Date/Time: Sat, 04 May 2024 15:04:25 +0000
Price doesn't move
View Count: 1123
[2014-06-27 14:58:08] |
User49421 - Posts: 21 |
Hi, im logged on to SC FOREX DATA (FXCM) however on simulation moved price doesnt seem to move,it is static and i have to keep disconnecting and connecting again to see the change in price. I'm not sure what is wrong. Regards Ahmed |
[2014-06-27 16:17:00] |
What is the symbol of the chart? Post a copy of the Message Log by following these instructions: https://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-27 17:09:14] |
Aud/usd but it is the same for all symbols
[2014-06-27 17:18:22] |
[2014-06-27 17:27:18] |
Software version: 1151 | 2014-06-27 15:17:09 Usage end date: 2014-08-03 | 2014-06-27 15:17:09 Enabled for: Advanced Features. | 2014-06-27 15:17:09 Enabled for: Sierra Chart Historical Data Service. | 2014-06-27 15:17:09 Allow Support for Sierra Chart Data Feeds is disabled. | 2014-06-27 15:17:09 Active service: myTrack | 2014-06-27 15:17:09 Time Zone: +01:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2014-06-27 15:17:09 2014-06-27 15:17:09 Local computer clock time | 2014-06-27 15:17:09 2014-06-27 14:17:09 GMT time | 2014-06-27 15:17:09 2014-06-27 15:17:09 Time zone adjusted time | 2014-06-27 15:17:09 Time difference to server time: 2 seconds. | 2014-06-27 15:17:09 Program path: C:\SierraChart\ | 2014-06-27 15:17:09 Data Files path: C:\SierraChart\Data\ | 2014-06-27 15:17:09 OS Version Number: 6.2 | 2014-06-27 15:17:09 Checking for new symbol settings for mt | 2014-06-27 15:17:09 Symbol settings are up-to-date for mt | 2014-06-27 15:17:09 Connecting to data feed server host.trackdata.com port 9983... | 2014-06-27 15:17:14 Socket (0) - Resolved address host.trackdata.com to IP 198.6.18.36 | 2014-06-27 15:17:15 Socket (2084) - Connected. | 2014-06-27 15:17:15 Waiting for acceptance... | 2014-06-27 15:17:15 Error from MyTrack: Invalid MyTrack username or password. Select File >> Data/Trade Service Settings on the menu to set them. | 2014-06-27 15:17:15 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-27 15:17:15 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-27 15:17:15 Socket (2084) - Shutdown and closed. | 2014-06-27 15:17:15 Disconnected from MyTrack. | 2014-06-27 15:17:15 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-27 15:17:15 Connecting to data feed server host.trackdata.com port 9983... | 2014-06-27 15:17:20 Socket (0) - Resolved address host.trackdata.com to IP 198.6.18.36 | 2014-06-27 15:17:20 Socket (2088) - Connected. | 2014-06-27 15:17:20 Waiting for acceptance... | 2014-06-27 15:17:20 Error from MyTrack: Invalid MyTrack username or password. Select File >> Data/Trade Service Settings on the menu to set them. | 2014-06-27 15:17:20 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-27 15:17:20 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-27 15:17:20 Socket (2088) - Shutdown and closed. | 2014-06-27 15:17:20 Disconnected from MyTrack. | 2014-06-27 15:17:20 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-27 15:17:20 Connecting to data feed server host.trackdata.com port 9983... | 2014-06-27 15:17:25 Socket (0) - Resolved address host.trackdata.com to IP 198.6.18.36 | 2014-06-27 15:17:25 Socket (2096) - Connected. | 2014-06-27 15:17:25 Waiting for acceptance... | 2014-06-27 15:17:25 Error from MyTrack: Invalid MyTrack username or password. Select File >> Data/Trade Service Settings on the menu to set them. | 2014-06-27 15:17:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-27 15:17:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-27 15:17:25 Socket (2096) - Shutdown and closed. | 2014-06-27 15:17:25 Disconnected from MyTrack. | 2014-06-27 15:17:25 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-27 15:17:25 Current selected Data/Trading service: FXCM FIX Trading | 2014-06-27 15:17:27 Checking for new symbol settings for fxcm | 2014-06-27 15:17:27 Disconnected from MyTrack. | 2014-06-27 15:17:27 Requesting symbol settings for fxcm. Overwrite = on. | 2014-06-27 15:17:27 Symbol settings received. | 2014-06-27 15:17:27 Processed received symbol settings | 2014-06-27 15:17:29 Connecting to FXCM FIX at address: fixreal.fxcorporate.com | 2014-06-27 15:17:40 FXCM FIX socket (0) - Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-06-27 15:17:40 FXCM FIX socket (584) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-06-27 15:17:41 FXCM FIX socket (584) - Shutdown and closed. | 2014-06-27 15:17:41 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-06-27 15:17:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-27 15:17:41 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-27 15:17:41 Disconnected from FXCM FIX. | 2014-06-27 15:17:41 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-27 15:17:41 Connecting to FXCM FIX at address: fixreal.fxcorporate.com | 2014-06-27 15:17:46 FXCM FIX socket (0) - Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-06-27 15:17:46 FXCM FIX socket (2008) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-06-27 15:17:47 FXCM FIX socket (2008) - Shutdown and closed. | 2014-06-27 15:17:47 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-06-27 15:17:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-27 15:17:47 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-27 15:17:47 Disconnected from FXCM FIX. | 2014-06-27 15:17:47 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-27 15:17:47 Connecting to FXCM FIX at address: fixreal.fxcorporate.com | 2014-06-27 15:17:52 FXCM FIX socket (0) - Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-06-27 15:17:52 FXCM FIX socket (2012) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-06-27 15:17:54 FXCM FIX socket (2012) - Shutdown and closed. | 2014-06-27 15:17:54 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-06-27 15:17:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-27 15:17:54 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-27 15:17:54 Disconnected from FXCM FIX. | 2014-06-27 15:17:54 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-27 15:17:54 Connecting to FXCM FIX at address: fixreal.fxcorporate.com | 2014-06-27 15:17:59 FXCM FIX socket (0) - Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-06-27 15:17:59 FXCM FIX socket (2100) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-06-27 15:18:00 FXCM FIX socket (2100) - Shutdown and closed. | 2014-06-27 15:18:00 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-06-27 15:18:00 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-27 15:18:00 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-27 15:18:00 Disconnected from FXCM FIX. | 2014-06-27 15:18:00 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-27 15:18:00 Connecting to FXCM FIX at address: fixreal.fxcorporate.com | 2014-06-27 15:18:05 FXCM FIX socket (0) - Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-06-27 15:18:05 FXCM FIX socket (2012) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-06-27 15:18:06 FXCM FIX socket (2012) - Shutdown and closed. | 2014-06-27 15:18:06 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-06-27 15:18:06 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-27 15:18:06 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-27 15:18:06 Disconnected from FXCM FIX. | 2014-06-27 15:18:06 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-27 15:18:06 Connecting to FXCM FIX at address: fixreal.fxcorporate.com | 2014-06-27 15:18:11 FXCM FIX socket (0) - Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-06-27 15:18:11 FXCM FIX socket (2100) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-06-27 15:18:12 FXCM FIX socket (2100) - Shutdown and closed. | 2014-06-27 15:18:12 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-06-27 15:18:12 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-27 15:18:12 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-27 15:18:12 Disconnected from FXCM FIX. | 2014-06-27 15:18:12 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-27 15:18:12 Connecting to FXCM FIX at address: fixreal.fxcorporate.com | 2014-06-27 15:18:17 FXCM FIX socket (0) - Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-06-27 15:18:17 FXCM FIX socket (1412) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-06-27 15:18:19 FXCM FIX socket (1412) - Shutdown and closed. | 2014-06-27 15:18:19 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-06-27 15:18:19 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-27 15:18:19 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-27 15:18:19 Disconnected from FXCM FIX. | 2014-06-27 15:18:19 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-27 15:18:19 Connecting to FXCM FIX at address: fixreal.fxcorporate.com | 2014-06-27 15:18:24 FXCM FIX socket (0) - Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-06-27 15:18:24 FXCM FIX socket (1408) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-06-27 15:18:25 FXCM FIX socket (1408) - Shutdown and closed. | 2014-06-27 15:18:25 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-06-27 15:18:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-27 15:18:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-27 15:18:25 Disconnected from FXCM FIX. | 2014-06-27 15:18:25 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-27 15:18:25 Connecting to FXCM FIX at address: fixreal.fxcorporate.com | 2014-06-27 15:18:30 FXCM FIX socket (0) - Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-06-27 15:18:30 FXCM FIX socket (1416) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-06-27 15:18:31 FXCM FIX socket (1416) - Shutdown and closed. | 2014-06-27 15:18:31 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-06-27 15:18:31 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-27 15:18:31 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-27 15:18:31 Disconnected from FXCM FIX. | 2014-06-27 15:18:31 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-27 15:18:31 Connecting to FXCM FIX at address: fixreal.fxcorporate.com | 2014-06-27 15:18:36 FXCM FIX socket (0) - Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-06-27 15:18:36 FXCM FIX socket (1416) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-06-27 15:18:38 FXCM FIX socket (1416) - Shutdown and closed. | 2014-06-27 15:18:38 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-06-27 15:18:38 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-27 15:18:38 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-27 15:18:38 Disconnected from FXCM FIX. | 2014-06-27 15:18:38 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-27 15:18:38 Connecting to FXCM FIX at address: fixreal.fxcorporate.com | 2014-06-27 15:18:43 FXCM FIX socket (0) - Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-06-27 15:18:43 FXCM FIX socket (1404) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-06-27 15:18:44 FXCM FIX socket (1404) - Shutdown and closed. | 2014-06-27 15:18:44 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-06-27 15:18:44 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-27 15:18:44 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-27 15:18:44 Disconnected from FXCM FIX. | 2014-06-27 15:18:44 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-27 15:18:44 Connecting to FXCM FIX at address: fixreal.fxcorporate.com | 2014-06-27 15:18:49 FXCM FIX socket (0) - Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-06-27 15:18:49 FXCM FIX socket (1400) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-06-27 15:18:50 FXCM FIX socket (1400) - Shutdown and closed. | 2014-06-27 15:18:51 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-06-27 15:18:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-27 15:18:51 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-27 15:18:51 Disconnected from FXCM FIX. | 2014-06-27 15:18:51 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-27 15:18:51 Connecting to FXCM FIX at address: fixreal.fxcorporate.com | 2014-06-27 15:18:56 FXCM FIX socket (0) - Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-06-27 15:18:56 FXCM FIX socket (1396) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-06-27 15:18:57 FXCM FIX socket (1396) - Shutdown and closed. | 2014-06-27 15:18:57 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-06-27 15:18:57 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-27 15:18:57 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-27 15:18:57 Disconnected from FXCM FIX. | 2014-06-27 15:18:57 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-27 15:18:57 Connecting to FXCM FIX at address: fixreal.fxcorporate.com | 2014-06-27 15:19:02 FXCM FIX socket (0) - Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-06-27 15:19:02 FXCM FIX socket (1396) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-06-27 15:19:03 FXCM FIX socket (1396) - Shutdown and closed. | 2014-06-27 15:19:03 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-06-27 15:19:03 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-27 15:19:03 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-27 15:19:03 Disconnected from FXCM FIX. | 2014-06-27 15:19:03 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-27 15:19:03 Connecting to FXCM FIX at address: fixreal.fxcorporate.com | 2014-06-27 15:19:08 FXCM FIX socket (0) - Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-06-27 15:19:08 FXCM FIX socket (1396) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-06-27 15:19:09 FXCM FIX socket (1396) - Shutdown and closed. | 2014-06-27 15:19:09 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-06-27 15:19:09 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-27 15:19:09 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-27 15:19:09 Disconnected from FXCM FIX. | 2014-06-27 15:19:09 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-27 15:19:09 Connecting to FXCM FIX at address: fixreal.fxcorporate.com | 2014-06-27 15:19:14 FXCM FIX socket (0) - Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-06-27 15:19:14 FXCM FIX socket (2100) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-06-27 15:19:16 FXCM FIX socket (2100) - Shutdown and closed. | 2014-06-27 15:19:16 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-06-27 15:19:16 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-27 15:19:16 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-27 15:19:16 Disconnected from FXCM FIX. | 2014-06-27 15:19:16 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-27 15:19:16 Current selected Data/Trading service: SC Forex Data (FXCM) | 2014-06-27 15:19:20 Checking for new symbol settings for fxcm | 2014-06-27 15:19:20 Disconnected from FXCM FIX. | 2014-06-27 15:19:20 Symbol settings are up-to-date for fxcm | 2014-06-27 15:19:20 SC Forex Data (FXCM): Connecting to the server ds3.sierracharts.com. Port 443 | 2014-06-27 15:19:25 Socket (0) - Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-06-27 15:19:25 Socket (2100) - Connected. | 2014-06-27 15:19:25 SC Forex Data (FXCM): Connected to server. | 2014-06-27 15:19:25 SC Forex Data (FXCM): Sending logon request message. | 2014-06-27 15:19:25 SC Forex Data (FXCM) Server Info - Server Name: . Server Version: . Provider Name: . | 2014-06-27 15:19:25 SC Forex Data (FXCM) - Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-06-27 15:19:25 SC Forex Data (FXCM) - Successfully connected. | 2014-06-27 15:19:25 SC Forex Data (FXCM) - Starting real-time market data updates for: ^GBPUSD. ID: 1 | 2014-06-27 15:19:25 SC Forex Data (FXCM) - Starting real-time market data updates for: ^AUDUSD. ID: 2 | 2014-06-27 15:19:25 SC Forex Data (FXCM) - Starting real-time market data updates for: ^EURGBP. ID: 3 | 2014-06-27 15:19:25 SC Forex Data (FXCM) - Starting real-time market data updates for: ^EURUSD. ID: 4 | 2014-06-27 15:19:25 SC Forex Data (FXCM) - Starting real-time market data updates for: ^EURJPY. ID: 5 | 2014-06-27 15:19:25 HD Request # 2 - Downloading Intraday chart data for ^GBPUSD to the file ^GBPUSD.scid. Service: fxcm | 2014-06-27 15:19:25 HD Request # 2 - Download start Date-Time: 2014-06-25 20:23:00.0 | 2014-06-27 15:19:25 HD Request # 2 - Using server: ds4.sierracharts.com port 10149 | 2014-06-27 15:19:25 Socket (0) - Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-06-27 15:19:25 Real-time data for symbol ^GBPUSD is currently unavailable. | 2014-06-27 15:19:25 Real-time data for symbol ^AUDUSD is currently unavailable. | 2014-06-27 15:19:25 Real-time data for symbol ^EURGBP is currently unavailable. | 2014-06-27 15:19:25 Real-time data for symbol ^EURUSD is currently unavailable. | 2014-06-27 15:19:25 Real-time data for symbol ^EURJPY is currently unavailable. | 2014-06-27 15:19:25 Socket (1408) - Connected. | 2014-06-27 15:19:25 HD Request # 2 - Sending historical data logon request message. | 2014-06-27 15:19:25 HD Request # 2 - Requesting Intraday data. Start Date-Time: 2014-06-25 20:23:00. Record interval: 1. Symbol: ^GBPUSD | 2014-06-27 15:19:26 HD Request # 2 - Error downloading historical Intraday data for ^GBPUSD. Historical data file not available for symbol. | 2014-06-27 15:19:26 Socket (1408) - Shutdown and closed. | 2014-06-27 15:19:26 The network socket for historical data has been closed. | 2014-06-27 15:19:26 HD Request # 2 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ^GBPUSD | 2014-06-27 15:19:26 HD Request # 2 - Intraday download COMPLETE for ^GBPUSD. Completion time: 1s | 2014-06-27 15:19:26 Real-time Intraday chart data file updates started for ^GBPUSD | 2014-06-27 15:19:26 HD Request # 3 - Downloading Intraday chart data for ^AUDUSD to the file ^AUDUSD.scid. Service: fxcm | 2014-06-27 15:19:26 HD Request # 3 - Download start Date-Time: 2014-06-25 20:23:00.0 | 2014-06-27 15:19:26 HD Request # 3 - Using server: ds5.sierracharts.com port 10149 | 2014-06-27 15:19:26 Socket (0) - Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-06-27 15:19:26 Socket (1028) - Connected. | 2014-06-27 15:19:26 HD Request # 3 - Sending historical data logon request message. | 2014-06-27 15:19:26 HD Request # 3 - Requesting Intraday data. Start Date-Time: 2014-06-25 20:23:00. Record interval: 1. Symbol: ^AUDUSD | 2014-06-27 15:19:26 HD Request # 3 - Error downloading historical Intraday data for ^AUDUSD. Historical data file not available for symbol. | 2014-06-27 15:19:27 Socket (1028) - Shutdown and closed. | 2014-06-27 15:19:27 The network socket for historical data has been closed. | 2014-06-27 15:19:27 HD Request # 3 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ^AUDUSD | 2014-06-27 15:19:27 HD Request # 3 - Intraday download COMPLETE for ^AUDUSD. Completion time: 1s | 2014-06-27 15:19:27 Real-time Intraday chart data file updates started for ^AUDUSD | 2014-06-27 15:19:27 HD Request # 4 - Downloading Intraday chart data for ^EURGBP to the file ^EURGBP.scid. Service: fxcm | 2014-06-27 15:19:27 HD Request # 4 - Download start Date-Time: 2014-06-25 20:24:00.0 | 2014-06-27 15:19:27 HD Request # 4 - Using server: ds3.sierracharts.com port 10149 | 2014-06-27 15:19:27 Socket (0) - Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-06-27 15:19:27 Socket (676) - Connected. | 2014-06-27 15:19:27 HD Request # 4 - Sending historical data logon request message. | 2014-06-27 15:19:27 HD Request # 4 - Requesting Intraday data. Start Date-Time: 2014-06-25 20:24:00. Record interval: 1. Symbol: ^EURGBP | 2014-06-27 15:19:27 HD Request # 4 - Error downloading historical Intraday data for ^EURGBP. Historical data file not available for symbol. | 2014-06-27 15:19:27 Socket (676) - Shutdown and closed. | 2014-06-27 15:19:27 The network socket for historical data has been closed. | 2014-06-27 15:19:27 HD Request # 4 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ^EURGBP | 2014-06-27 15:19:27 HD Request # 4 - Intraday download COMPLETE for ^EURGBP. Completion time: 0s | 2014-06-27 15:19:27 Real-time Intraday chart data file updates started for ^EURGBP | 2014-06-27 15:19:27 HD Request # 5 - Downloading Intraday chart data for ^EURUSD to the file ^EURUSD.scid. Service: fxcm | 2014-06-27 15:19:27 HD Request # 5 - Download start Date-Time: 2014-06-25 20:23:00.0 | 2014-06-27 15:19:27 HD Request # 5 - Using server: ds4.sierracharts.com port 10149 | 2014-06-27 15:19:27 Socket (0) - Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-06-27 15:19:27 Socket (676) - Connected. | 2014-06-27 15:19:27 HD Request # 5 - Sending historical data logon request message. | 2014-06-27 15:19:27 HD Request # 5 - Requesting Intraday data. Start Date-Time: 2014-06-25 20:23:00. Record interval: 1. Symbol: ^EURUSD | 2014-06-27 15:19:28 HD Request # 5 - Error downloading historical Intraday data for ^EURUSD. Historical data file not available for symbol. | 2014-06-27 15:19:28 Socket (676) - Shutdown and closed. | 2014-06-27 15:19:28 The network socket for historical data has been closed. | 2014-06-27 15:19:28 HD Request # 5 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ^EURUSD | 2014-06-27 15:19:28 HD Request # 5 - Intraday download COMPLETE for ^EURUSD. Completion time: 0s | 2014-06-27 15:19:28 Real-time Intraday chart data file updates started for ^EURUSD | 2014-06-27 15:19:28 HD Request # 6 - Downloading Intraday chart data for ^EURJPY to the file ^EURJPY.scid. Service: fxcm | 2014-06-27 15:19:28 HD Request # 6 - Download start Date-Time: 2014-06-25 20:23:00.0 | 2014-06-27 15:19:28 HD Request # 6 - Using server: ds5.sierracharts.com port 10149 | 2014-06-27 15:19:28 Socket (0) - Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-06-27 15:19:28 Socket (1028) - Connected. | 2014-06-27 15:19:28 HD Request # 6 - Sending historical data logon request message. | 2014-06-27 15:19:28 HD Request # 6 - Requesting Intraday data. Start Date-Time: 2014-06-25 20:23:00. Record interval: 1. Symbol: ^EURJPY | 2014-06-27 15:19:28 Socket (1028) - Shutdown and closed. | 2014-06-27 15:19:28 The network socket for historical data has been closed. | 2014-06-27 15:19:28 HD Request # 6 - Error downloading historical Intraday data for ^EURJPY. Historical data file not available for symbol. | 2014-06-27 15:19:28 HD Request # 6 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ^EURJPY | 2014-06-27 15:19:28 HD Request # 6 - Intraday download COMPLETE for ^EURJPY. Completion time: 0s | 2014-06-27 15:19:28 Real-time Intraday chart data file updates started for ^EURJPY | 2014-06-27 15:19:28 HD Request # 7 - Downloading Historical Daily chart data for ^AUDUSD. Starting date: 2014-06-24. Service: fxcm | 2014-06-27 15:19:45 Historical data download counter reset. | 2014-06-27 15:19:45 HD Request # 7 - Requesting historical Daily data for ^AUDUSD starting at 2014-06-23 | 2014-06-27 15:19:45 HD Request # 7 - Receiving historical Daily data for ^AUDUSD starting at 2014-06-23 | 2014-06-27 15:19:45 Writing historical Daily data for ^AUDUSD to the file ^AUDUSD.dly | 2014-06-27 15:19:45 HD Request # 7 - Received 5 records from 2014-06-23 00:00:00 to 2014-06-27 00:00:00 (5.0 days) and wrote 4 records for ^AUDUSD | 2014-06-27 15:19:45 HD Request # 7 - Daily download COMPLETE for ^AUDUSD. Completion time: 0s | 2014-06-27 15:19:45 |
[2014-06-27 18:01:05] |
You are not using the correct symbols. You need to remove the ^ character from the beginning of the Forex symbol. This can be done for each chart through Chart >> Chart Settings >> Symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
