Date/Time: Sun, 05 May 2024 15:31:12 +0000
Footprint not compatible
View Count: 182
[2023-05-23 20:28:24] |
User314484 - Posts: 7 |
Dear support, I am not able to use the footprint's file attached. I believe it is because the file is not compatible with your system. Could you please help me fixing this issue. I have attached the file. Thanks a lot. William |
Private File |
[2023-05-23 21:46:00] |
John - SC Support - Posts: 31368 |
Refer to the following: Chartbooks (Workspaces): Opening Older Chartbooks For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
