Date/Time: Tue, 07 May 2024 12:22:05 +0000
Horizontal Ray's
View Count: 264
[2023-05-23 09:26:55] |
User144064 - Posts: 3 |
Good day, I am looking to maintain my chart drawings each day to enable me to come back and analyse at the end of the week. I like to use Horizontal Ray's to define levels while trading. However I need to delete these at the end of each day as they carry over to the next day. In Global Settings > Tool Configs > Horizontal Ray Config. I can see the option to select 'Extend Until Future Intersection'. I would like to ask if it is possible to have the option to extend to end of day and/or end of session. This would allow me to maintain all drawings created each day and not carry over to future trading days. This would be of great help and I would like to thank you for your consideration with this request. All the best Dan |
[2023-05-23 15:28:57] |
John - SC Support - Posts: 31419 |
We have set this as a Feature Request. We can not say when we will get to any particular request.
[2023-05-23 15:34:26] |
Sierra_Chart Engineering - Posts: 14253 |
Would be best, that you develop this functionality using ACSIL. With ACSIL you can control the beginning and ending points of the lines: Using Drawing Tools From an Advanced Custom Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
