Date/Time: Mon, 06 May 2024 12:21:44 +0000
Displaying Reversal Price on a Point & Figure Chart
View Count: 1224
[2014-06-27 13:51:44] |
cmet - Posts: 538 |
Trying to find out if there's a simple way to visually indicate the reversal price on a PNF chart. This would be the price that, if traded, would create a new PNF bar. In Investor RT, they use a little white box that travels with the size of the bar. For example, on an up bar (row of X's) in a 5 tick PNF chart, the white box is always 5 ticks below the high of the bar. Just looking for something similar. Since you can plot the point of control by itself with a dash or symbol in Sierra, was wondering if you could do the same with the reversal price. Example of what it might look like: http://s1.postimg.org/c3m00g7zz/pnf.jpg |
