Date/Time: Mon, 06 May 2024 17:54:16 +0000
Text Display for Study - how to set it to change colour +/-?
View Count: 210
[2023-05-25 08:55:14] |
User385631 - Posts: 4 |
Hi, I use Ask Volume Bid Volume Difference Text with the colour of the text set to change depending on whether number is positive or negative. I would like a static display (i.e. not attached to bar top or bottom) of the current bar number but if I use Text Display for Study I cannot set it to change colour depending on -/+. Is there another way to achieve a static display of current AVBVT that will change colour according to -/+ and that can be positioned anywhere on the chart window? Many thanks, sirwalter |
[2023-05-25 14:04:18] |
John - SC Support - Posts: 31401 |
We need you to post on the Support Board with your active Sierra Chart account. To do that select "Help >> Support Board " from within Sierra Chart. If you did not get an answer to your prior question, post here again after doing the above confirming that you have logged in with your current account to let us know. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
