Date/Time: Wed, 30 Sep 2026 01:04:47 +0000
Alerts
View Count: 534
[2023-06-06 11:33:20]
Robert Wojczak - Posts: 178
Hold do i get a visual alert from a chart drawing and can name the alert so i see what triggered when im looking at another chart... i.e. if I have a alert on the gc chart and I'm looking at an es chart how can i see that the chart drawing level was triggered on that chart..
Thank You
[2023-06-06 16:21:59]
John - SC Support - Posts: 48062
What you would want to use is the option for "Compact Alert Pop-Up Window". If you have this enabled for an alert, then a compact window will pop-up when the alert is true. Refer to the following:
General Settings Window: Add Alert to Compact Alert Popup Window (Global Settings >> General Settings >> Alerts >> Additional Settings)
