Date/Time: Wed, 30 Sep 2026 00:26:45 +0000
Missing 2 SPDR index in the Nasdaq total view
View Count: 506
[2023-06-02 14:39:09]
GravisHTG - Posts: 321
I cannot find those 2 main index in your total view package
XLC-NQTV
XLRE-NQTV
is that normal ?
imageexample.PNG / V - Attached On 2023-06-02 14:38:58 UTC - Size: 11.88 KB - 188 views
[2023-06-02 14:46:40]
John - SC Support - Posts: 48062
Yes - it is normal. Not every stock is listed in the Find Symbol page for stocks. You would just need to enter those symbols directly rather than choosing them from the list.
You can search for symbols to find ones that are not listed. Refer to the following:
File Menu: Searching for Stock Symbols
And we did verify that you can get data for XLC-NQTV and XLRE-NQTV.
