Date/Time: Tue, 29 Sep 2026 23:46:08 +0000
DOM
View Count: 587
[2023-05-25 17:38:41]
User988492 - Posts: 2
Hello, I am trying to "Open Trading DOM" but it looks like it is gray out and not opening. I Would like to know if there is another or better way to get it active.
Date Time Of Last Edit: 2023-05-25 17:40:34
[2023-05-25 20:14:45]
John - SC Support - Posts: 48062
There are a couple of ways to open a Trading DOM. Both options are under the "File" menu. So you have the following:
- File >> Open Trading DOM for Chart
The only one that might be greyed out is "Open Trading DOM for Chart", if you do not have a chartbook open, or you do not have a chart as the active window. To resolve it, select a chart, and then select the option.
Selecting "Open Trading DOM" brings up the Find Symbol page, where you select the symbol you want and then select the button for "Open Trading DOM".
If these are not working for you, then we need more information as to what exactly is not working.
