Date/Time: Fri, 13 Nov 2026 23:26:38 +0000
Market Profile POC
View Count: 1300
[2023-05-26 14:40:20]
User585993 - Posts: 83
How can I show just the market profile POC in another chart?
[2023-05-26 17:54:10]
You would want to use the "TPO Value Area Lines" on the "other" chart, assuming it is the same symbol. If it is not, then you would need to open a separate chart on which you can put the "TPO Value Area Lines" study and then use the "Study/Price Overlay" to overlay it to the "other" chart.
Refer to the following:
Study/Price Overlay Study
[2023-05-29 15:41:10]
Sierra_Chart Engineering - Posts: 25424
You just need to use the TPO Value Area Lines study on the chart where you want it and that is all.
