Date/Time: Wed, 30 Sep 2026 00:27:14 +0000
[User Discussion] - Stock Options Structure Setup
View Count: 954
| [2023-05-31 16:13:14] |
| Albert - Posts: 30 |
Will you please direct me to the "very specific" (link) instructions on how to setup a chart for: "stock options chart setup? Thank you Date Time Of Last Edit: 2023-05-31 16:13:55
| [2023-06-01 03:38:15] |
| User708541 - Posts: 208 |
If you go to: Global Settings --> Symbol Settings, it is my understanding that is where all your available symbols are listed. I don't think you will find symbols for any stock options on Sierra Chart. For example, you want to find the ticker for the 16 June AAPL 180 Call options? I don't think that's possible with Sierra. If it is, I'd also like to know how to chart Stock Option symbols.
| [2023-06-01 15:28:14] |
| John - SC Support - Posts: 48062 |
Follow the instructions at the following link to be able to pull up the data for Options: Real-Time Exchange Data Feeds Available From Sierra Chart: Futures Options For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2023-06-01 16:59:43] |
The original post is requesting Stock Options. It doesn't appear that SC offers data for stock options.
| [2023-06-02 09:59:50] |
| Sierra_Chart Engineering - Posts: 25005 |
No stock options data is not available.
