 HD Request # 29 - Received 11211 records from 2014-07-02 11:14:03 to 2014-07-02 15:24:56 (4.2 hours) and wrote 11210 records for RBQ4 | 2014-07-02 15:25:14 HD Request # 29 - Intraday download COMPLETE for RBQ4. Completion time: 0s | 2014-07-02 15:25:14 Real-time Intraday chart data file updates started for RBQ4 | 2014-07-02 15:25:14 HD Request # 30 - Downloading Intraday chart data for SIU4 to the file SIU4.scid. Service: ta | 2014-07-02 15:25:14 HD Request # 30 - Download start Date-Time: 2014-07-02 11:14:02.0 | 2014-07-02 15:25:14 HD Request # 30 - Using server: ds3.sierracharts.com port 10149 | 2014-07-02 15:25:14 Socket (0) - Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 Socket (1804) - Connected. | 2014-07-02 15:25:14 HD Request # 30 - Sending historical data logon request message. | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:14 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 HD Request # 30 - Requesting Intraday data. Start Date-Time: 2014-07-02 11:14:02. Record interval: 0. Symbol: SIU4 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 HD Request # 30 - Decompressing data. | 2014-07-02 15:25:15 HD Request # 30 - Receiving Intraday data for SIU4 starting at 2014-07-02 11:14:02 | 2014-07-02 15:25:15 HD Request # 30 - Timestamp of first Intraday data file record written: 2014-07-02 11:14:04 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:15 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:15 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:15 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 Socket (1804) - Shutdown and closed. | 2014-07-02 15:25:16 The network socket for historical data has been closed. | 2014-07-02 15:25:16 HD Request # 30 - Received 7250 records from 2014-07-02 11:14:02 to 2014-07-02 15:22:54 (4.1 hours) and wrote 7247 records for SIU4 | 2014-07-02 15:25:16 HD Request # 30 - Intraday download COMPLETE for SIU4. Completion time: 2s | 2014-07-02 15:25:16 Real-time Intraday chart data file updates started for SIU4 | 2014-07-02 15:25:16 HD Request # 31 - Downloading Intraday chart data for TFU4 to the file TFU4.scid. Service: ta | 2014-07-02 15:25:16 HD Request # 31 - Download start Date-Time: 2014-07-02 11:14:04.0 | 2014-07-02 15:25:16 HD Request # 31 - Using server: ds4.sierracharts.com port 10149 | 2014-07-02 15:25:16 Socket (0) - Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 Socket (1804) - Connected. | 2014-07-02 15:25:16 HD Request # 31 - Sending historical data logon request message. | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 HD Request # 31 - Requesting Intraday data. Start Date-Time: 2014-07-02 11:14:04. Record interval: 0. Symbol: TFU4 | 2014-07-02 15:25:16 Error filtered for FDAXU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 9917.500000, Time Difference = 3 seconds, Percentage = 15.004443% | 2014-07-02 15:25:16 Error filtered for FDAXU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 9917.500000, Time Difference = 3 seconds, Percentage = 15.004443% | 2014-07-02 15:25:16 Error filtered for FDAXU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 9918.000000, Time Difference = 3 seconds, Percentage = 15.004443% | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:16 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:16 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 HD Request # 31 - Decompressing data. | 2014-07-02 15:25:16 Error filtered for FDAXU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 9918.000000, Time Difference = 3 seconds, Percentage = 15.004443% | 2014-07-02 15:25:16 Error filtered for NGQ4, Intraday High = 3888.500000, Intraday Low = 3888.250000, Value = 4.366000, Time Difference = 1 seconds, Percentage = 10.000988% | 2014-07-02 15:25:16 HD Request # 31 - Receiving Intraday data for TFU4 starting at 2014-07-02 11:14:04 | 2014-07-02 15:25:16 Error filtered for GCQ4, Intraday High = 3888.500000, Intraday Low = 3888.250000, Value = 1328.500000, Time Difference = 1 seconds, Percentage = 10.000988% | 2014-07-02 15:25:16 HD Request # 31 - Timestamp of first Intraday data file record written: 2014-07-02 11:14:07 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 Error filtered for FDAXU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 9918.500000, Time Difference = 3 seconds, Percentage = 15.004443% | 2014-07-02 15:25:16 Error filtered for GCQ4, Intraday High = 3888.500000, Intraday Low = 3888.250000, Value = 1328.400024, Time Difference = 1 seconds, Percentage = 10.000988% | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:16 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:17 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:17 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 Error filtered for GCQ4, Intraday High = 3888.500000, Intraday Low = 3888.250000, Value = 1328.400024, Time Difference = 1 seconds, Percentage = 10.000988% | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 Socket (1804) - Shutdown and closed. | 2014-07-02 15:25:17 The network socket for historical data has been closed. | 2014-07-02 15:25:17 HD Request # 31 - Received 42246 records from 2014-07-02 11:14:04 to 2014-07-02 15:25:14 (4.2 hours) and wrote 42242 records for TFU4 | 2014-07-02 15:25:17 Added 17 Time and Sales records to Intraday data file for TFU4 after download. | 2014-07-02 15:25:17 HD Request # 31 - Intraday download COMPLETE for TFU4. Completion time: 0s | 2014-07-02 15:25:17 Real-time Intraday chart data file updates started for TFU4 | 2014-07-02 15:25:17 HD Request # 32 - Downloading Intraday chart data for YMU4 to the file YMU4.scid. Service: ta | 2014-07-02 15:25:17 HD Request # 32 - Download start Date-Time: 2014-07-02 11:14:02.0 | 2014-07-02 15:25:17 HD Request # 32 - Using server: ds5.sierracharts.com port 10149 | 2014-07-02 15:25:17 Socket (0) - Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 Error filtered for TFU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 1195.900024, Time Difference = 1 seconds, Percentage = 15.001385% | 2014-07-02 15:25:17 Error filtered for GCQ4, Intraday High = 3888.500000, Intraday Low = 3888.250000, Value = 1328.400024, Time Difference = 3 seconds, Percentage = 10.002989% | 2014-07-02 15:25:17 Error filtered for TFU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 1195.900024, Time Difference = 1 seconds, Percentage = 15.001385% | 2014-07-02 15:25:17 Error filtered for TFU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 1195.900024, Time Difference = 1 seconds, Percentage = 15.001385% | 2014-07-02 15:25:17 Error filtered for TFU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 1195.900024, Time Difference = 1 seconds, Percentage = 15.001385% | 2014-07-02 15:25:17 Error filtered for TFU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 1195.900024, Time Difference = 1 seconds, Percentage = 15.001385% | 2014-07-02 15:25:17 Error filtered for TFU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 1195.900024, Time Difference = 1 seconds, Percentage = 15.001385% | 2014-07-02 15:25:17 Error filtered for TFU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 1195.800049, Time Difference = 2 seconds, Percentage = 15.002885% | 2014-07-02 15:25:17 Error filtered for TFU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 1195.800049, Time Difference = 2 seconds, Percentage = 15.002885% | 2014-07-02 15:25:17 Error filtered for TFU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 1195.800049, Time Difference = 2 seconds, Percentage = 15.002885% | 2014-07-02 15:25:17 Error filtered for TFU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 1195.800049, Time Difference = 2 seconds, Percentage = 15.002885% | 2014-07-02 15:25:17 Error filtered for TFU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 1195.800049, Time Difference = 2 seconds, Percentage = 15.002885% | 2014-07-02 15:25:17 Error filtered for TFU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 1195.800049, Time Difference = 2 seconds, Percentage = 15.002885% | 2014-07-02 15:25:17 Socket (2272) - Connected. | 2014-07-02 15:25:17 HD Request # 32 - Sending historical data logon request message. | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:17 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:17 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 HD Request # 32 - Requesting Intraday data. Start Date-Time: 2014-07-02 11:14:02. Record interval: 0. Symbol: YMU4 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 Error filtered for TFU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 1195.800049, Time Difference = 2 seconds, Percentage = 15.002885% | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 HD Request # 32 - Decompressing data. | 2014-07-02 15:25:17 Error filtered for TFU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 1195.800049, Time Difference = 2 seconds, Percentage = 15.002885% | 2014-07-02 15:25:17 Error filtered for TFU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 1195.699951, Time Difference = 3 seconds, Percentage = 15.004385% | 2014-07-02 15:25:17 Error filtered for TFU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 1195.699951, Time Difference = 3 seconds, Percentage = 15.004385% | 2014-07-02 15:25:17 HD Request # 32 - Receiving Intraday data for YMU4 starting at 2014-07-02 11:14:02 | 2014-07-02 15:25:17 Error filtered for TFU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 1195.699951, Time Difference = 3 seconds, Percentage = 15.004385% | 2014-07-02 15:25:17 Error filtered for TFU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 1195.699951, Time Difference = 3 seconds, Percentage = 15.004385% | 2014-07-02 15:25:17 HD Request # 32 - Timestamp of first Intraday data file record written: 2014-07-02 11:14:07 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:17 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 Error filtered for TFU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 1195.699951, Time Difference = 4 seconds, Percentage = 15.005885% | 2014-07-02 15:25:18 Error filtered for TFU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 1195.699951, Time Difference = 4 seconds, Percentage = 15.005885% | 2014-07-02 15:25:18 Error filtered for TFU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 1195.699951, Time Difference = 4 seconds, Percentage = 15.005885% | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 Socket (2272) - Shutdown and closed. | 2014-07-02 15:25:18 The network socket for historical data has been closed. | 2014-07-02 15:25:18 HD Request # 32 - Received 13634 records from 2014-07-02 11:14:02 to 2014-07-02 15:25:15 (4.2 hours) and wrote 13632 records for YMU4 | 2014-07-02 15:25:18 Added 5 Time and Sales records to Intraday data file for YMU4 after download. | 2014-07-02 15:25:18 HD Request # 32 - Intraday download COMPLETE for YMU4. Completion time: 1s | 2014-07-02 15:25:18 Real-time Intraday chart data file updates started for YMU4 | 2014-07-02 15:25:18 HD Request # 33 - Downloading Intraday chart data for ZCU4 to the file ZCU4.scid. Service: ta | 2014-07-02 15:25:18 HD Request # 33 - Download start Date-Time: 2014-07-02 11:13:55.0 | 2014-07-02 15:25:18 HD Request # 33 - Using server: ds3.sierracharts.com port 10149 | 2014-07-02 15:25:18 Socket (0) - Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 Socket (2836) - Connected. | 2014-07-02 15:25:18 HD Request # 33 - Sending historical data logon request message. | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 HD Request # 33 - Requesting Intraday data. Start Date-Time: 2014-07-02 11:13:55. Record interval: 0. Symbol: ZCU4 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 HD Request # 33 - Decompressing data. | 2014-07-02 15:25:18 HD Request # 33 - Receiving Intraday data for ZCU4 starting at 2014-07-02 11:13:55 | 2014-07-02 15:25:18 HD Request # 33 - Timestamp of first Intraday data file record written: 2014-07-02 11:14:06 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:18 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:19 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:19 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 Error filtered for FDAXU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 9918.000000, Time Difference = 7 seconds, Percentage = 15.010442% | 2014-07-02 15:25:19 Error filtered for FDAXU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 9918.000000, Time Difference = 7 seconds, Percentage = 15.010442% | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 Socket (2836) - Shutdown and closed. | 2014-07-02 15:25:19 The network socket for historical data has been closed. | 2014-07-02 15:25:19 HD Request # 33 - Received 10849 records from 2014-07-02 11:13:55 to 2014-07-02 14:14:59 (3.0 hours) and wrote 10810 records for ZCU4 | 2014-07-02 15:25:19 HD Request # 33 - Intraday download COMPLETE for ZCU4. Completion time: 0s | 2014-07-02 15:25:19 Real-time Intraday chart data file updates started for ZCU4 | 2014-07-02 15:25:19 HD Request # 34 - Downloading Intraday chart data for ZSX4 to the file ZSX4.scid. Service: ta | 2014-07-02 15:25:19 HD Request # 34 - Download start Date-Time: 2014-07-02 11:14:06.0 | 2014-07-02 15:25:19 HD Request # 34 - Using server: ds4.sierracharts.com port 10149 | 2014-07-02 15:25:19 Socket (0) - Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 Socket (2836) - Connected. | 2014-07-02 15:25:19 HD Request # 34 - Sending historical data logon request message. | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 HD Request # 34 - Requesting Intraday data. Start Date-Time: 2014-07-02 11:14:06. Record interval: 0. Symbol: ZSX4 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 Error filtered for TFU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 1195.699951, Time Difference = 5 seconds, Percentage = 15.007386% | 2014-07-02 15:25:19 Error filtered for TFU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 1195.699951, Time Difference = 5 seconds, Percentage = 15.007386% | 2014-07-02 15:25:19 Error filtered for TFU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 1195.699951, Time Difference = 5 seconds, Percentage = 15.007386% | 2014-07-02 15:25:19 Error filtered for YMU4, Intraday High = 3888.250000, Intraday Low = 3888.000000, Value = 16892.000000, Time Difference = 1 seconds, Percentage = 10.000999% | 2014-07-02 15:25:19 Error filtered for YMU4, Intraday High = 3888.250000, Intraday Low = 3888.000000, Value = 16892.000000, Time Difference = 1 seconds, Percentage = 10.000999% | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:19 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 HD Request # 34 - Decompressing data. | 2014-07-02 15:25:20 HD Request # 34 - Receiving Intraday data for ZSX4 starting at 2014-07-02 11:14:06 | 2014-07-02 15:25:20 HD Request # 34 - Timestamp of first Intraday data file record written: 2014-07-02 11:14:07 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 Error filtered for CLQ4, Intraday High = 3888.250000, Intraday Low = 3888.000000, Value = 104.239998, Time Difference = 2 seconds, Percentage = 10.001999% | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 Socket (2836) - Shutdown and closed. | 2014-07-02 15:25:20 The network socket for historical data has been closed. | 2014-07-02 15:25:20 HD Request # 34 - Received 16369 records from 2014-07-02 11:14:06 to 2014-07-02 14:14:59 (3.0 hours) and wrote 16368 records for ZSX4 | 2014-07-02 15:25:20 HD Request # 34 - Intraday download COMPLETE for ZSX4. Completion time: 1s | 2014-07-02 15:25:20 Real-time Intraday chart data file updates started for ZSX4 | 2014-07-02 15:25:20 HD Request # 35 - Downloading Intraday chart data for ZWU4 to the file ZWU4.scid. Service: ta | 2014-07-02 15:25:20 HD Request # 35 - Download start Date-Time: 2014-07-02 11:14:00.0 | 2014-07-02 15:25:20 HD Request # 35 - Using server: ds5.sierracharts.com port 10149 | 2014-07-02 15:25:20 Socket (0) - Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 Socket (2836) - Connected. | 2014-07-02 15:25:20 HD Request # 35 - Sending historical data logon request message. | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 Error filtered for CLQ4, Intraday High = 3888.250000, Intraday Low = 3888.000000, Value = 104.239998, Time Difference = 2 seconds, Percentage = 10.001999% | 2014-07-02 15:25:20 Error filtered for CLQ4, Intraday High = 3888.250000, Intraday Low = 3888.000000, Value = 104.239998, Time Difference = 2 seconds, Percentage = 10.001999% | 2014-07-02 15:25:20 Error filtered for CLQ4, Intraday High = 3888.250000, Intraday Low = 3888.000000, Value = 104.239998, Time Difference = 2 seconds, Percentage = 10.001999% | 2014-07-02 15:25:20 Error filtered for CLQ4, Intraday High = 3888.250000, Intraday Low = 3888.000000, Value = 104.239998, Time Difference = 2 seconds, Percentage = 10.001999% | 2014-07-02 15:25:20 Error filtered for CLQ4, Intraday High = 3888.250000, Intraday Low = 3888.000000, Value = 104.239998, Time Difference = 2 seconds, Percentage = 10.001999% | 2014-07-02 15:25:20 Error filtered for CLQ4, Intraday High = 3888.250000, Intraday Low = 3888.000000, Value = 104.239998, Time Difference = 2 seconds, Percentage = 10.001999% | 2014-07-02 15:25:20 Error filtered for CLQ4, Intraday High = 3888.250000, Intraday Low = 3888.000000, Value = 104.239998, Time Difference = 2 seconds, Percentage = 10.001999% | 2014-07-02 15:25:20 Error filtered for CLQ4, Intraday High = 3888.250000, Intraday Low = 3888.000000, Value = 104.239998, Time Difference = 2 seconds, Percentage = 10.001999% | 2014-07-02 15:25:20 Error filtered for CLQ4, Intraday High = 3888.250000, Intraday Low = 3888.000000, Value = 104.239998, Time Difference = 2 seconds, Percentage = 10.001999% | 2014-07-02 15:25:20 Error filtered for PLV4, Intraday High = 3888.250000, Intraday Low = 3888.000000, Value = 1510.699951, Time Difference = 2 seconds, Percentage = 10.001999% | 2014-07-02 15:25:20 Error filtered for PLV4, Intraday High = 3888.250000, Intraday Low = 3888.000000, Value = 1510.599976, Time Difference = 2 seconds, Percentage = 10.001999% | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 HD Request # 35 - Requesting Intraday data. Start Date-Time: 2014-07-02 11:14:00. Record interval: 0. Symbol: ZWU4 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:20 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 HD Request # 35 - Decompressing data. | 2014-07-02 15:25:21 HD Request # 35 - Receiving Intraday data for ZWU4 starting at 2014-07-02 11:14:00 | 2014-07-02 15:25:21 HD Request # 35 - Timestamp of first Intraday data file record written: 2014-07-02 11:14:09 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 Error filtered for CLQ4, Intraday High = 3888.250000, Intraday Low = 3888.000000, Value = 104.239998, Time Difference = 3 seconds, Percentage = 10.003000% | 2014-07-02 15:25:21 Socket (2836) - Shutdown and closed. | 2014-07-02 15:25:21 The network socket for historical data has been closed. | 2014-07-02 15:25:21 HD Request # 35 - Received 10169 records from 2014-07-02 11:14:00 to 2014-07-02 14:14:59 (3.0 hours) and wrote 10168 records for ZWU4 | 2014-07-02 15:25:21 HD Request # 35 - Intraday download COMPLETE for ZWU4. Completion time: 1s | 2014-07-02 15:25:21 Real-time Intraday chart data file updates started for ZWU4 | 2014-07-02 15:25:21 HD Request # 36 - Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2014-07-02 15:25:21 HD Request # 36 - Download start Date-Time: 2014-07-02 11:14:08.0 | 2014-07-02 15:25:21 HD Request # 36 - Using server: ds3.sierracharts.com port 10149 | 2014-07-02 15:25:21 Socket (0) - Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:21 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 Error filtered for FDAXU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 9917.500000, Time Difference = 10 seconds, Percentage = 15.014942% | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:22 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:22 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 Error filtered for FDAXU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 9917.500000, Time Difference = 11 seconds, Percentage = 15.016443% | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:22 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:23 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:23 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 Error filtered for GCQ4, Intraday High = 3888.500000, Intraday Low = 3888.250000, Value = 1328.400024, Time Difference = 9 seconds, Percentage = 10.008989% | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:23 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:24 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:24 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 Socket (2564) - Connected. | 2014-07-02 15:25:24 HD Request # 36 - Sending historical data logon request message. | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:24 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 HD Request # 36 - Requesting Intraday data. Start Date-Time: 2014-07-02 11:14:08. Record interval: 0. Symbol: TICK-NYSE | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 HD Request # 36 - Decompressing data. | 2014-07-02 15:25:25 HD Request # 36 - Receiving Intraday data for TICK-NYSE starting at 2014-07-02 11:14:08 | 2014-07-02 15:25:25 Error filtered for TFU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 1195.699951, Time Difference = 11 seconds, Percentage = 15.016384% | 2014-07-02 15:25:25 Error filtered for TFU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 1195.699951, Time Difference = 11 seconds, Percentage = 15.016384% | 2014-07-02 15:25:25 Error filtered for TFU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 1195.699951, Time Difference = 11 seconds, Percentage = 15.016384% | 2014-07-02 15:25:25 Error filtered for TFU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 1195.699951, Time Difference = 11 seconds, Percentage = 15.016384% | 2014-07-02 15:25:25 Error filtered for TFU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 1195.699951, Time Difference = 11 seconds, Percentage = 15.016384% | 2014-07-02 15:25:25 HD Request # 36 - Timestamp of first Intraday data file record written: 2014-07-02 11:14:09 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:25 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:25 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:25 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:26 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:26 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 Error filtered for TFU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 1195.699951, Time Difference = 11 seconds, Percentage = 15.016384% | 2014-07-02 15:25:26 Error filtered for TFU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 1195.699951, Time Difference = 11 seconds, Percentage = 15.016384% | 2014-07-02 15:25:26 Error filtered for HOQ4, Intraday High = 3888.250000, Intraday Low = 3888.000000, Value = 2.941300, Time Difference = 1 seconds, Percentage = 10.000999% | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:26 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:26 Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 Error filtered for TFU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 1195.800049, Time Difference = 12 seconds, Percentage = 15.017885% | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:26 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 Error filtered for TFU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 1195.800049, Time Difference = 12 seconds, Percentage = 15.017885% | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 Error filtered for TFU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 1195.699951, Time Difference = 13 seconds, Percentage = 15.019386% | 2014-07-02 15:25:27 Error filtered for TFU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 1195.699951, Time Difference = 13 seconds, Percentage = 15.019386% | 2014-07-02 15:25:27 Error filtered for TFU4, Intraday High = 1966.500000, Intraday Low = 1966.250000, Value = 1195.699951, Time Difference = 13 seconds, Percentage = 15.019386% | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:27 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:28 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 Socket (2564) - Shutdown and closed. | 2014-07-02 15:25:29 The network socket for historical data has been closed. | 2014-07-02 15:25:29 HD Request # 36 - Received 15073 records from 2014-07-02 11:14:08 to 2014-07-02 15:25:25 (4.2 hours) and wrote 15072 records for TICK-NYSE | 2014-07-02 15:25:29 Added 12 Time and Sales records to Intraday data file for TICK-NYSE after download. | 2014-07-02 15:25:29 HD Request # 36 - Intraday download COMPLETE for TICK-NYSE. Completion time: 8s | 2014-07-02 15:25:29 Real-time Intraday chart data file updates started for TICK-NYSE | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-07-02 15:25:29 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 1 |
[2014-07-02 19:41:02] |
mayerrs - Posts: 70 |
ok, now i have got 1156 version. i opened my chartbooks - it is ok. but i am still not able to open my studies: here is a alert manager (it was pop up window by itself - i never sw it before) and under alert log is message log: i just have seen when i do F6 for studies there is no studies on left side. it is clear. so that is propabyl why is my studies set is not working. ps: i can see i am not able to copy whole alert manager so here is 1st row of alerts log and then message log: Alert Formula Error - Chart: CLQ4 2 Min #1 | Study: CountDown Timer | Error: Invalid formula. | Formula: ( | 2014-07-02 15:34:14 Software version: 1156 | 2014-07-02 15:33:21 Enabled for: Advanced Features. | 2014-07-02 15:33:21 Enabled for: Sierra Chart Historical Data Service. | 2014-07-02 15:33:21 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-07-02 15:33:21 Active service: TransAct Trading | 2014-07-02 15:33:21 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-07-02 15:33:21 2014-07-02 15:33:21 Local computer clock time | 2014-07-02 15:33:21 2014-07-02 19:33:21 GMT time | 2014-07-02 15:33:21 2014-07-02 15:33:21 Time zone adjusted time | 2014-07-02 15:33:21 Time difference to server time: 0 seconds. | 2014-07-02 15:33:21 Program path: C:\SierraChart\SierraChartTransActMA\ | 2014-07-02 15:33:21 Data Files path: C:\SierraChart\SierraChartTransActMA\Data\ | 2014-07-02 15:33:21 OS Version Number: 5.1 | 2014-07-02 15:33:21 Checking for new symbol settings for ta | 2014-07-02 15:33:21 Requesting symbol settings for ta. Overwrite = off. | 2014-07-02 15:33:21 Symbol settings received. | 2014-07-02 15:33:23 Processed received symbol settings | 2014-07-02 15:33:23 Requesting data files from remote instance: CLQ4.scid, ESU4.scid, FDAXU4.scid, GCQ4.scid, HGU4.scid, HOQ4.scid, NGQ4.scid, NQU4.scid, PLV4.scid, RBQ4.scid, SIU4.scid, TFU4.scid, YMU4.scid, ZCU4.scid, ZSX4.scid, ZWU4.scid | 2014-07-02 15:33:30 Remote instance requested data files: CLQ4.scid, ESU4.scid, FDAXU4.scid, GCQ4.scid, HGU4.scid, HOQ4.scid, NGQ4.scid, NQU4.scid, PLV4.scid, RBQ4.scid, SIU4.scid, TFU4.scid, YMU4.scid, ZCU4.scid, ZSX4.scid, ZWU4.scid | 2014-07-02 15:33:31 Requesting data files from remote instance: RJ#.dly | 2014-07-02 15:33:49 Remote instance requested data files: RJ#.dly | 2014-07-02 15:33:49 Chart: HOQ4 [R] 2 Min #18 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:33:53 Chart: HOQ4 [R] 2 Min #18 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:33:53 Chart: HOQ4 [R] 2 Min #18 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:33:53 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 Chart: CLQ4 [R] 2 Min #17 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:33:56 Chart: CLQ4 [R] 2 Min #17 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:33:56 Chart: CLQ4 [R] 2 Min #17 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:33:56 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:33:56 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:33:56 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:33:56 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:33:56 TransAct Trading - Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2014-07-02 15:33:56 HD Request # 2 - Downloading Historical Daily chart data for DY#. Starting date: 2014-07-01. Service: ta | 2014-07-02 15:33:56 HD Request # 2 - Requesting historical Daily Continuous data for DYZ10 starting at 2014-06-30 | 2014-07-02 15:33:56 HD Request # 3 - Downloading Intraday chart data for FDAXU4 to the file FDAXU4.scid. Service: ta | 2014-07-02 15:33:57 HD Request # 3 - Download start Date-Time: 2014-07-02 15:25:01.0 | 2014-07-02 15:33:57 HD Request # 3 - Using server: ds4.sierracharts.com port 10149 | 2014-07-02 15:33:57 Socket (0) - Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-07-02 15:33:57 Requesting data files from remote instance: RJ#.dly | 2014-07-02 15:33:57 Remote instance requested data files: RJ#.dly | 2014-07-02 15:33:57 Socket (1956) - Connected. | 2014-07-02 15:33:57 HD Request # 3 - Sending historical data logon request message. | 2014-07-02 15:33:57 HD Request # 2 - Receiving historical Daily data for DY# starting at 2014-06-30 | 2014-07-02 15:33:57 Writing historical Daily data for DY# to the file DY#.dly | 2014-07-02 15:33:57 HD Request # 2 - Received 3 records from 2014-06-30 00:00:00 to 2014-07-02 00:00:00 (3.0 days) and wrote 2 records for DY# | 2014-07-02 15:33:57 HD Request # 2 - Daily download COMPLETE for DY#. Completion time: 1s | 2014-07-02 15:33:57 HD Request # 4 - Downloading Historical Daily chart data for ZW#. Starting date: 2014-07-01. Service: ta | 2014-07-02 15:33:57 HD Request # 4 - Requesting historical Daily Continuous data for ZWZ10 starting at 2014-06-30 | 2014-07-02 15:33:57 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:33:57 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:33:57 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:33:57 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:33:57 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:33:57 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:33:57 Chart: HOQ4 [R] 2 Min #18 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:33:57 Chart: HOQ4 [R] 2 Min #18 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:33:57 Chart: HOQ4 [R] 2 Min #18 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:33:57 Chart: CLQ4 [R] 2 Min #17 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:33:57 Chart: CLQ4 [R] 2 Min #17 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:33:57 Chart: CLQ4 [R] 2 Min #17 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:33:57 HD Request # 4 - Receiving historical Daily data for ZW# starting at 2014-06-30 | 2014-07-02 15:33:58 Writing historical Daily data for ZW# to the file ZW#.dly | 2014-07-02 15:33:58 HD Request # 4 - Received 3 records from 2014-06-30 00:00:00 to 2014-07-02 00:00:00 (3.0 days) and wrote 2 records for ZW# | 2014-07-02 15:33:58 HD Request # 4 - Daily download COMPLETE for ZW#. Completion time: 0s | 2014-07-02 15:33:58 HD Request # 5 - Downloading Historical Daily chart data for ZS#. Starting date: 2014-07-01. Service: ta | 2014-07-02 15:33:58 HD Request # 5 - Requesting historical Daily Continuous data for ZSZ10 starting at 2014-06-30 | 2014-07-02 15:33:58 HD Request # 3 - Requesting Intraday data. Start Date-Time: 2014-07-02 15:25:01. Record interval: 0. Symbol: FDAXU4 | 2014-07-02 15:33:58 HD Request # 3 - Historical data for FDAXU4 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-07-02 15:33:58 Socket (1956) - Shutdown and closed. | 2014-07-02 15:33:58 The network socket for historical data has been closed. | 2014-07-02 15:33:58 HD Request # 3 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for FDAXU4 | 2014-07-02 15:33:58 HD Request # 3 - Intraday download COMPLETE for FDAXU4. Completion time: 0s | 2014-07-02 15:33:58 HD Request # 5 - Receiving historical Daily data for ZS# starting at 2014-06-30 | 2014-07-02 15:33:58 Writing historical Daily data for ZS# to the file ZS#.dly | 2014-07-02 15:33:58 HD Request # 5 - Received 3 records from 2014-06-30 00:00:00 to 2014-07-02 00:00:00 (3.0 days) and wrote 2 records for ZS# | 2014-07-02 15:33:58 HD Request # 5 - Daily download COMPLETE for ZS#. Completion time: 0s | 2014-07-02 15:33:58 HD Request # 6 - Downloading Intraday chart data for ZSX4 to the file ZSX4.scid. Service: ta | 2014-07-02 15:33:58 HD Request # 6 - Download start Date-Time: 2014-07-02 14:14:59.0 | 2014-07-02 15:33:58 HD Request # 6 - Using server: ds5.sierracharts.com port 10149 | 2014-07-02 15:33:58 Socket (0) - Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-07-02 15:33:58 HD Request # 7 - Downloading Historical Daily chart data for ZC#. Starting date: 2014-07-01. Service: ta | 2014-07-02 15:33:58 HD Request # 7 - Requesting historical Daily Continuous data for ZCZ10 starting at 2014-06-30 | 2014-07-02 15:33:58 TransAct Trading: Connecting to the server 127.0.0.1. Port 1869 | 2014-07-02 15:33:58 Socket (572) - Connected. | 2014-07-02 15:33:58 TransAct Trading: Connected to server. | 2014-07-02 15:33:58 TransAct Trading: Sending logon request message. | 2014-07-02 15:33:58 Socket (2100) - Connected. | 2014-07-02 15:33:58 HD Request # 6 - Sending historical data logon request message. | 2014-07-02 15:33:58 HD Request # 7 - Receiving historical Daily data for ZC# starting at 2014-06-30 | 2014-07-02 15:33:58 Writing historical Daily data for ZC# to the file ZC#.dly | 2014-07-02 15:33:58 HD Request # 7 - Received 3 records from 2014-06-30 00:00:00 to 2014-07-02 00:00:00 (3.0 days) and wrote 2 records for ZC# | 2014-07-02 15:33:58 HD Request # 7 - Daily download COMPLETE for ZC#. Completion time: 0s | 2014-07-02 15:33:58 HD Request # 8 - Downloading Historical Daily chart data for RJ#. Starting date: 2014-07-01. Service: ta | 2014-07-02 15:33:59 HD Request # 8 - Requesting historical Daily Continuous data for RJZ10 starting at 2014-06-30 | 2014-07-02 15:33:59 HD Request # 8 - Receiving historical Daily data for RJ# starting at 2014-06-30 | 2014-07-02 15:33:59 HD Request # 6 - Requesting Intraday data. Start Date-Time: 2014-07-02 14:14:59. Record interval: 0. Symbol: ZSX4 | 2014-07-02 15:33:59 Writing historical Daily data for RJ# to the file RJ#.dly | 2014-07-02 15:33:59 HD Request # 8 - Received 3 records from 2014-06-30 00:00:00 to 2014-07-02 00:00:00 (3.0 days) and wrote 2 records for RJ# | 2014-07-02 15:33:59 HD Request # 8 - Daily download COMPLETE for RJ#. Completion time: 0s | 2014-07-02 15:33:59 HD Request # 9 - Downloading Historical Daily chart data for YM#. Starting date: 2014-07-01. Service: ta | 2014-07-02 15:33:59 HD Request # 9 - Requesting historical Daily Continuous data for YMZ10 starting at 2014-06-30 | 2014-07-02 15:33:59 HD Request # 6 - Historical data for ZSX4 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-07-02 15:33:59 Socket (2100) - Shutdown and closed. | 2014-07-02 15:33:59 The network socket for historical data has been closed. | 2014-07-02 15:33:59 HD Request # 6 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ZSX4 | 2014-07-02 15:33:59 HD Request # 6 - Intraday download COMPLETE for ZSX4. Completion time: 1s | 2014-07-02 15:33:59 HD Request # 9 - Receiving historical Daily data for YM# starting at 2014-06-30 | 2014-07-02 15:33:59 Writing historical Daily data for YM# to the file YM#.dly | 2014-07-02 15:33:59 HD Request # 9 - Received 3 records from 2014-06-30 00:00:00 to 2014-07-02 00:00:00 (3.0 days) and wrote 2 records for YM# | 2014-07-02 15:33:59 HD Request # 9 - Daily download COMPLETE for YM#. Completion time: 0s | 2014-07-02 15:33:59 HD Request # 10 - Downloading Intraday chart data for ZCU4 to the file ZCU4.scid. Service: ta | 2014-07-02 15:33:59 HD Request # 10 - Download start Date-Time: 2014-07-02 14:14:59.0 | 2014-07-02 15:33:59 HD Request # 10 - Using server: ds3.sierracharts.com port 10149 | 2014-07-02 15:33:59 Socket (0) - Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-07-02 15:33:59 HD Request # 11 - Downloading Historical Daily chart data for NQ#. Starting date: 2014-07-01. Service: ta | 2014-07-02 15:33:59 HD Request # 11 - Requesting historical Daily Continuous data for NQZ10 starting at 2014-06-30 | 2014-07-02 15:33:59 Socket (2280) - Connected. | 2014-07-02 15:34:00 HD Request # 10 - Sending historical data logon request message. | 2014-07-02 15:34:00 HD Request # 11 - Receiving historical Daily data for NQ# starting at 2014-06-30 | 2014-07-02 15:34:00 Writing historical Daily data for NQ# to the file NQ#.dly | 2014-07-02 15:34:00 HD Request # 11 - Received 3 records from 2014-06-30 00:00:00 to 2014-07-02 00:00:00 (3.0 days) and wrote 2 records for NQ# | 2014-07-02 15:34:00 HD Request # 11 - Daily download COMPLETE for NQ#. Completion time: 1s | 2014-07-02 15:34:00 HD Request # 12 - Downloading Historical Daily chart data for ES#. Starting date: 2014-07-01. Service: ta | 2014-07-02 15:34:00 HD Request # 12 - Requesting historical Daily Continuous data for ESZ10 starting at 2014-06-30 | 2014-07-02 15:34:00 HD Request # 10 - Requesting Intraday data. Start Date-Time: 2014-07-02 14:14:59. Record interval: 0. Symbol: ZCU4 | 2014-07-02 15:34:00 HD Request # 12 - Receiving historical Daily data for ES# starting at 2014-06-30 | 2014-07-02 15:34:00 Writing historical Daily data for ES# to the file ES#.dly | 2014-07-02 15:34:00 HD Request # 12 - Received 3 records from 2014-06-30 00:00:00 to 2014-07-02 00:00:00 (3.0 days) and wrote 2 records for ES# | 2014-07-02 15:34:00 HD Request # 12 - Daily download COMPLETE for ES#. Completion time: 0s | 2014-07-02 15:34:00 HD Request # 13 - Downloading Historical Daily chart data for HG#. Starting date: 2014-07-01. Service: ta | 2014-07-02 15:34:00 HD Request # 13 - Requesting historical Daily Continuous data for HGZ10 starting at 2014-06-30 | 2014-07-02 15:34:00 HD Request # 10 - Historical data for ZCU4 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-07-02 15:34:01 Socket (2280) - Shutdown and closed. | 2014-07-02 15:34:01 The network socket for historical data has been closed. | 2014-07-02 15:34:01 HD Request # 10 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ZCU4 | 2014-07-02 15:34:01 HD Request # 10 - Intraday download COMPLETE for ZCU4. Completion time: 2s | 2014-07-02 15:34:01 HD Request # 14 - Downloading Intraday chart data for ZWU4 to the file ZWU4.scid. Service: ta | 2014-07-02 15:34:01 HD Request # 14 - Download start Date-Time: 2014-07-02 14:14:59.0 | 2014-07-02 15:34:01 HD Request # 14 - Using server: ds4.sierracharts.com port 10149 | 2014-07-02 15:34:01 HD Request # 13 - Receiving historical Daily data for HG# starting at 2014-06-30 | 2014-07-02 15:34:01 Writing historical Daily data for HG# to the file HG#.dly | 2014-07-02 15:34:01 HD Request # 13 - Received 3 records from 2014-06-30 00:00:00 to 2014-07-02 00:00:00 (3.0 days) and wrote 2 records for HG# | 2014-07-02 15:34:01 HD Request # 13 - Daily download COMPLETE for HG#. Completion time: 0s | 2014-07-02 15:34:01 Socket (0) - Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-07-02 15:34:01 HD Request # 15 - Downloading Historical Daily chart data for PL#. Starting date: 2014-07-01. Service: ta | 2014-07-02 15:34:01 HD Request # 15 - Requesting historical Daily Continuous data for PLZ10 starting at 2014-06-30 | 2014-07-02 15:34:01 Socket (2284) - Connected. | 2014-07-02 15:34:01 HD Request # 14 - Sending historical data logon request message. | 2014-07-02 15:34:01 HD Request # 15 - Receiving historical Daily data for PL# starting at 2014-06-30 | 2014-07-02 15:34:01 Writing historical Daily data for PL# to the file PL#.dly | 2014-07-02 15:34:01 HD Request # 15 - Received 3 records from 2014-06-30 00:00:00 to 2014-07-02 00:00:00 (3.0 days) and wrote 2 records for PL# | 2014-07-02 15:34:01 HD Request # 15 - Daily download COMPLETE for PL#. Completion time: 0s | 2014-07-02 15:34:01 HD Request # 16 - Downloading Historical Daily chart data for SI#. Starting date: 2014-07-01. Service: ta | 2014-07-02 15:34:01 HD Request # 16 - Requesting historical Daily Continuous data for SIZ10 starting at 2014-06-30 | 2014-07-02 15:34:01 HD Request # 14 - Requesting Intraday data. Start Date-Time: 2014-07-02 14:14:59. Record interval: 0. Symbol: ZWU4 | 2014-07-02 15:34:01 HD Request # 16 - Receiving historical Daily data for SI# starting at 2014-06-30 | 2014-07-02 15:34:01 Writing historical Daily data for SI# to the file SI#.dly | 2014-07-02 15:34:01 HD Request # 16 - Received 3 records from 2014-06-30 00:00:00 to 2014-07-02 00:00:00 (3.0 days) and wrote 2 records for SI# | 2014-07-02 15:34:01 HD Request # 16 - Daily download COMPLETE for SI#. Completion time: 0s | 2014-07-02 15:34:01 HD Request # 17 - Downloading Historical Daily chart data for GC#. Starting date: 2014-07-01. Service: ta | 2014-07-02 15:34:01 HD Request # 17 - Requesting historical Daily Continuous data for GCZ10 starting at 2014-06-30 | 2014-07-02 15:34:01 Socket (2284) - Shutdown and closed. | 2014-07-02 15:34:01 The network socket for historical data has been closed. | 2014-07-02 15:34:01 HD Request # 14 - Historical data for ZWU4 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-07-02 15:34:01 HD Request # 14 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ZWU4 | 2014-07-02 15:34:01 HD Request # 14 - Intraday download COMPLETE for ZWU4. Completion time: 0s | 2014-07-02 15:34:01 HD Request # 18 - Downloading Intraday chart data for YMU4 to the file YMU4.scid. Service: ta | 2014-07-02 15:34:01 HD Request # 18 - Download start Date-Time: 2014-07-02 15:25:16.0 | 2014-07-02 15:34:01 HD Request # 18 - Using server: ds5.sierracharts.com port 10149 | 2014-07-02 15:34:01 Socket (0) - Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-07-02 15:34:01 Socket (1568) - Connected. | 2014-07-02 15:34:01 HD Request # 18 - Sending historical data logon request message. | 2014-07-02 15:34:01 HD Request # 17 - Receiving historical Daily data for GC# starting at 2014-06-30 | 2014-07-02 15:34:01 Writing historical Daily data for GC# to the file GC#.dly | 2014-07-02 15:34:01 HD Request # 17 - Received 3 records from 2014-06-30 00:00:00 to 2014-07-02 00:00:00 (3.0 days) and wrote 2 records for GC# | 2014-07-02 15:34:01 HD Request # 17 - Daily download COMPLETE for GC#. Completion time: 0s | 2014-07-02 15:34:01 HD Request # 19 - Downloading Historical Daily chart data for NG#. Starting date: 2014-07-01. Service: ta | 2014-07-02 15:34:02 HD Request # 19 - Requesting historical Daily Continuous data for NGZ10 starting at 2014-06-30 | 2014-07-02 15:34:02 HD Request # 18 - Requesting Intraday data. Start Date-Time: 2014-07-02 15:25:16. Record interval: 0. Symbol: YMU4 | 2014-07-02 15:34:02 HD Request # 19 - Receiving historical Daily data for NG# starting at 2014-06-30 | 2014-07-02 15:34:02 Writing historical Daily data for NG# to the file NG#.dly | 2014-07-02 15:34:02 HD Request # 19 - Received 3 records from 2014-06-30 00:00:00 to 2014-07-02 00:00:00 (3.0 days) and wrote 2 records for NG# | 2014-07-02 15:34:02 HD Request # 19 - Daily download COMPLETE for NG#. Completion time: 0s | 2014-07-02 15:34:02 HD Request # 20 - Downloading Historical Daily chart data for RB#. Starting date: 2014-07-01. Service: ta | 2014-07-02 15:34:02 HD Request # 20 - Requesting historical Daily Continuous data for RBZ10 starting at 2014-06-30 | 2014-07-02 15:34:02 HD Request # 18 - Historical data for YMU4 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-07-02 15:34:02 Socket (1568) - Shutdown and closed. | 2014-07-02 15:34:02 The network socket for historical data has been closed. | 2014-07-02 15:34:02 HD Request # 18 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YMU4 | 2014-07-02 15:34:02 HD Request # 18 - Intraday download COMPLETE for YMU4. Completion time: 1s | 2014-07-02 15:34:02 HD Request # 21 - Downloading Intraday chart data for NQU4 to the file NQU4.scid. Service: ta | 2014-07-02 15:34:02 HD Request # 21 - Download start Date-Time: 2014-07-02 15:25:10.0 | 2014-07-02 15:34:02 HD Request # 21 - Using server: ds3.sierracharts.com port 10149 | 2014-07-02 15:34:02 Socket (0) - Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-07-02 15:34:02 HD Request # 20 - Receiving historical Daily data for RB# starting at 2014-06-30 | 2014-07-02 15:34:02 Writing historical Daily data for RB# to the file RB#.dly | 2014-07-02 15:34:02 HD Request # 20 - Received 3 records from 2014-06-30 00:00:00 to 2014-07-02 00:00:00 (3.0 days) and wrote 2 records for RB# | 2014-07-02 15:34:02 HD Request # 20 - Daily download COMPLETE for RB#. Completion time: 0s | 2014-07-02 15:34:02 HD Request # 22 - Downloading Historical Daily chart data for HO#. Starting date: 2014-07-01. Service: ta | 2014-07-02 15:34:02 HD Request # 22 - Requesting historical Daily Continuous data for HOZ10 starting at 2014-06-30 | 2014-07-02 15:34:02 Socket (2288) - Connected. | 2014-07-02 15:34:02 HD Request # 21 - Sending historical data logon request message. | 2014-07-02 15:34:02 HD Request # 22 - Receiving historical Daily data for HO# starting at 2014-06-30 | 2014-07-02 15:34:02 Writing historical Daily data for HO# to the file HO#.dly | 2014-07-02 15:34:02 HD Request # 22 - Received 3 records from 2014-06-30 00:00:00 to 2014-07-02 00:00:00 (3.0 days) and wrote 2 records for HO# | 2014-07-02 15:34:02 HD Request # 22 - Daily download COMPLETE for HO#. Completion time: 0s | 2014-07-02 15:34:02 HD Request # 21 - Requesting Intraday data. Start Date-Time: 2014-07-02 15:25:10. Record interval: 0. Symbol: NQU4 | 2014-07-02 15:34:03 HD Request # 23 - Downloading Historical Daily chart data for CL#. Starting date: 2014-07-01. Service: ta | 2014-07-02 15:34:03 HD Request # 23 - Requesting historical Daily Continuous data for CLZ10 starting at 2014-06-30 | 2014-07-02 15:34:03 HD Request # 21 - Historical data for NQU4 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-07-02 15:34:03 Socket (2288) - Shutdown and closed. | 2014-07-02 15:34:03 The network socket for historical data has been closed. | 2014-07-02 15:34:03 HD Request # 21 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQU4 | 2014-07-02 15:34:03 HD Request # 21 - Intraday download COMPLETE for NQU4. Completion time: 1s | 2014-07-02 15:34:03 HD Request # 24 - Downloading Intraday chart data for ESU4 to the file ESU4.scid. Service: ta | 2014-07-02 15:34:03 HD Request # 24 - Download start Date-Time: 2014-07-02 15:25:02.0 | 2014-07-02 15:34:03 HD Request # 24 - Using server: ds4.sierracharts.com port 10149 | 2014-07-02 15:34:03 Socket (0) - Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-07-02 15:34:03 Socket (1852) - Connected. | 2014-07-02 15:34:03 HD Request # 24 - Sending historical data logon request message. | 2014-07-02 15:34:03 HD Request # 23 - Receiving historical Daily data for CL# starting at 2014-06-30 | 2014-07-02 15:34:03 Writing historical Daily data for CL# to the file CL#.dly | 2014-07-02 15:34:03 HD Request # 23 - Received 3 records from 2014-06-30 00:00:00 to 2014-07-02 00:00:00 (3.0 days) and wrote 2 records for CL# | 2014-07-02 15:34:03 HD Request # 23 - Daily download COMPLETE for CL#. Completion time: 0s | 2014-07-02 15:34:03 HD Request # 24 - Requesting Intraday data. Start Date-Time: 2014-07-02 15:25:02. Record interval: 0. Symbol: ESU4 | 2014-07-02 15:34:03 Socket (1852) - Shutdown and closed. | 2014-07-02 15:34:03 The network socket for historical data has been closed. | 2014-07-02 15:34:03 HD Request # 24 - Historical data for ESU4 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-07-02 15:34:03 HD Request # 24 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU4 | 2014-07-02 15:34:03 HD Request # 24 - Intraday download COMPLETE for ESU4. Completion time: 0s | 2014-07-02 15:34:04 HD Request # 25 - Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2014-07-02 15:34:04 HD Request # 25 - Download start Date-Time: 2014-07-02 15:25:29.0 | 2014-07-02 15:34:04 HD Request # 25 - Using server: ds5.sierracharts.com port 10149 | 2014-07-02 15:34:04 Socket (0) - Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-07-02 15:34:04 Socket (2284) - Connected. | 2014-07-02 15:34:04 HD Request # 25 - Sending historical data logon request message. | 2014-07-02 15:34:04 HD Request # 25 - Requesting Intraday data. Start Date-Time: 2014-07-02 15:25:29. Record interval: 0. Symbol: TICK-NYSE | 2014-07-02 15:34:04 HD Request # 25 - Decompressing data. | 2014-07-02 15:34:04 HD Request # 25 - Receiving Intraday data for TICK-NYSE starting at 2014-07-02 15:25:29 | 2014-07-02 15:34:04 HD Request # 25 - Timestamp of first Intraday data file record written: 2014-07-02 15:25:30 | 2014-07-02 15:34:04 HD Request # 25 - Historical data for TICK-NYSE is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-07-02 15:34:05 Socket (2284) - Shutdown and closed. | 2014-07-02 15:34:05 The network socket for historical data has been closed. | 2014-07-02 15:34:05 HD Request # 25 - Received 513 records from 2014-07-02 15:25:29 to 2014-07-02 15:34:04 (8.6 minutes) and wrote 512 records for TICK-NYSE | 2014-07-02 15:34:05 HD Request # 25 - Intraday download COMPLETE for TICK-NYSE. Completion time: 1s | 2014-07-02 15:34:05 HD Request # 26 - Downloading Intraday chart data for TFU4 to the file TFU4.scid. Service: ta | 2014-07-02 15:34:05 HD Request # 26 - Download start Date-Time: 2014-07-02 15:25:15.0 | 2014-07-02 15:34:05 HD Request # 26 - Using server: ds3.sierracharts.com port 10149 | 2014-07-02 15:34:05 Socket (0) - Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-07-02 15:34:05 Socket (2100) - Connected. | 2014-07-02 15:34:05 HD Request # 26 - Sending historical data logon request message. | 2014-07-02 15:34:05 HD Request # 26 - Requesting Intraday data. Start Date-Time: 2014-07-02 15:25:15. Record interval: 0. Symbol: TFU4 | 2014-07-02 15:34:05 HD Request # 26 - Historical data for TFU4 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-07-02 15:34:05 Socket (2100) - Shutdown and closed. | 2014-07-02 15:34:05 The network socket for historical data has been closed. | 2014-07-02 15:34:05 HD Request # 26 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TFU4 | 2014-07-02 15:34:05 HD Request # 26 - Intraday download COMPLETE for TFU4. Completion time: 0s | 2014-07-02 15:34:05 HD Request # 27 - Downloading Intraday chart data for HGU4 to the file HGU4.scid. Service: ta | 2014-07-02 15:34:05 HD Request # 27 - Download start Date-Time: 2014-07-02 15:25:01.0 | 2014-07-02 15:34:05 HD Request # 27 - Using server: ds4.sierracharts.com port 10149 | 2014-07-02 15:34:05 Socket (0) - Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-07-02 15:34:05 Socket (2100) - Connected. | 2014-07-02 15:34:06 HD Request # 27 - Sending historical data logon request message. | 2014-07-02 15:34:06 HD Request # 27 - Requesting Intraday data. Start Date-Time: 2014-07-02 15:25:01. Record interval: 0. Symbol: HGU4 | 2014-07-02 15:34:06 HD Request # 27 - Historical data for HGU4 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-07-02 15:34:06 Socket (2100) - Shutdown and closed. | 2014-07-02 15:34:06 The network socket for historical data has been closed. | 2014-07-02 15:34:06 HD Request # 27 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for HGU4 | 2014-07-02 15:34:06 HD Request # 27 - Intraday download COMPLETE for HGU4. Completion time: 1s | 2014-07-02 15:34:06 HD Request # 28 - Downloading Intraday chart data for SIU4 to the file SIU4.scid. Service: ta | 2014-07-02 15:34:06 HD Request # 28 - Download start Date-Time: 2014-07-02 15:22:54.0 | 2014-07-02 15:34:06 HD Request # 28 - Using server: ds5.sierracharts.com port 10149 | 2014-07-02 15:34:06 Socket (0) - Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-07-02 15:34:06 Socket (2288) - Connected. | 2014-07-02 15:34:07 HD Request # 28 - Sending historical data logon request message. | 2014-07-02 15:34:07 HD Request # 28 - Requesting Intraday data. Start Date-Time: 2014-07-02 15:22:54. Record interval: 0. Symbol: SIU4 | 2014-07-02 15:34:07 HD Request # 28 - Historical data for SIU4 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-07-02 15:34:07 Socket (2288) - Shutdown and closed. | 2014-07-02 15:34:07 The network socket for historical data has been closed. | 2014-07-02 15:34:07 HD Request # 28 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for SIU4 | 2014-07-02 15:34:07 HD Request # 28 - Intraday download COMPLETE for SIU4. Completion time: 0s | 2014-07-02 15:34:07 HD Request # 29 - Downloading Intraday chart data for GCQ4 to the file GCQ4.scid. Service: ta | 2014-07-02 15:34:07 HD Request # 29 - Download start Date-Time: 2014-07-02 15:25:04.0 | 2014-07-02 15:34:07 HD Request # 29 - Using server: ds3.sierracharts.com port 10149 | 2014-07-02 15:34:07 Socket (0) - Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-07-02 15:34:07 Socket (2288) - Connected. | 2014-07-02 15:34:08 HD Request # 29 - Sending historical data logon request message. | 2014-07-02 15:34:08 HD Request # 29 - Requesting Intraday data. Start Date-Time: 2014-07-02 15:25:04. Record interval: 0. Symbol: GCQ4 | 2014-07-02 15:34:08 Socket (2288) - Shutdown and closed. | 2014-07-02 15:34:08 The network socket for historical data has been closed. | 2014-07-02 15:34:08 HD Request # 29 - Historical data for GCQ4 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-07-02 15:34:08 HD Request # 29 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GCQ4 | 2014-07-02 15:34:08 HD Request # 29 - Intraday download COMPLETE for GCQ4. Completion time: 1s | 2014-07-02 15:34:08 HD Request # 30 - Downloading Intraday chart data for PLV4 to the file PLV4.scid. Service: ta | 2014-07-02 15:34:08 HD Request # 30 - Download start Date-Time: 2014-07-02 15:23:19.0 | 2014-07-02 15:34:08 HD Request # 30 - Using server: ds4.sierracharts.com port 10149 | 2014-07-02 15:34:08 Socket (0) - Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-07-02 15:34:08 Socket (1568) - Connected. | 2014-07-02 15:34:09 HD Request # 30 - Sending historical data logon request message. | 2014-07-02 15:34:09 HD Request # 30 - Requesting Intraday data. Start Date-Time: 2014-07-02 15:23:19. Record interval: 0. Symbol: PLV4 | 2014-07-02 15:34:09 HD Request # 30 - Historical data for PLV4 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-07-02 15:34:09 Socket (1568) - Shutdown and closed. | 2014-07-02 15:34:09 The network socket for historical data has been closed. | 2014-07-02 15:34:09 HD Request # 30 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for PLV4 | 2014-07-02 15:34:09 HD Request # 30 - Intraday download COMPLETE for PLV4. Completion time: 0s | 2014-07-02 15:34:09 HD Request # 31 - Downloading Intraday chart data for NGQ4 to the file NGQ4.scid. Service: ta | 2014-07-02 15:34:09 HD Request # 31 - Download start Date-Time: 2014-07-02 15:24:51.0 | 2014-07-02 15:34:09 HD Request # 31 - Using server: ds5.sierracharts.com port 10149 | 2014-07-02 15:34:09 Socket (0) - Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-07-02 15:34:09 Socket (1568) - Connected. | 2014-07-02 15:34:09 HD Request # 31 - Sending historical data logon request message. | 2014-07-02 15:34:09 HD Request # 31 - Requesting Intraday data. Start Date-Time: 2014-07-02 15:24:51. Record interval: 0. Symbol: NGQ4 | 2014-07-02 15:34:10 TransAct Trading Server Info - Server Name: TransactToSierraBridge. Server Version: 1.2.3.0. Provider Name: Transact Futures. | 2014-07-02 15:34:10 TransAct Trading - Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-07-02 15:34:10 TransAct Trading - Successfully connected. Operation Successful. | 2014-07-02 15:34:10 Chart: CLQ4 [R] 2 Min #17 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:10 Chart: CLQ4 [R] 2 Min #17 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:10 Chart: CLQ4 [R] 2 Min #17 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:10 Chart: HOQ4 [R] 2 Min #18 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:10 Chart: HOQ4 [R] 2 Min #18 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:10 Chart: HOQ4 [R] 2 Min #18 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:10 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:10 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:10 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:10 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:10 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:10 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:10 TransAct Trading - Starting real-time market data updates for: TFU4. ID: 1 | 2014-07-02 15:34:10 TransAct Trading - Starting real-time market data updates for: NGQ4. ID: 2 | 2014-07-02 15:34:10 TransAct Trading - Starting real-time market data updates for: ESU4. ID: 3 | 2014-07-02 15:34:10 TransAct Trading - Starting real-time market data updates for: RBQ4. ID: 4 | 2014-07-02 15:34:10 TransAct Trading - Starting real-time market data updates for: CLQ4. ID: 5 | 2014-07-02 15:34:10 TransAct Trading - Starting real-time market data updates for: HOQ4. ID: 6 | 2014-07-02 15:34:10 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:10 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:10 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:10 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:10 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:10 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:10 TransAct Trading - Starting real-time market data updates for: FDAXU4. ID: 7 | 2014-07-02 15:34:10 TransAct Trading - Starting real-time market data updates for: ZWU4. ID: 8 | 2014-07-02 15:34:10 TransAct Trading - Starting real-time market data updates for: ZSX4. ID: 9 | 2014-07-02 15:34:10 TransAct Trading - Starting real-time market data updates for: ZCU4. ID: 10 | 2014-07-02 15:34:10 TransAct Trading - Starting real-time market data updates for: YMU4. ID: 11 | 2014-07-02 15:34:10 TransAct Trading - Starting real-time market data updates for: NQU4. ID: 12 | 2014-07-02 15:34:10 TransAct Trading - Starting real-time market data updates for: HGU4. ID: 13 | 2014-07-02 15:34:10 TransAct Trading - Starting real-time market data updates for: PLV4. ID: 14 | 2014-07-02 15:34:10 TransAct Trading - Starting real-time market data updates for: SIU4. ID: 15 | 2014-07-02 15:34:10 TransAct Trading - Starting real-time market data updates for: GCQ4. ID: 16 | 2014-07-02 15:34:10 Historical data request is discarded because it is not for earlier data. | 2014-07-02 15:34:10 SC Market Stats - Starting real-time market data updates for: TICK-NYSE. ID: 17 | 2014-07-02 15:34:10 SC Market Stats: Connecting to the server ds3.sierracharts.com. Port 443 | 2014-07-02 15:34:10 Socket (0) - Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-07-02 15:34:10 Socket (1568) - Shutdown and closed. | 2014-07-02 15:34:10 HD Request # 31 - Re-requesting historical data for NGQ4 to get the latest data since the download was started while not connected to primary service. | 2014-07-02 15:34:10 The network socket for historical data has been closed. | 2014-07-02 15:34:10 HD Request # 31 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NGQ4 | 2014-07-02 15:34:10 Socket (1148) - Connected. | 2014-07-02 15:34:10 SC Market Stats: Connected to server. | 2014-07-02 15:34:10 SC Market Stats: Sending logon request message. | 2014-07-02 15:34:10 HD Request # 32 - Downloading Intraday chart data for NGQ4 to the file NGQ4.scid. Service: ta | 2014-07-02 15:34:10 HD Request # 32 - Download start Date-Time: 2014-07-02 15:24:51.0 | 2014-07-02 15:34:10 HD Request # 32 - Using server: ds4.sierracharts.com port 10149 | 2014-07-02 15:34:10 Socket (0) - Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-07-02 15:34:10 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:10 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:10 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:10 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:10 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:10 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:10 Socket (1568) - Connected. | 2014-07-02 15:34:10 HD Request # 32 - Sending historical data logon request message. | 2014-07-02 15:34:10 HD Request # 32 - Requesting Intraday data. Start Date-Time: 2014-07-02 15:24:51. Record interval: 0. Symbol: NGQ4 | 2014-07-02 15:34:11 HD Request # 32 - Decompressing data. | 2014-07-02 15:34:11 HD Request # 32 - Receiving Intraday data for NGQ4 starting at 2014-07-02 15:24:51 | 2014-07-02 15:34:11 SC Market Stats Server Info - Server Name: . Server Version: . Provider Name: . | 2014-07-02 15:34:11 HD Request # 32 - Timestamp of first Intraday data file record written: 2014-07-02 15:25:15 | 2014-07-02 15:34:11 SC Market Stats - Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-07-02 15:34:11 Socket (1568) - Shutdown and closed. | 2014-07-02 15:34:11 The network socket for historical data has been closed. | 2014-07-02 15:34:11 SC Market Stats - Successfully connected. | 2014-07-02 15:34:11 SC Market Stats - Restarting real-time data updates for symbol: TICK-NYSE | 2014-07-02 15:34:11 HD Request # 32 - Received 93 records from 2014-07-02 15:24:51 to 2014-07-02 15:34:06 (9.2 minutes) and wrote 92 records for NGQ4 | 2014-07-02 15:34:11 HD Request # 32 - Intraday download COMPLETE for NGQ4. Completion time: 1s | 2014-07-02 15:34:11 Real-time Intraday chart data file updates started for NGQ4 | 2014-07-02 15:34:11 HD Request # 33 - Downloading Intraday chart data for HOQ4 to the file HOQ4.scid. Service: ta | 2014-07-02 15:34:11 HD Request # 33 - Download start Date-Time: 2014-07-02 15:24:59.0 | 2014-07-02 15:34:11 HD Request # 33 - Using server: ds5.sierracharts.com port 10149 | 2014-07-02 15:34:11 Socket (0) - Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-07-02 15:34:11 Socket (1124) - Connected. | 2014-07-02 15:34:11 HD Request # 33 - Sending historical data logon request message. | 2014-07-02 15:34:11 HD Request # 33 - Requesting Intraday data. Start Date-Time: 2014-07-02 15:24:59. Record interval: 0. Symbol: HOQ4 | 2014-07-02 15:34:11 HD Request # 33 - Decompressing data. | 2014-07-02 15:34:12 HD Request # 33 - Receiving Intraday data for HOQ4 starting at 2014-07-02 15:24:59 | 2014-07-02 15:34:12 HD Request # 33 - Timestamp of first Intraday data file record written: 2014-07-02 15:25:26 | 2014-07-02 15:34:12 Socket (1124) - Shutdown and closed. | 2014-07-02 15:34:12 The network socket for historical data has been closed. | 2014-07-02 15:34:12 HD Request # 33 - Received 82 records from 2014-07-02 15:24:59 to 2014-07-02 15:34:09 (9.2 minutes) and wrote 81 records for HOQ4 | 2014-07-02 15:34:12 HD Request # 33 - Intraday download COMPLETE for HOQ4. Completion time: 0s | 2014-07-02 15:34:12 Real-time Intraday chart data file updates started for HOQ4 | 2014-07-02 15:34:12 HD Request # 34 - Downloading Intraday chart data for CLQ4 to the file CLQ4.scid. Service: ta | 2014-07-02 15:34:12 HD Request # 34 - Download start Date-Time: 2014-07-02 15:24:56.0 | 2014-07-02 15:34:12 HD Request # 34 - Using server: ds3.sierracharts.com port 10149 | 2014-07-02 15:34:12 Socket (0) - Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-07-02 15:34:12 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:12 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:12 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:12 Chart: HOQ4 [R] 2 Min #18 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:12 Chart: HOQ4 [R] 2 Min #18 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:12 Chart: HOQ4 [R] 2 Min #18 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:12 Socket (1140) - Connected. | 2014-07-02 15:34:12 HD Request # 34 - Sending historical data logon request message. | 2014-07-02 15:34:12 HD Request # 34 - Requesting Intraday data. Start Date-Time: 2014-07-02 15:24:56. Record interval: 0. Symbol: CLQ4 | 2014-07-02 15:34:12 HD Request # 34 - Decompressing data. | 2014-07-02 15:34:13 HD Request # 34 - Receiving Intraday data for CLQ4 starting at 2014-07-02 15:24:56 | 2014-07-02 15:34:13 HD Request # 34 - Timestamp of first Intraday data file record written: 2014-07-02 15:25:20 | 2014-07-02 15:34:13 Socket (1140) - Shutdown and closed. | 2014-07-02 15:34:13 The network socket for historical data has been closed. | 2014-07-02 15:34:13 HD Request # 34 - Received 337 records from 2014-07-02 15:24:56 to 2014-07-02 15:34:03 (9.1 minutes) and wrote 332 records for CLQ4 | 2014-07-02 15:34:13 HD Request # 34 - Intraday download COMPLETE for CLQ4. Completion time: 1s | 2014-07-02 15:34:13 Real-time Intraday chart data file updates started for CLQ4 | 2014-07-02 15:34:13 HD Request # 35 - Downloading Intraday chart data for RBQ4 to the file RBQ4.scid. Service: ta | 2014-07-02 15:34:13 HD Request # 35 - Download start Date-Time: 2014-07-02 15:24:56.0 | 2014-07-02 15:34:13 HD Request # 35 - Using server: ds4.sierracharts.com port 10149 | 2014-07-02 15:34:13 Socket (0) - Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-07-02 15:34:13 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:13 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:13 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:13 Chart: CLQ4 [R] 2 Min #17 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:13 Chart: CLQ4 [R] 2 Min #17 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:13 Chart: CLQ4 [R] 2 Min #17 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:13 Socket (1140) - Connected. | 2014-07-02 15:34:13 HD Request # 35 - Sending historical data logon request message. | 2014-07-02 15:34:13 HD Request # 35 - Requesting Intraday data. Start Date-Time: 2014-07-02 15:24:56. Record interval: 0. Symbol: RBQ4 | 2014-07-02 15:34:13 HD Request # 35 - Decompressing data. | 2014-07-02 15:34:13 HD Request # 35 - Receiving Intraday data for RBQ4 starting at 2014-07-02 15:24:56 | 2014-07-02 15:34:13 HD Request # 35 - Timestamp of first Intraday data file record written: 2014-07-02 15:25:30 | 2014-07-02 15:34:13 Socket (1140) - Shutdown and closed. | 2014-07-02 15:34:13 The network socket for historical data has been closed. | 2014-07-02 15:34:13 HD Request # 35 - Received 33 records from 2014-07-02 15:24:56 to 2014-07-02 15:33:13 (8.3 minutes) and wrote 32 records for RBQ4 | 2014-07-02 15:34:13 HD Request # 35 - Intraday download COMPLETE for RBQ4. Completion time: 0s | 2014-07-02 15:34:13 Real-time Intraday chart data file updates started for RBQ4 | 2014-07-02 15:34:13 HD Request # 36 - Downloading Intraday chart data for FDAXU4 to the file FDAXU4.scid. Service: ta | 2014-07-02 15:34:13 HD Request # 36 - Download start Date-Time: 2014-07-02 15:25:01.0 | 2014-07-02 15:34:13 HD Request # 36 - Using server: ds5.sierracharts.com port 10149 | 2014-07-02 15:34:13 Socket (0) - Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-07-02 15:34:13 Socket (1140) - Connected. | 2014-07-02 15:34:14 HD Request # 36 - Sending historical data logon request message. | 2014-07-02 15:34:14 HD Request # 36 - Requesting Intraday data. Start Date-Time: 2014-07-02 15:25:01. Record interval: 0. Symbol: FDAXU4 | 2014-07-02 15:34:14 HD Request # 36 - Decompressing data. | 2014-07-02 15:34:14 HD Request # 36 - Receiving Intraday data for FDAXU4 starting at 2014-07-02 15:25:01 | 2014-07-02 15:34:14 HD Request # 36 - Timestamp of first Intraday data file record written: 2014-07-02 15:25:12 | 2014-07-02 15:34:14 Socket (1140) - Shutdown and closed. | 2014-07-02 15:34:14 The network socket for historical data has been closed. | 2014-07-02 15:34:14 HD Request # 36 - Received 59 records from 2014-07-02 15:25:01 to 2014-07-02 15:33:56 (8.9 minutes) and wrote 51 records for FDAXU4 | 2014-07-02 15:34:14 HD Request # 36 - Intraday download COMPLETE for FDAXU4. Completion time: 1s | 2014-07-02 15:34:14 Real-time Intraday chart data file updates started for FDAXU4 | 2014-07-02 15:34:14 HD Request # 37 - Downloading Intraday chart data for ZWU4 to the file ZWU4.scid. Service: ta | 2014-07-02 15:34:14 HD Request # 37 - Download start Date-Time: 2014-07-02 14:14:59.0 | 2014-07-02 15:34:14 HD Request # 37 - Using server: ds3.sierracharts.com port 10149 | 2014-07-02 15:34:14 Socket (0) - Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-07-02 15:34:14 Socket (2288) - Connected. | 2014-07-02 15:34:14 HD Request # 37 - Sending historical data logon request message. | 2014-07-02 15:34:14 HD Request # 37 - Requesting Intraday data. Start Date-Time: 2014-07-02 14:14:59. Record interval: 0. Symbol: ZWU4 | 2014-07-02 15:34:15 TransAct Trading: Requesting Trade Positions data. | 2014-07-02 15:34:15 Requesting market depth updates for: CLQ4 if supported. | 2014-07-02 15:34:15 Requesting market depth updates for: ESU4 if supported. | 2014-07-02 15:34:15 Requesting market depth updates for: FDAXU4 if supported. | 2014-07-02 15:34:15 Requesting market depth updates for: GCQ4 if supported. | 2014-07-02 15:34:15 Requesting market depth updates for: HGU4 if supported. | 2014-07-02 15:34:15 Requesting market depth updates for: HOQ4 if supported. | 2014-07-02 15:34:15 Requesting market depth updates for: NGQ4 if supported. | 2014-07-02 15:34:15 Requesting market depth updates for: NQU4 if supported. | 2014-07-02 15:34:15 Requesting market depth updates for: PLV4 if supported. | 2014-07-02 15:34:15 Requesting market depth updates for: RBQ4 if supported. | 2014-07-02 15:34:15 Requesting market depth updates for: SIU4 if supported. | 2014-07-02 15:34:15 Requesting market depth updates for: TFU4 if supported. | 2014-07-02 15:34:15 Requesting market depth updates for: YMU4 if supported. | 2014-07-02 15:34:15 Requesting market depth updates for: ZCU4 if supported. | 2014-07-02 15:34:15 Requesting market depth updates for: ZSX4 if supported. | 2014-07-02 15:34:15 Requesting market depth updates for: ZWU4 if supported. | 2014-07-02 15:34:15 HD Request # 37 - Decompressing data. | 2014-07-02 15:34:15 HD Request # 37 - Receiving Intraday data for ZWU4 starting at 2014-07-02 14:14:59 | 2014-07-02 15:34:15 Socket (2288) - Shutdown and closed. | 2014-07-02 15:34:15 The network socket for historical data has been closed. | 2014-07-02 15:34:15 HD Request # 37 - Received 36 records from 2014-07-02 14:14:59 to 2014-07-02 14:14:59 (0.0 seconds) and wrote 0 records for ZWU4 | 2014-07-02 15:34:15 HD Request # 37 - Intraday download COMPLETE for ZWU4. Completion time: 0s | 2014-07-02 15:34:15 Real-time Intraday chart data file updates started for ZWU4 | 2014-07-02 15:34:15 HD Request # 38 - Downloading Intraday chart data for ZSX4 to the file ZSX4.scid. Service: ta | 2014-07-02 15:34:15 HD Request # 38 - Download start Date-Time: 2014-07-02 14:14:59.0 | 2014-07-02 15:34:15 HD Request # 38 - Using server: ds4.sierracharts.com port 10149 | 2014-07-02 15:34:15 Socket (0) - Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-07-02 15:34:15 Socket (1156) - Connected. | 2014-07-02 15:34:15 HD Request # 38 - Sending historical data logon request message. | 2014-07-02 15:34:15 HD Request # 38 - Requesting Intraday data. Start Date-Time: 2014-07-02 14:14:59. Record interval: 0. Symbol: ZSX4 | 2014-07-02 15:34:16 HD Request # 38 - Decompressing data. | 2014-07-02 15:34:16 HD Request # 38 - Receiving Intraday data for ZSX4 starting at 2014-07-02 14:14:59 | 2014-07-02 15:34:16 Socket (1156) - Shutdown and closed. | 2014-07-02 15:34:16 The network socket for historical data has been closed. | 2014-07-02 15:34:16 HD Request # 38 - Received 4 records from 2014-07-02 14:14:59 to 2014-07-02 14:14:59 (0.0 seconds) and wrote 0 records for ZSX4 | 2014-07-02 15:34:16 HD Request # 38 - Intraday download COMPLETE for ZSX4. Completion time: 1s | 2014-07-02 15:34:16 Real-time Intraday chart data file updates started for ZSX4 | 2014-07-02 15:34:16 HD Request # 39 - Downloading Intraday chart data for ZCU4 to the file ZCU4.scid. Service: ta | 2014-07-02 15:34:16 HD Request # 39 - Download start Date-Time: 2014-07-02 14:14:59.0 | 2014-07-02 15:34:16 HD Request # 39 - Using server: ds5.sierracharts.com port 10149 | 2014-07-02 15:34:16 Socket (0) - Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-07-02 15:34:16 Socket (1124) - Connected. | 2014-07-02 15:34:16 HD Request # 39 - Sending historical data logon request message. | 2014-07-02 15:34:16 HD Request # 39 - Requesting Intraday data. Start Date-Time: 2014-07-02 14:14:59. Record interval: 0. Symbol: ZCU4 | 2014-07-02 15:34:16 HD Request # 39 - Decompressing data. | 2014-07-02 15:34:17 HD Request # 39 - Receiving Intraday data for ZCU4 starting at 2014-07-02 14:14:59 | 2014-07-02 15:34:17 Socket (1124) - Shutdown and closed. | 2014-07-02 15:34:17 The network socket for historical data has been closed. | 2014-07-02 15:34:17 HD Request # 39 - Received 19 records from 2014-07-02 14:14:59 to 2014-07-02 14:14:59 (0.0 seconds) and wrote 0 records for ZCU4 | 2014-07-02 15:34:17 HD Request # 39 - Intraday download COMPLETE for ZCU4. Completion time: 0s | 2014-07-02 15:34:17 Real-time Intraday chart data file updates started for ZCU4 | 2014-07-02 15:34:17 HD Request # 40 - Downloading Intraday chart data for TFU4 to the file TFU4.scid. Service: ta | 2014-07-02 15:34:17 HD Request # 40 - Download start Date-Time: 2014-07-02 15:25:15.0 | 2014-07-02 15:34:17 HD Request # 40 - Using server: ds3.sierracharts.com port 10149 | 2014-07-02 15:34:17 Socket (0) - Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-07-02 15:34:17 Socket (1124) - Connected. | 2014-07-02 15:34:17 HD Request # 40 - Sending historical data logon request message. | 2014-07-02 15:34:17 HD Request # 40 - Requesting Intraday data. Start Date-Time: 2014-07-02 15:25:15. Record interval: 0. Symbol: TFU4 | 2014-07-02 15:34:17 HD Request # 40 - Decompressing data. | 2014-07-02 15:34:17 HD Request # 40 - Receiving Intraday data for TFU4 starting at 2014-07-02 15:25:15 | 2014-07-02 15:34:17 HD Request # 40 - Timestamp of first Intraday data file record written: 2014-07-02 15:25:15 | 2014-07-02 15:34:17 Socket (1124) - Shutdown and closed. | 2014-07-02 15:34:17 The network socket for historical data has been closed. | 2014-07-02 15:34:17 HD Request # 40 - Received 1691 records from 2014-07-02 15:25:15 to 2014-07-02 15:34:13 (9.0 minutes) and wrote 1674 records for TFU4 | 2014-07-02 15:34:17 HD Request # 40 - Intraday download COMPLETE for TFU4. Completion time: 0s | 2014-07-02 15:34:17 Real-time Intraday chart data file updates started for TFU4 | 2014-07-02 15:34:17 HD Request # 41 - Downloading Intraday chart data for YMU4 to the file YMU4.scid. Service: ta | 2014-07-02 15:34:17 HD Request # 41 - Download start Date-Time: 2014-07-02 15:25:16.0 | 2014-07-02 15:34:17 HD Request # 41 - Using server: ds4.sierracharts.com port 10149 | 2014-07-02 15:34:17 Socket (0) - Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-07-02 15:34:17 Socket (1124) - Connected. | 2014-07-02 15:34:18 HD Request # 41 - Sending historical data logon request message. | 2014-07-02 15:34:18 HD Request # 41 - Requesting Intraday data. Start Date-Time: 2014-07-02 15:25:16. Record interval: 0. Symbol: YMU4 | 2014-07-02 15:34:18 HD Request # 41 - Decompressing data. | 2014-07-02 15:34:18 HD Request # 41 - Receiving Intraday data for YMU4 starting at 2014-07-02 15:25:16 | 2014-07-02 15:34:18 HD Request # 41 - Timestamp of first Intraday data file record written: 2014-07-02 15:25:19 | 2014-07-02 15:34:18 Socket (1124) - Shutdown and closed. | 2014-07-02 15:34:18 The network socket for historical data has been closed. | 2014-07-02 15:34:18 HD Request # 41 - Received 402 records from 2014-07-02 15:25:16 to 2014-07-02 15:34:05 (8.8 minutes) and wrote 397 records for YMU4 | 2014-07-02 15:34:18 HD Request # 41 - Intraday download COMPLETE for YMU4. Completion time: 1s | 2014-07-02 15:34:18 Real-time Intraday chart data file updates started for YMU4 | 2014-07-02 15:34:18 HD Request # 42 - Downloading Intraday chart data for NQU4 to the file NQU4.scid. Service: ta | 2014-07-02 15:34:18 HD Request # 42 - Download start Date-Time: 2014-07-02 15:25:10.0 | 2014-07-02 15:34:18 HD Request # 42 - Using server: ds5.sierracharts.com port 10149 | 2014-07-02 15:34:18 Socket (0) - Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-07-02 15:34:18 Socket (1124) - Connected. | 2014-07-02 15:34:18 HD Request # 42 - Sending historical data logon request message. | 2014-07-02 15:34:18 HD Request # 42 - Requesting Intraday data. Start Date-Time: 2014-07-02 15:25:10. Record interval: 0. Symbol: NQU4 | 2014-07-02 15:34:19 HD Request # 42 - Decompressing data. | 2014-07-02 15:34:19 HD Request # 42 - Receiving Intraday data for NQU4 starting at 2014-07-02 15:25:10 | 2014-07-02 15:34:19 HD Request # 42 - Timestamp of first Intraday data file record written: 2014-07-02 15:25:11 | 2014-07-02 15:34:19 Socket (1124) - Shutdown and closed. | 2014-07-02 15:34:19 The network socket for historical data has been closed. | 2014-07-02 15:34:19 HD Request # 42 - Received 943 records from 2014-07-02 15:25:10 to 2014-07-02 15:34:13 (9.1 minutes) and wrote 937 records for NQU4 | 2014-07-02 15:34:19 HD Request # 42 - Intraday download COMPLETE for NQU4. Completion time: 1s | 2014-07-02 15:34:19 Real-time Intraday chart data file updates started for NQU4 | 2014-07-02 15:34:19 HD Request # 43 - Downloading Intraday chart data for ESU4 to the file ESU4.scid. Service: ta | 2014-07-02 15:34:19 HD Request # 43 - Download start Date-Time: 2014-07-02 15:25:02.0 | 2014-07-02 15:34:19 HD Request # 43 - Using server: ds3.sierracharts.com port 10149 | 2014-07-02 15:34:19 Socket (0) - Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-07-02 15:34:19 Socket (1124) - Connected. | 2014-07-02 15:34:19 HD Request # 43 - Sending historical data logon request message. | 2014-07-02 15:34:19 HD Request # 43 - Requesting Intraday data. Start Date-Time: 2014-07-02 15:25:02. Record interval: 0. Symbol: ESU4 | 2014-07-02 15:34:19 HD Request # 43 - Decompressing data. | 2014-07-02 15:34:20 HD Request # 43 - Receiving Intraday data for ESU4 starting at 2014-07-02 15:25:02 | 2014-07-02 15:34:20 HD Request # 43 - Timestamp of first Intraday data file record written: 2014-07-02 15:25:04 | 2014-07-02 15:34:20 Socket (1124) - Shutdown and closed. | 2014-07-02 15:34:20 The network socket for historical data has been closed. | 2014-07-02 15:34:20 HD Request # 43 - Received 2376 records from 2014-07-02 15:25:02 to 2014-07-02 15:34:11 (9.2 minutes) and wrote 2319 records for ESU4 | 2014-07-02 15:34:20 HD Request # 43 - Intraday download COMPLETE for ESU4. Completion time: 0s | 2014-07-02 15:34:20 Real-time Intraday chart data file updates started for ESU4 | 2014-07-02 15:34:20 HD Request # 44 - Downloading Intraday chart data for HGU4 to the file HGU4.scid. Service: ta | 2014-07-02 15:34:20 HD Request # 44 - Download start Date-Time: 2014-07-02 15:25:01.0 | 2014-07-02 15:34:20 HD Request # 44 - Using server: ds4.sierracharts.com port 10149 | 2014-07-02 15:34:20 Socket (0) - Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-07-02 15:34:20 Socket (1124) - Connected. | 2014-07-02 15:34:20 HD Request # 44 - Sending historical data logon request message. | 2014-07-02 15:34:20 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3890.000000, Time Difference = 4 seconds, Percentage = 300.119853% | 2014-07-02 15:34:20 HD Request # 44 - Requesting Intraday data. Start Date-Time: 2014-07-02 15:25:01. Record interval: 0. Symbol: HGU4 | 2014-07-02 15:34:20 HD Request # 44 - Decompressing data. | 2014-07-02 15:34:21 HD Request # 44 - Receiving Intraday data for HGU4 starting at 2014-07-02 15:25:01 | 2014-07-02 15:34:21 HD Request # 44 - Timestamp of first Intraday data file record written: 2014-07-02 15:25:08 | 2014-07-02 15:34:21 Socket (1124) - Shutdown and closed. | 2014-07-02 15:34:21 The network socket for historical data has been closed. | 2014-07-02 15:34:21 HD Request # 44 - Received 54 records from 2014-07-02 15:25:01 to 2014-07-02 15:34:16 (9.3 minutes) and wrote 53 records for HGU4 | 2014-07-02 15:34:21 HD Request # 44 - Intraday download COMPLETE for HGU4. Completion time: 1s | 2014-07-02 15:34:21 Real-time Intraday chart data file updates started for HGU4 | 2014-07-02 15:34:21 HD Request # 45 - Downloading Intraday chart data for PLV4 to the file PLV4.scid. Service: ta | 2014-07-02 15:34:21 HD Request # 45 - Download start Date-Time: 2014-07-02 15:23:19.0 | 2014-07-02 15:34:21 HD Request # 45 - Using server: ds5.sierracharts.com port 10149 | 2014-07-02 15:34:21 Socket (0) - Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-07-02 15:34:21 Socket (1124) - Connected. | 2014-07-02 15:34:21 HD Request # 45 - Sending historical data logon request message. | 2014-07-02 15:34:21 HD Request # 45 - Requesting Intraday data. Start Date-Time: 2014-07-02 15:23:19. Record interval: 0. Symbol: PLV4 | 2014-07-02 15:34:21 HD Request # 45 - Decompressing data. | 2014-07-02 15:34:21 HD Request # 45 - Receiving Intraday data for PLV4 starting at 2014-07-02 15:23:19 | 2014-07-02 15:34:21 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.900024, Time Difference = 5 seconds, Percentage = 300.149846% | 2014-07-02 15:34:21 HD Request # 45 - Timestamp of first Intraday data file record written: 2014-07-02 15:25:20 | 2014-07-02 15:34:21 Socket (1124) - Shutdown and closed. | 2014-07-02 15:34:21 The network socket for historical data has been closed. | 2014-07-02 15:34:21 HD Request # 45 - Received 4 records from 2014-07-02 15:23:19 to 2014-07-02 15:29:28 (6.2 minutes) and wrote 3 records for PLV4 | 2014-07-02 15:34:21 HD Request # 45 - Intraday download COMPLETE for PLV4. Completion time: 0s | 2014-07-02 15:34:21 Real-time Intraday chart data file updates started for PLV4 | 2014-07-02 15:34:21 HD Request # 46 - Downloading Intraday chart data for SIU4 to the file SIU4.scid. Service: ta | 2014-07-02 15:34:21 HD Request # 46 - Download start Date-Time: 2014-07-02 15:22:54.0 | 2014-07-02 15:34:21 HD Request # 46 - Using server: ds3.sierracharts.com port 10149 | 2014-07-02 15:34:21 Socket (0) - Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-07-02 15:34:21 Socket (1124) - Connected. | 2014-07-02 15:34:21 HD Request # 46 - Sending historical data logon request message. | 2014-07-02 15:34:21 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.900024, Time Difference = 5 seconds, Percentage = 300.149846% | 2014-07-02 15:34:21 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 5 seconds, Percentage = 300.149846% | 2014-07-02 15:34:21 HD Request # 46 - Requesting Intraday data. Start Date-Time: 2014-07-02 15:22:54. Record interval: 0. Symbol: SIU4 | 2014-07-02 15:34:22 HD Request # 46 - Decompressing data. | 2014-07-02 15:34:22 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.900024, Time Difference = 6 seconds, Percentage = 300.179839% | 2014-07-02 15:34:22 HD Request # 46 - Receiving Intraday data for SIU4 starting at 2014-07-02 15:22:54 | 2014-07-02 15:34:22 HD Request # 46 - Timestamp of first Intraday data file record written: 2014-07-02 15:26:07 | 2014-07-02 15:34:22 Socket (1124) - Shutdown and closed. | 2014-07-02 15:34:22 The network socket for historical data has been closed. | 2014-07-02 15:34:22 HD Request # 46 - Received 58 records from 2014-07-02 15:22:54 to 2014-07-02 15:34:19 (11.4 minutes) and wrote 54 records for SIU4 | 2014-07-02 15:34:22 HD Request # 46 - Intraday download COMPLETE for SIU4. Completion time: 1s | 2014-07-02 15:34:22 Real-time Intraday chart data file updates started for SIU4 | 2014-07-02 15:34:22 HD Request # 47 - Downloading Intraday chart data for GCQ4 to the file GCQ4.scid. Service: ta | 2014-07-02 15:34:22 HD Request # 47 - Download start Date-Time: 2014-07-02 15:25:04.0 | 2014-07-02 15:34:22 HD Request # 47 - Using server: ds4.sierracharts.com port 10149 | 2014-07-02 15:34:22 Socket (0) - Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-07-02 15:34:22 Socket (1124) - Connected. | 2014-07-02 15:34:22 HD Request # 47 - Sending historical data logon request message. | 2014-07-02 15:34:22 HD Request # 47 - Requesting Intraday data. Start Date-Time: 2014-07-02 15:25:04. Record interval: 0. Symbol: GCQ4 | 2014-07-02 15:34:22 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.900024, Time Difference = 6 seconds, Percentage = 300.179839% | 2014-07-02 15:34:22 HD Request # 47 - Decompressing data. | 2014-07-02 15:34:23 HD Request # 47 - Receiving Intraday data for GCQ4 starting at 2014-07-02 15:25:04 | 2014-07-02 15:34:23 HD Request # 47 - Timestamp of first Intraday data file record written: 2014-07-02 15:25:15 | 2014-07-02 15:34:23 Socket (1124) - Shutdown and closed. | 2014-07-02 15:34:23 The network socket for historical data has been closed. | 2014-07-02 15:34:23 HD Request # 47 - Received 277 records from 2014-07-02 15:25:04 to 2014-07-02 15:34:19 (9.3 minutes) and wrote 276 records for GCQ4 | 2014-07-02 15:34:23 HD Request # 47 - Intraday download COMPLETE for GCQ4. Completion time: 0s | 2014-07-02 15:34:23 Real-time Intraday chart data file updates started for GCQ4 | 2014-07-02 15:34:23 HD Request # 48 - Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2014-07-02 15:34:23 HD Request # 48 - Download start Date-Time: 2014-07-02 15:34:04.0 | 2014-07-02 15:34:23 HD Request # 48 - Using server: ds5.sierracharts.com port 10149 | 2014-07-02 15:34:23 Socket (0) - Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-07-02 15:34:23 Socket (1124) - Connected. | 2014-07-02 15:34:23 HD Request # 48 - Sending historical data logon request message. | 2014-07-02 15:34:23 HD Request # 48 - Requesting Intraday data. Start Date-Time: 2014-07-02 15:34:04. Record interval: 0. Symbol: TICK-NYSE | 2014-07-02 15:34:23 HD Request # 48 - Decompressing data. | 2014-07-02 15:34:24 HD Request # 48 - Receiving Intraday data for TICK-NYSE starting at 2014-07-02 15:34:04 | 2014-07-02 15:34:24 HD Request # 48 - Timestamp of first Intraday data file record written: 2014-07-02 15:34:05 | 2014-07-02 15:34:24 Socket (1124) - Shutdown and closed. | 2014-07-02 15:34:24 The network socket for historical data has been closed. | 2014-07-02 15:34:24 HD Request # 48 - Received 19 records from 2014-07-02 15:34:04 to 2014-07-02 15:34:22 (18.0 seconds) and wrote 18 records for TICK-NYSE | 2014-07-02 15:34:24 Added 4 Time and Sales records to Intraday data file for TICK-NYSE after download. | 2014-07-02 15:34:24 HD Request # 48 - Intraday download COMPLETE for TICK-NYSE. Completion time: 1s | 2014-07-02 15:34:24 Real-time Intraday chart data file updates started for TICK-NYSE | 2014-07-02 15:34:24 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.900024, Time Difference = 8 seconds, Percentage = 300.239849% | 2014-07-02 15:34:25 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.900024, Time Difference = 8 seconds, Percentage = 300.239849% | 2014-07-02 15:34:25 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.900024, Time Difference = 8 seconds, Percentage = 300.239849% | 2014-07-02 15:34:25 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.900024, Time Difference = 8 seconds, Percentage = 300.239849% | 2014-07-02 15:34:25 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.900024, Time Difference = 8 seconds, Percentage = 300.239849% | 2014-07-02 15:34:25 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.900024, Time Difference = 8 seconds, Percentage = 300.239849% | 2014-07-02 15:34:25 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.900024, Time Difference = 8 seconds, Percentage = 300.239849% | 2014-07-02 15:34:25 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.900024, Time Difference = 8 seconds, Percentage = 300.239849% | 2014-07-02 15:34:25 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.900024, Time Difference = 8 seconds, Percentage = 300.239849% | 2014-07-02 15:34:25 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:25 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:25 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:25 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.900024, Time Difference = 9 seconds, Percentage = 300.269842% | 2014-07-02 15:34:25 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.900024, Time Difference = 9 seconds, Percentage = 300.269842% | 2014-07-02 15:34:26 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 9 seconds, Percentage = 300.269842% | 2014-07-02 15:34:26 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 9 seconds, Percentage = 300.269842% | 2014-07-02 15:34:26 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 9 seconds, Percentage = 300.269842% | 2014-07-02 15:34:26 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.750000, Time Difference = 9 seconds, Percentage = 300.269842% | 2014-07-02 15:34:26 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:26 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:26 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:26 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.750000, Time Difference = 15 seconds, Percentage = 300.449848% | 2014-07-02 15:34:31 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.750000, Time Difference = 15 seconds, Percentage = 300.449848% | 2014-07-02 15:34:31 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.750000, Time Difference = 15 seconds, Percentage = 300.449848% | 2014-07-02 15:34:31 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:32 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:32 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:32 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.750000, Time Difference = 16 seconds, Percentage = 300.479841% | 2014-07-02 15:34:32 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:34 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:34 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:34 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:34 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:34 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:34 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.900024, Time Difference = 18 seconds, Percentage = 300.539851% | 2014-07-02 15:34:35 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.900024, Time Difference = 18 seconds, Percentage = 300.539851% | 2014-07-02 15:34:35 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:35 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:35 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:35 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:36 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:36 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:36 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:37 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:37 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:37 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 22 seconds, Percentage = 300.659847% | 2014-07-02 15:34:38 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:39 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:39 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:39 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:40 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:40 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:40 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.750000, Time Difference = 24 seconds, Percentage = 300.719857% | 2014-07-02 15:34:40 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.750000, Time Difference = 24 seconds, Percentage = 300.719857% | 2014-07-02 15:34:40 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:42 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:42 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:42 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:42 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:42 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:42 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.400024, Time Difference = 0 seconds, Percentage = 9.999999% | 2014-07-02 15:34:43 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1967.000000, Time Difference = 26 seconds, Percentage = 300.779843% | 2014-07-02 15:34:43 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:43 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:43 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:43 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.750000, Time Difference = 28 seconds, Percentage = 300.839853% | 2014-07-02 15:34:45 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.750000, Time Difference = 30 seconds, Percentage = 300.899839% | 2014-07-02 15:34:46 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 30 seconds, Percentage = 300.899839% | 2014-07-02 15:34:47 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 33 seconds, Percentage = 300.989842% | 2014-07-02 15:34:49 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 33 seconds, Percentage = 300.989842% | 2014-07-02 15:34:49 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 33 seconds, Percentage = 300.989842% | 2014-07-02 15:34:49 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 33 seconds, Percentage = 300.989842% | 2014-07-02 15:34:49 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 33 seconds, Percentage = 300.989842% | 2014-07-02 15:34:49 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 33 seconds, Percentage = 300.989842% | 2014-07-02 15:34:49 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 33 seconds, Percentage = 300.989842% | 2014-07-02 15:34:49 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 33 seconds, Percentage = 300.989842% | 2014-07-02 15:34:49 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 33 seconds, Percentage = 300.989842% | 2014-07-02 15:34:49 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 33 seconds, Percentage = 300.989842% | 2014-07-02 15:34:49 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 33 seconds, Percentage = 300.989842% | 2014-07-02 15:34:49 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 33 seconds, Percentage = 300.989842% | 2014-07-02 15:34:49 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 33 seconds, Percentage = 300.989842% | 2014-07-02 15:34:49 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 33 seconds, Percentage = 300.989842% | 2014-07-02 15:34:49 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 33 seconds, Percentage = 300.989842% | 2014-07-02 15:34:49 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 33 seconds, Percentage = 300.989842% | 2014-07-02 15:34:49 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 33 seconds, Percentage = 300.989842% | 2014-07-02 15:34:49 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 33 seconds, Percentage = 300.989842% | 2014-07-02 15:34:49 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 33 seconds, Percentage = 300.989842% | 2014-07-02 15:34:49 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 33 seconds, Percentage = 300.989842% | 2014-07-02 15:34:49 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 33 seconds, Percentage = 300.989842% | 2014-07-02 15:34:49 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 33 seconds, Percentage = 300.989842% | 2014-07-02 15:34:50 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 33 seconds, Percentage = 300.989842% | 2014-07-02 15:34:50 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 33 seconds, Percentage = 300.989842% | 2014-07-02 15:34:50 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 33 seconds, Percentage = 300.989842% | 2014-07-02 15:34:50 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 33 seconds, Percentage = 300.989842% | 2014-07-02 15:34:50 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 33 seconds, Percentage = 300.989842% | 2014-07-02 15:34:50 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 33 seconds, Percentage = 300.989842% | 2014-07-02 15:34:50 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 33 seconds, Percentage = 300.989842% | 2014-07-02 15:34:50 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 33 seconds, Percentage = 300.989842% | 2014-07-02 15:34:50 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 33 seconds, Percentage = 300.989842% | 2014-07-02 15:34:50 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 33 seconds, Percentage = 300.989842% | 2014-07-02 15:34:50 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 33 seconds, Percentage = 300.989842% | 2014-07-02 15:34:50 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 34 seconds, Percentage = 301.019859% | 2014-07-02 15:34:50 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 34 seconds, Percentage = 301.019859% | 2014-07-02 15:34:50 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:50 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:50 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:50 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:53 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:53 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:53 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:53 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:53 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:53 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 38 seconds, Percentage = 301.139855% | 2014-07-02 15:34:54 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 38 seconds, Percentage = 301.139855% | 2014-07-02 15:34:54 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1967.000000, Time Difference = 38 seconds, Percentage = 301.139855% | 2014-07-02 15:34:54 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 38 seconds, Percentage = 301.139855% | 2014-07-02 15:34:54 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:56 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:56 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:56 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1967.000000, Time Difference = 41 seconds, Percentage = 301.229858% | 2014-07-02 15:34:57 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 41 seconds, Percentage = 301.229858% | 2014-07-02 15:34:58 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 41 seconds, Percentage = 301.229858% | 2014-07-02 15:34:58 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 41 seconds, Percentage = 301.229858% | 2014-07-02 15:34:58 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 41 seconds, Percentage = 301.229858% | 2014-07-02 15:34:58 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:58 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:58 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:58 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 42 seconds, Percentage = 301.259851% | 2014-07-02 15:34:59 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:59 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:59 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:34:59 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 43 seconds, Percentage = 301.289845% | 2014-07-02 15:35:00 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 43 seconds, Percentage = 301.289845% | 2014-07-02 15:35:00 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 43 seconds, Percentage = 301.289845% | 2014-07-02 15:35:00 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 43 seconds, Percentage = 301.289845% | 2014-07-02 15:35:00 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:01 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:01 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:01 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 44 seconds, Percentage = 301.319861% | 2014-07-02 15:35:01 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 45 seconds, Percentage = 301.349854% | 2014-07-02 15:35:01 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 45 seconds, Percentage = 301.349854% | 2014-07-02 15:35:01 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 45 seconds, Percentage = 301.349854% | 2014-07-02 15:35:02 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 46 seconds, Percentage = 301.379848% | 2014-07-02 15:35:02 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:02 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:02 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:02 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:03 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:03 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:03 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:03 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:03 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:03 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 48 seconds, Percentage = 301.439857% | 2014-07-02 15:35:04 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 48 seconds, Percentage = 301.439857% | 2014-07-02 15:35:04 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:05 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:05 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:05 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1967.000000, Time Difference = 50 seconds, Percentage = 301.499844% | 2014-07-02 15:35:06 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 50 seconds, Percentage = 301.499844% | 2014-07-02 15:35:06 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 50 seconds, Percentage = 301.499844% | 2014-07-02 15:35:06 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 50 seconds, Percentage = 301.499844% | 2014-07-02 15:35:06 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 50 seconds, Percentage = 301.499844% | 2014-07-02 15:35:06 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 50 seconds, Percentage = 301.499844% | 2014-07-02 15:35:06 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 50 seconds, Percentage = 301.499844% | 2014-07-02 15:35:06 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 50 seconds, Percentage = 301.499844% | 2014-07-02 15:35:06 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 50 seconds, Percentage = 301.499844% | 2014-07-02 15:35:06 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 50 seconds, Percentage = 301.499844% | 2014-07-02 15:35:06 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 50 seconds, Percentage = 301.499844% | 2014-07-02 15:35:06 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 50 seconds, Percentage = 301.499844% | 2014-07-02 15:35:06 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 50 seconds, Percentage = 301.499844% | 2014-07-02 15:35:06 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 50 seconds, Percentage = 301.499844% | 2014-07-02 15:35:06 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 50 seconds, Percentage = 301.499844% | 2014-07-02 15:35:06 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 50 seconds, Percentage = 301.499844% | 2014-07-02 15:35:06 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 50 seconds, Percentage = 301.499844% | 2014-07-02 15:35:06 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 50 seconds, Percentage = 301.499844% | 2014-07-02 15:35:06 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 50 seconds, Percentage = 301.499844% | 2014-07-02 15:35:06 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 50 seconds, Percentage = 301.499844% | 2014-07-02 15:35:06 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:08 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:08 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:08 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:08 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:08 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:08 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:08 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:08 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:08 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:09 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:09 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:09 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:10 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:10 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:10 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1967.000000, Time Difference = 54 seconds, Percentage = 301.619840% | 2014-07-02 15:35:10 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 54 seconds, Percentage = 301.619840% | 2014-07-02 15:35:11 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 56 seconds, Percentage = 301.679850% | 2014-07-02 15:35:12 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 56 seconds, Percentage = 301.679850% | 2014-07-02 15:35:12 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 57 seconds, Percentage = 301.709843% | 2014-07-02 15:35:14 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1967.000000, Time Difference = 58 seconds, Percentage = 301.739860% | 2014-07-02 15:35:14 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1967.000000, Time Difference = 58 seconds, Percentage = 301.739860% | 2014-07-02 15:35:14 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:14 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:14 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:14 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1967.000000, Time Difference = 58 seconds, Percentage = 301.739860% | 2014-07-02 15:35:14 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 59 seconds, Percentage = 301.769853% | 2014-07-02 15:35:16 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1967.000000, Time Difference = 59 seconds, Percentage = 301.769853% | 2014-07-02 15:35:16 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.750000, Time Difference = 59 seconds, Percentage = 301.769853% | 2014-07-02 15:35:16 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 59 seconds, Percentage = 301.769853% | 2014-07-02 15:35:16 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.800049, Time Difference = 59 seconds, Percentage = 301.769853% | 2014-07-02 15:35:16 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 59 seconds, Percentage = 301.769853% | 2014-07-02 15:35:16 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:16 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:16 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:16 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:16 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:16 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:16 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:16 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:16 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:16 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:16 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:16 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:16 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:16 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:16 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:16 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:16 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:16 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:16 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:16 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.500000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.500000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.500000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.500000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.500000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.500000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.500000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.500000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.500000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.500000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.500000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.250000, Time Difference = 61 seconds, Percentage = 301.829839% | 2014-07-02 15:35:17 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.500000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.500000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.250000, Time Difference = 61 seconds, Percentage = 301.829839% | 2014-07-02 15:35:17 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.250000, Time Difference = 61 seconds, Percentage = 301.829839% | 2014-07-02 15:35:17 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.250000, Time Difference = 61 seconds, Percentage = 301.829839% | 2014-07-02 15:35:17 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.250000, Time Difference = 61 seconds, Percentage = 301.829839% | 2014-07-02 15:35:17 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.250000, Time Difference = 61 seconds, Percentage = 301.829839% | 2014-07-02 15:35:17 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.500000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.500000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:17 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.250000, Time Difference = 61 seconds, Percentage = 301.829839% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.250000, Time Difference = 61 seconds, Percentage = 301.829839% | 2014-07-02 15:35:18 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.250000, Time Difference = 62 seconds, Percentage = 301.859856% | 2014-07-02 15:35:18 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.300049, Time Difference = 36 seconds, Percentage = 10.035999% | 2014-07-02 15:35:18 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.300049, Time Difference = 36 seconds, Percentage = 10.035999% | 2014-07-02 15:35:18 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.300049, Time Difference = 36 seconds, Percentage = 10.035999% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.300049, Time Difference = 36 seconds, Percentage = 10.035999% | 2014-07-02 15:35:18 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.300049, Time Difference = 36 seconds, Percentage = 10.035999% | 2014-07-02 15:35:18 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.300049, Time Difference = 36 seconds, Percentage = 10.035999% | 2014-07-02 15:35:18 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.300049, Time Difference = 36 seconds, Percentage = 10.035999% | 2014-07-02 15:35:18 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.300049, Time Difference = 36 seconds, Percentage = 10.035999% | 2014-07-02 15:35:18 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.300049, Time Difference = 36 seconds, Percentage = 10.035999% | 2014-07-02 15:35:18 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.300049, Time Difference = 36 seconds, Percentage = 10.035999% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:18 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:19 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.300049, Time Difference = 36 seconds, Percentage = 10.035999% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:19 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.300049, Time Difference = 36 seconds, Percentage = 10.035999% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:19 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.300049, Time Difference = 36 seconds, Percentage = 10.035999% | 2014-07-02 15:35:19 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.300049, Time Difference = 36 seconds, Percentage = 10.035999% | 2014-07-02 15:35:19 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.199951, Time Difference = 36 seconds, Percentage = 10.035999% | 2014-07-02 15:35:19 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.199951, Time Difference = 36 seconds, Percentage = 10.035999% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 60 seconds, Percentage = 301.799846% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 61 seconds, Percentage = 301.829839% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.500000, Time Difference = 61 seconds, Percentage = 301.829839% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 62 seconds, Percentage = 301.859856% | 2014-07-02 15:35:19 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 62 seconds, Percentage = 301.859856% | 2014-07-02 15:35:19 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.250000, Time Difference = 64 seconds, Percentage = 301.919842% | 2014-07-02 15:35:20 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.250000, Time Difference = 64 seconds, Percentage = 301.919842% | 2014-07-02 15:35:20 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.250000, Time Difference = 64 seconds, Percentage = 301.919842% | 2014-07-02 15:35:20 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.250000, Time Difference = 64 seconds, Percentage = 301.919842% | 2014-07-02 15:35:20 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.250000, Time Difference = 65 seconds, Percentage = 301.949859% | 2014-07-02 15:35:21 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.250000, Time Difference = 65 seconds, Percentage = 301.949859% | 2014-07-02 15:35:22 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.250000, Time Difference = 65 seconds, Percentage = 301.949859% | 2014-07-02 15:35:22 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.250000, Time Difference = 65 seconds, Percentage = 301.949859% | 2014-07-02 15:35:22 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.250000, Time Difference = 65 seconds, Percentage = 301.949859% | 2014-07-02 15:35:22 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.000000, Time Difference = 65 seconds, Percentage = 301.949859% | 2014-07-02 15:35:22 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.000000, Time Difference = 65 seconds, Percentage = 301.949859% | 2014-07-02 15:35:22 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.000000, Time Difference = 65 seconds, Percentage = 301.949859% | 2014-07-02 15:35:22 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.000000, Time Difference = 65 seconds, Percentage = 301.949859% | 2014-07-02 15:35:22 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.000000, Time Difference = 65 seconds, Percentage = 301.949859% | 2014-07-02 15:35:22 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.000000, Time Difference = 65 seconds, Percentage = 301.949859% | 2014-07-02 15:35:22 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.000000, Time Difference = 65 seconds, Percentage = 301.949859% | 2014-07-02 15:35:22 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:22 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:22 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:22 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.250000, Time Difference = 66 seconds, Percentage = 301.979852% | 2014-07-02 15:35:23 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.500000, Time Difference = 66 seconds, Percentage = 301.979852% | 2014-07-02 15:35:23 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.500000, Time Difference = 67 seconds, Percentage = 302.009845% | 2014-07-02 15:35:23 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.500000, Time Difference = 67 seconds, Percentage = 302.009845% | 2014-07-02 15:35:23 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.500000, Time Difference = 67 seconds, Percentage = 302.009845% | 2014-07-02 15:35:23 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.250000, Time Difference = 67 seconds, Percentage = 302.009845% | 2014-07-02 15:35:23 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 69 seconds, Percentage = 302.069855% | 2014-07-02 15:35:25 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 69 seconds, Percentage = 302.069855% | 2014-07-02 15:35:25 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 69 seconds, Percentage = 302.069855% | 2014-07-02 15:35:25 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 69 seconds, Percentage = 302.069855% | 2014-07-02 15:35:25 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 69 seconds, Percentage = 302.069855% | 2014-07-02 15:35:25 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 69 seconds, Percentage = 302.069855% | 2014-07-02 15:35:25 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 69 seconds, Percentage = 302.069855% | 2014-07-02 15:35:25 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 69 seconds, Percentage = 302.069855% | 2014-07-02 15:35:25 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 69 seconds, Percentage = 302.069855% | 2014-07-02 15:35:25 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 69 seconds, Percentage = 302.069855% | 2014-07-02 15:35:25 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 69 seconds, Percentage = 302.069855% | 2014-07-02 15:35:25 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 69 seconds, Percentage = 302.069855% | 2014-07-02 15:35:25 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 69 seconds, Percentage = 302.069855% | 2014-07-02 15:35:25 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 69 seconds, Percentage = 302.069855% | 2014-07-02 15:35:25 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 69 seconds, Percentage = 302.069855% | 2014-07-02 15:35:25 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 69 seconds, Percentage = 302.069855% | 2014-07-02 15:35:25 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 69 seconds, Percentage = 302.069855% | 2014-07-02 15:35:25 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.500000, Time Difference = 69 seconds, Percentage = 302.069855% | 2014-07-02 15:35:25 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:26 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:26 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:26 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:26 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:26 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:26 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:26 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:26 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:26 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.500000, Time Difference = 70 seconds, Percentage = 302.099848% | 2014-07-02 15:35:27 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.500000, Time Difference = 70 seconds, Percentage = 302.099848% | 2014-07-02 15:35:27 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.500000, Time Difference = 71 seconds, Percentage = 302.129841% | 2014-07-02 15:35:27 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:27 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:27 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:27 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.000000, Time Difference = 71 seconds, Percentage = 302.129841% | 2014-07-02 15:35:28 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:28 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:28 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:28 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 72 seconds, Percentage = 302.159858% | 2014-07-02 15:35:28 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 72 seconds, Percentage = 302.159858% | 2014-07-02 15:35:28 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 72 seconds, Percentage = 302.159858% | 2014-07-02 15:35:28 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 72 seconds, Percentage = 302.159858% | 2014-07-02 15:35:28 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 72 seconds, Percentage = 302.159858% | 2014-07-02 15:35:28 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.250000, Time Difference = 72 seconds, Percentage = 302.159858% | 2014-07-02 15:35:28 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.250000, Time Difference = 72 seconds, Percentage = 302.159858% | 2014-07-02 15:35:28 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:29 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:29 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:29 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 75 seconds, Percentage = 302.249861% | 2014-07-02 15:35:31 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 75 seconds, Percentage = 302.249861% | 2014-07-02 15:35:32 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.500000, Time Difference = 76 seconds, Percentage = 302.279854% | 2014-07-02 15:35:32 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.500000, Time Difference = 76 seconds, Percentage = 302.279854% | 2014-07-02 15:35:32 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.500000, Time Difference = 76 seconds, Percentage = 302.279854% | 2014-07-02 15:35:32 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.500000, Time Difference = 76 seconds, Percentage = 302.279854% | 2014-07-02 15:35:32 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 76 seconds, Percentage = 302.279854% | 2014-07-02 15:35:33 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 76 seconds, Percentage = 302.279854% | 2014-07-02 15:35:33 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 76 seconds, Percentage = 302.279854% | 2014-07-02 15:35:33 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.500000, Time Difference = 77 seconds, Percentage = 302.309847% | 2014-07-02 15:35:33 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.250000, Time Difference = 77 seconds, Percentage = 302.309847% | 2014-07-02 15:35:34 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.500000, Time Difference = 78 seconds, Percentage = 302.339840% | 2014-07-02 15:35:34 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.250000, Time Difference = 78 seconds, Percentage = 302.339840% | 2014-07-02 15:35:34 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.500000, Time Difference = 79 seconds, Percentage = 302.369857% | 2014-07-02 15:35:37 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.500000, Time Difference = 79 seconds, Percentage = 302.369857% | 2014-07-02 15:35:37 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.500000, Time Difference = 79 seconds, Percentage = 302.369857% | 2014-07-02 15:35:37 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.750000, Time Difference = 80 seconds, Percentage = 302.399850% | 2014-07-02 15:35:37 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:37 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:37 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:37 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 81 seconds, Percentage = 302.429843% | 2014-07-02 15:35:37 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 81 seconds, Percentage = 302.429843% | 2014-07-02 15:35:38 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 81 seconds, Percentage = 302.429843% | 2014-07-02 15:35:38 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 81 seconds, Percentage = 302.429843% | 2014-07-02 15:35:38 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.500000, Time Difference = 82 seconds, Percentage = 302.459860% | 2014-07-02 15:35:39 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.500000, Time Difference = 82 seconds, Percentage = 302.459860% | 2014-07-02 15:35:39 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:39 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:39 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:39 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.500000, Time Difference = 83 seconds, Percentage = 302.489853% | 2014-07-02 15:35:40 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 84 seconds, Percentage = 302.519846% | 2014-07-02 15:35:40 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 84 seconds, Percentage = 302.519846% | 2014-07-02 15:35:40 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 84 seconds, Percentage = 302.519846% | 2014-07-02 15:35:40 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 84 seconds, Percentage = 302.519846% | 2014-07-02 15:35:40 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 84 seconds, Percentage = 302.519846% | 2014-07-02 15:35:40 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 84 seconds, Percentage = 302.519846% | 2014-07-02 15:35:40 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 84 seconds, Percentage = 302.519846% | 2014-07-02 15:35:40 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 84 seconds, Percentage = 302.519846% | 2014-07-02 15:35:40 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 84 seconds, Percentage = 302.519846% | 2014-07-02 15:35:40 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 84 seconds, Percentage = 302.519846% | 2014-07-02 15:35:40 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 84 seconds, Percentage = 302.519846% | 2014-07-02 15:35:40 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 84 seconds, Percentage = 302.519846% | 2014-07-02 15:35:40 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 84 seconds, Percentage = 302.519846% | 2014-07-02 15:35:40 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 84 seconds, Percentage = 302.519846% | 2014-07-02 15:35:40 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 84 seconds, Percentage = 302.519846% | 2014-07-02 15:35:40 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 84 seconds, Percentage = 302.519846% | 2014-07-02 15:35:40 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.599976, Time Difference = 84 seconds, Percentage = 302.519846% | 2014-07-02 15:35:40 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.500000, Time Difference = 84 seconds, Percentage = 302.519846% | 2014-07-02 15:35:41 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.500000, Time Difference = 85 seconds, Percentage = 302.549839% | 2014-07-02 15:35:42 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.500000, Time Difference = 85 seconds, Percentage = 302.549839% | 2014-07-02 15:35:42 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.500000, Time Difference = 85 seconds, Percentage = 302.549839% | 2014-07-02 15:35:42 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.500000, Time Difference = 85 seconds, Percentage = 302.549839% | 2014-07-02 15:35:42 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:42 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:42 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:42 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.500000, Time Difference = 85 seconds, Percentage = 302.549839% | 2014-07-02 15:35:42 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.500000, Time Difference = 85 seconds, Percentage = 302.549839% | 2014-07-02 15:35:42 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.500000, Time Difference = 85 seconds, Percentage = 302.549839% | 2014-07-02 15:35:42 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.500000, Time Difference = 85 seconds, Percentage = 302.549839% | 2014-07-02 15:35:42 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.500000, Time Difference = 85 seconds, Percentage = 302.549839% | 2014-07-02 15:35:42 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.500000, Time Difference = 87 seconds, Percentage = 302.609849% | 2014-07-02 15:35:44 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.500000, Time Difference = 88 seconds, Percentage = 302.639842% | 2014-07-02 15:35:45 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.500000, Time Difference = 88 seconds, Percentage = 302.639842% | 2014-07-02 15:35:45 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 89 seconds, Percentage = 302.669859% | 2014-07-02 15:35:45 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 89 seconds, Percentage = 302.669859% | 2014-07-02 15:35:46 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 89 seconds, Percentage = 302.669859% | 2014-07-02 15:35:46 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 89 seconds, Percentage = 302.669859% | 2014-07-02 15:35:46 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 89 seconds, Percentage = 302.669859% | 2014-07-02 15:35:46 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 89 seconds, Percentage = 302.669859% | 2014-07-02 15:35:46 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 89 seconds, Percentage = 302.669859% | 2014-07-02 15:35:46 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 89 seconds, Percentage = 302.669859% | 2014-07-02 15:35:46 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 89 seconds, Percentage = 302.669859% | 2014-07-02 15:35:46 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 89 seconds, Percentage = 302.669859% | 2014-07-02 15:35:46 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 89 seconds, Percentage = 302.669859% | 2014-07-02 15:35:46 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 89 seconds, Percentage = 302.669859% | 2014-07-02 15:35:46 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 89 seconds, Percentage = 302.669859% | 2014-07-02 15:35:46 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 89 seconds, Percentage = 302.669859% | 2014-07-02 15:35:46 Error filtered for TFU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1195.699951, Time Difference = 89 seconds, Percentage = 302.669859% | 2014-07-02 15:35:46 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:46 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:46 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:46 Error filtered for ESU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 1966.500000, Time Difference = 89 seconds, Percentage = 302.669859% | 2014-07-02 15:35:46 Error filtered for NQU4, Intraday High = 4.364000, Intraday Low = 4.363000, Value = 3889.250000, Time Difference = 90 seconds, Percentage = 302.699852% | 2014-07-02 15:35:46 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.199951, Time Difference = 64 seconds, Percentage = 10.063999% | 2014-07-02 15:35:46 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:50 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:50 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:50 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:51 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:51 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:51 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.199951, Time Difference = 69 seconds, Percentage = 10.068999% | 2014-07-02 15:35:52 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.199951, Time Difference = 69 seconds, Percentage = 10.068999% | 2014-07-02 15:35:52 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.199951, Time Difference = 69 seconds, Percentage = 10.068999% | 2014-07-02 15:35:52 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.199951, Time Difference = 69 seconds, Percentage = 10.068999% | 2014-07-02 15:35:52 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.199951, Time Difference = 69 seconds, Percentage = 10.068999% | 2014-07-02 15:35:52 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.199951, Time Difference = 69 seconds, Percentage = 10.068999% | 2014-07-02 15:35:52 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.199951, Time Difference = 69 seconds, Percentage = 10.068999% | 2014-07-02 15:35:52 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.199951, Time Difference = 69 seconds, Percentage = 10.068999% | 2014-07-02 15:35:52 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.199951, Time Difference = 69 seconds, Percentage = 10.068999% | 2014-07-02 15:35:52 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.199951, Time Difference = 69 seconds, Percentage = 10.068999% | 2014-07-02 15:35:52 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.199951, Time Difference = 69 seconds, Percentage = 10.068999% | 2014-07-02 15:35:52 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.199951, Time Difference = 69 seconds, Percentage = 10.068999% | 2014-07-02 15:35:52 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.199951, Time Difference = 69 seconds, Percentage = 10.068999% | 2014-07-02 15:35:52 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.199951, Time Difference = 69 seconds, Percentage = 10.068999% | 2014-07-02 15:35:52 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:52 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:52 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:52 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:53 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:53 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:53 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:56 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:56 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:56 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:56 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:56 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:56 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.199951, Time Difference = 74 seconds, Percentage = 10.073999% | 2014-07-02 15:35:57 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.199951, Time Difference = 74 seconds, Percentage = 10.073999% | 2014-07-02 15:35:57 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.199951, Time Difference = 74 seconds, Percentage = 10.073999% | 2014-07-02 15:35:57 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.199951, Time Difference = 74 seconds, Percentage = 10.073999% | 2014-07-02 15:35:57 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.099976, Time Difference = 74 seconds, Percentage = 10.073999% | 2014-07-02 15:35:57 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.099976, Time Difference = 74 seconds, Percentage = 10.073999% | 2014-07-02 15:35:57 Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.099976, Time Difference = 74 seconds, Percentage = 10.073999% | 2014-07-02 15:35:57 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:57 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:57 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:35:57 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:05 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:05 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:05 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:06 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:06 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:06 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:07 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:07 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:07 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:08 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:08 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:08 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:09 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:09 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:09 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:09 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:09 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:09 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:10 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:10 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:10 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:11 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:11 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:11 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:11 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:11 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:11 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:12 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:12 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:12 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:12 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:12 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:12 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:14 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:14 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:14 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:15 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:15 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:15 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:16 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:16 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:16 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:16 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:16 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:16 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:18 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:18 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:18 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:18 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:18 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:18 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:18 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:18 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:18 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:19 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:19 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:19 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:20 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:20 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:20 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:22 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:22 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:22 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:23 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:23 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:23 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:24 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:24 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:24 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:25 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:25 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:25 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:27 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:27 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:27 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:28 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:28 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:28 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:31 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:31 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:31 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:32 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:32 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:32 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:34 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:34 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:34 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:34 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:34 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:34 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:34 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:34 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:34 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:35 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:35 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:35 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:36 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:36 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:36 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:37 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:37 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:37 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:39 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:39 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:39 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:40 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:40 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:40 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:40 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:40 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:40 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:41 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:41 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:41 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:44 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:44 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:44 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:44 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:44 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:44 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:45 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:45 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:45 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:46 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:46 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:46 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:47 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:47 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:47 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:48 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:48 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:48 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:56 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:56 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:36:56 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:00 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:00 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:00 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:01 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:01 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:01 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:02 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:02 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:02 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:03 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:03 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:03 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:04 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:04 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:04 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:05 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:05 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:05 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:11 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:11 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:11 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:14 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:14 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:14 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:17 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:17 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:17 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:17 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:17 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:17 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:18 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:18 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:18 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:25 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:25 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:25 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:26 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:26 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:26 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:31 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:31 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:31 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:32 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:32 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:32 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:32 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:32 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:32 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:33 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:33 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:33 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:41 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:41 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:41 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:42 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:42 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:42 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:45 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:45 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:45 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:47 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:47 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:47 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:50 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:50 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:50 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:55 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:55 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:37:55 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:01 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:01 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:01 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:02 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:02 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:02 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:03 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:03 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:03 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:09 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:09 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:09 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:17 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:17 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:17 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:17 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:17 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:17 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:19 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:19 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:19 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:23 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:23 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:23 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:24 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:24 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:24 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:25 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:25 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:25 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:30 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:30 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:30 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:30 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:30 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:30 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:32 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:32 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:32 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:39 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:39 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:39 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:41 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:41 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:41 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:43 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:43 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:43 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:44 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:44 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:44 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:45 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:45 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:45 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:45 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:45 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:45 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:46 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:46 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:46 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:47 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:47 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:47 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:50 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:50 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:50 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:52 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:52 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:52 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:52 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:52 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:52 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:53 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:53 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:53 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:56 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:56 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:38:56 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:06 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:06 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:06 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:09 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:09 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:09 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:13 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:13 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:13 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:13 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:13 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:13 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:15 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:15 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:15 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:17 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:17 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:17 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:18 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:18 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:18 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:22 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:22 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:22 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:23 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:23 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:23 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:24 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:24 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:24 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:25 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:25 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:25 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:27 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:27 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:27 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:27 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:27 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:27 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:30 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:30 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:30 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:32 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:32 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:32 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:33 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:33 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:33 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:33 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:33 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:33 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:33 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:33 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:33 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:34 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:34 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:34 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:34 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:34 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:34 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:35 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:35 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:35 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:35 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:35 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:35 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:36 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:36 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:36 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:36 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:36 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:36 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:37 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:37 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:37 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:38 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:38 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:38 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:39 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:39 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:39 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:41 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:41 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:41 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:41 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:41 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:41 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:42 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:42 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:42 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:43 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:43 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:43 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:43 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:43 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:43 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:44 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:44 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:44 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:47 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:47 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:47 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:48 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:48 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:48 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:50 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:50 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:50 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:50 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:50 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:50 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:51 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:51 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:51 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:52 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:52 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:52 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:53 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:53 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:53 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:53 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:53 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:53 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:56 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:56 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:56 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:57 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:57 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:57 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:58 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:58 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:58 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:59 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:59 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:39:59 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:05 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:05 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:05 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:06 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:06 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:06 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:07 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:07 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:07 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:08 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:08 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:08 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:08 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:08 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:08 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:08 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:08 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:08 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:09 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:09 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:09 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:09 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:09 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:09 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:10 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:10 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:10 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:11 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:11 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:11 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:12 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:12 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:12 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:12 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:12 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:12 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:13 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:13 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:13 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:13 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:13 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:13 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:14 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:14 Chart: HOQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:14 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:14 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:14 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:14 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:17 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:17 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:17 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:17 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:17 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:17 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:18 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:18 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:18 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:21 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:21 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:21 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:22 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:22 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:22 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:22 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:22 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:22 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:29 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:29 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:29 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:33 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:33 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:33 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:37 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:37 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:37 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:46 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:46 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:46 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:47 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:47 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:47 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:47 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:47 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:47 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:48 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:48 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:48 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:48 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:48 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:48 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:49 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:49 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:49 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:52 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:52 Chart: CLQ4 2 Min #1 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:40:52 |
[2014-07-02 20:04:51] |
Just to give you an update, we are looking into this.
[2014-07-02 20:35:10] |
The issue causing this message to appear and preventing the Chartbook from being read is solved: Unable to read newer Chartbook file format. Update ATCharts by selecting 'Help >> Download Current Version'. We will be putting out a new release later today. However, we cannot duplicate these exceptions: Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:24:57
Chart: NQU4 2 Min #6 | Study: Unknown name | Exception occurred while calling study function. | 2014-07-02 15:24:57 An unhandled exception was caught in c_Chart::WindowProc. Message: 32799, wParam: 0, lParam: 0 | 2014-07-02 15:24:58 The only logical conclusion about an error message like this is that memory is getting corrupted: Error filtered for GCQ4, Intraday High = 16897.000000, Intraday Low = 16895.000000, Value = 1328.300049, Time Difference = 36 seconds, Percentage = 10.035999% | 2014-07-02 15:35:18
Are you running any custom studies? If so refer to help topic 17 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails17.html We recommend recompiling them on the latest Sierra Chart version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-02 20:35:44
[2014-07-02 21:08:35] |
mayerrs - Posts: 70 |
what exactly do you mean that memory is getting corrupted?
[2014-07-02 21:23:21] |
The only thing that we are aware of at this time that could be corrupting memory would be a custom study. Are you using any custom studies?
[2014-07-02 21:58:21] |
no, i do not. i do not know about that. here are some pics.
Date Time Of Last Edit: 2014-07-02 21:58:56
MyStudyShouldBe.png / V - Attached On 2014-07-02 21:57:03 UTC - Size: 23.32 KB - 300 views MyStudiesRightNow.png / V - Attached On 2014-07-02 21:57:15 UTC - Size: 18.02 KB - 268 views StudiesAvailable.png / V - Attached On 2014-07-02 21:57:45 UTC - Size: 70.02 KB - 326 views AlertManager.png / V - Attached On 2014-07-02 21:57:58 UTC - Size: 113.16 KB - 291 views AlsoInteresting.png / V - Attached On 2014-07-02 21:58:08 UTC - Size: 55.95 KB - 293 views |
[2014-07-02 23:03:53] |
Can you attach one of your Chartbooks. It can be attached privately. Here is the instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile In regards to AlsoInteresting.png , this has to do with recent changes to store historical bid and ask prices. You would notice this if you are sharing chart data and one version supports the historical bid and ask prices and other one does not. So both versions need to be on the current version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-07-03 02:27:02] |
Apparently the reason this problem occurred is because of the particular CCI study you are using, was removed from the main list of studies. However, that should not have caused any kind of problems you were encountering. We could not duplicate those problems. We have added the study back. You will need to update the latest prerelease with Help >> Download Prerelease. However, we need to understand why all of these exceptions and other problems occurred. This does not make sense to us. So we still would appreciate to get your Chartbook to determine the source of the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-07-03 08:06:20] |
ok, here are two of my chartbooks. i made an update to the latest prerelease and my studies seems ok. but there is still alert log window poping up. i will be glad if you let me know what actually hapened.
Private File Private File |
[2014-07-04 03:32:54] |
We tested both of these Chartbooks. The first Chartbook that used references to remote chart data files was not able to be tested fully because of the data folder it was referencing did not exist on our test system. Still we did not encounter any exceptions. We tested the second Chartbooks using the same version you encountered the exceptions on but we did not encounter any exceptions as we would expect. So we do not know why you had those exceptions. For now we will let this issue go. Have you set the Alerts Log to automatically open? This is done through Global Settings >> General Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-07-04 04:38:22] |
i have "show alerts log on study alert" off and when i opened sierra right now to check it, alert log did pop up again. still same issues: 50times this Alert Formula Error - Chart: CLQ4 2 Min #1 | Study: Commodity Channel Index | Error: Invalid formula. | Formula: ( | 2014-07-04 00:32:38 |
[2014-07-04 05:10:15] |
And what is the formula actually set on that particular study for that chart?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-04 05:10:27
[2014-07-04 05:12:11] |
Nevermind, we can see this testing your Chartbook. Our initial impression is, something has become corrupted the Chartbook. We will look at this a little more closely to see if we can determine anything. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-07-04 05:54:55] |
We see the Alert Condition Formulas which are giving an error are set to "(". If you did not set a "(" for the study Alert Condition Formulas, then the Chartbook for unknown reasons has become corrupted. You need to use a backup Chartbook. Refer to this section for instructions: https://www.sierrachart.com/index.php?page=doc/doc_Chartbooks.html#BackupChartbook Or remove the "(" from the Alert Condition Formulas on the studies. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-04 05:55:27
[2014-07-04 11:52:06] |
i did remove the "(" from the alert conditions formulas but i have no idea how this hapened.. there is no reason for me to put "(" into alerts thanks for your help |
[2014-07-04 18:41:43] |
We do not know why this happened . We do not have an explanation for it. We suspect that memory got corrupted and caused the Chartbook corruption but we do not know why the memory got corrupted to begin with. We could not duplicate the problem.
