Date/Time: Fri, 03 May 2024 20:14:20 +0000
control bar
View Count: 211
[2023-05-22 17:30:15] |
lservin29 - Posts: 27 |
I added "ENABLE ORDER ALLOCATION TO TRADE ACCOUNTS" to the main control bar, but I detached the chart that has the active trade window for chart.....?is this why the control bar button does not work?
[2023-05-22 23:00:51] |
John - SC Support - Posts: 31360 |
Yes, this would be the case. Any Control Bar that is attached to the Main Instance does not work with Detached Windows. You need to turn on the Control Bar for that specific detached chart. Refer to the following: Control Bar: Moving and Detaching the Control Bar For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
