Date/Time: Tue, 29 Sep 2026 23:46:24 +0000
Different Alert Sounds
View Count: 1159
| [2023-05-25 13:27:33] |
| ssangha84 - Posts: 132 |
Hello, I have two different instances where I want the alert sound to be different. When I scroll down the menu under "alert sounds" however, all 200 of them seem to make the same sound. How can I change that?
| [2023-05-25 14:21:56] |
| John - SC Support - Posts: 48062 |
Refer to the following instructions: General Settings Window: Configuring Alert Number Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
