Date/Time: Tue, 29 Sep 2026 23:45:52 +0000
REPLAY MODE STUCK
View Count: 729
| [2023-05-29 08:58:29] |
| tankil - Posts: 2 |
HALLO WHEN I USE REPLAY MODE EVRY TIME THAHT I EXIT FROM THIS MODE OR PRESS STOP ITS STUCK AND TAKE A LOT OF TIME TO RECOVER IT?
| [2023-05-29 08:58:49] |
| Sierra_Chart Engineering - Posts: 25005 |
This may have to do with the time to reload the chart data and perform study calculations. Refer to: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
