Date/Time: Tue, 29 Sep 2026 23:46:50 +0000
[Programming Help] - Using sc.GetBidMarketDepthNumberOfLevels() in ACSIL study
View Count: 1219
| [2023-05-28 18:50:17] |
| User769783 - Posts: 208 |
When using the sc.GetBidMarketDepthNumberOfLevels() function in a study, do I need to set any parameters within sierra in order for the study to update properly? Thanks.
| [2023-05-29 14:15:48] |
| Sierra_Chart Engineering - Posts: 25005 |
There are settings which do affect the number of market depth levels and they are explained here: File Menu: Not Receiving the Full Number of Market Depth Levels Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2023-05-29 15:16:32] |
Yes, thanks. I have read through and set these settings. But I still have an issue where, its not trading. Im using sc.GetBidMarketDepthNumberOfLevels() as the trigger for my entry. Is it because the market levels for ask and bid side are the same? I thought one side would be greater....Thanks again..
