Date/Time: Tue, 29 Sep 2026 23:46:08 +0000
Right align Fibonacci labels
View Count: 750
| [2023-05-25 13:25:41] |
| Delta Tango Foxtrot - Posts: 32 |
Is there any way to right align the labels on the Fibonacci tool?
| [2023-05-25 14:19:09] |
| John - SC Support - Posts: 48062 |
Exactly which tool are you referring to?
| [2023-05-25 19:47:43] |
Sorry. The Retracement Tool.
| [2023-05-25 20:46:33] |
For the Price Retracement Tool, there is a setting under the "Options" tab on the Configuration/Properties page for "Labels on Right". Refer to the following: Chart Drawing Tools: Price Retracement | Price Expansion | Price Projection Configuration For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
