Date/Time: Thu, 02 May 2024 06:05:27 +0000
Subgraphs do not work
View Count: 211
[2023-06-02 07:54:40] |
User582870 - Posts: 9 |
I have the problem that the "Subgraphs" do not work. They cannot be clicked. "Settings and Inputs" and "Alerts" are active. This is the case for all created chartbooks. Thank you.
Study deaktiviert.jpg / V - Attached On 2023-06-02 07:53:04 UTC - Size: 26.35 KB - 61 views Attachment Deleted. |
[2023-06-02 13:01:08] |
Sierra_Chart Engineering - Posts: 14173 |
This is an operating system problem. Exit from Sierra Chart and close down as many programs as you can running on your system and run Sierra Chart again. If that does not work restart your computer.
[2023-06-03 17:44:14] |
Error fixed. When I deleted an old Study and loaded another one, the problem was solved.
[2023-06-04 05:20:53] |
Does not make sense to us that would make any difference.
