Date/Time: Fri, 26 Apr 2024 20:09:06 +0000
Please add YM
View Count: 302
[2023-05-26 08:00:59] |
User716459 - Posts: 110 |
Please add YM.
[2023-05-26 09:16:32] |
Sierra_Chart Engineering - Posts: 14106 |
If you require real-time market data for YM CBOT futures you can activate that here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-05-26 09:16:38
[2023-05-26 12:03:25] |
I click the link and there is no path to add YM
[2023-05-26 14:23:15] |
John - SC Support - Posts: 31154 |
The symbol "YM" is traded on the CBOT exchange from the CME Group. If you want this data, then you will need to activate an exchange option that includes the CBOT (such as "CBOT non-professional top-of-book"). You do not currently have an exchange active that includes this. You can add the exchange you want at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed If you need something else, then let us know what it is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-26 14:51:00] |
I do not know how to do it, how to add YM
[2023-05-26 17:56:38] |
Please verify that what you want is to add the CBOT exchange to your account. The "CBOT Non-Professional Top-of-Book" costs $1.25 per month. If you can verify that this is what you want, then we can activate it for you. If you want to do this yourself, then select the link we have given previously to go to the page with the list of exchanges, find the CBOT exchange you want, and select the "Activate" button. If you need something else with regards to the YM, then we need more information on what exactly that is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-29 10:37:25] |
Activate the cheapest YM, please. thank you.
[2023-05-29 14:16:41] |
The 'CBOT non-professional top-of-book' exchange has been internally activated, and will be renewed. This change will go in effect in approximately 3 minutes. If it does not, then restart Sierra Chart after that time.
The cost is 1.25 USD per month and you have been billed that for the month of May. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-29 14:37:56] |
Have you added?
[2023-05-29 14:38:41] |
Yes this has been confirmed added.
