Date/Time: Wed, 30 Sep 2026 00:27:11 +0000
[Programming Help] - Dinali Historical Data Error
View Count: 502
[2023-06-06 06:13:37]
JB01 - Posts: 6
Starting this morning I'm receiving an error for all CME contracts I try to load.
The error is related to historical daily data, all intraday data is loading hwever the countdown timer suggests some lagging.
Yesterday everything was working fine, i have followed all the support material related to this with no luck.
Any suggestions? Or is it a wider data issue?
I've also checked my Interent connection and connected to a 5G hotspot to double check this, no difference in result.
imageScreenshot 2023-06-06 123921.png / V - Attached On 2023-06-06 05:49:09 UTC - Size: 7.11 KB - 143 views
[2023-06-06 10:23:25]
Sierra_Chart Engineering - Posts: 25005
Update the historical daily charts using this command:
Edit Menu: Edit >> Download Data For All Historical Charts
