Date/Time: Wed, 30 Sep 2026 01:04:42 +0000
Open candles delay
View Count: 537
| [2023-06-07 09:29:00] |
| Krysonoffice - Posts: 2 |
Hello, I have a delay of 25 seconds on the opening of the candles, I do not know how to solve it. I tried the manipulations that you recommended it worked before but it does not work anymore. I tried to uninstall everything to delete the data but it doesn't work. Do you have any idea where it might come from? Best regards |
| [2023-06-07 12:05:25] |
| Sierra_Chart Engineering - Posts: 25005 |
That may be normal. Refer to: Prices / Data Falling Behind Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
