Date/Time: Thu, 10 Jul 2025 02:46:45 +0000
How to compare the first 30 mins of several days of the RTH sess
View Count: 2110
[2013-05-02 16:28:25] |
user727 - Posts: 16 |
Hi; I have a thing I do where I compare the Range and Volume of pieces of the trading day. In other software I have used Sessions to do this. So for example I setup a Session that is just the first 30 min of the RTH Session then I get one bar per day and I can compare the Range and Volume today to an average. Also, other charting software has supported assigning buttons to set the chart to a particular session. This is important so that I can quickly switch between looking at the first 30 min to looking at the first 60 mins, etc. How would I do this in SierraChart where it allows only two sessions? I have attached a screen shot of the current chart I use. The buttons are for different sessions, the second pane shows me the Range, the third pane is the total volume for the "session" and the bottom pane is filtered to show the volume of trades larger than 150 contracts. This is another important feature, how would I do this in SierraChart? Thanks for your help |
[2013-05-03 03:25:51] |
To set the Session Times, refer to: https://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#SessionTimes These have to be manually done so you will want to have multiple charts configured as you require rather than a button to automatically change them. For the available studies in Sierra Chart, refer to: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html For Volume Filtering, refer to: https://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#VolumeFilterH Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-03 03:26:56
