Date/Time: Wed, 08 May 2024 04:58:46 +0000
chartbook file is not compatible
View Count: 200
[2023-05-22 07:00:17] |
Ajay_83 - Posts: 1 |
while loading a chartbook i got the following error 'The chartbook file is not compatible. Contact Sierra Chart support for hrlp with converting it' How can i convert it? |
StandardDailyTPOchartStingTommy.Cht - Attached On 2023-05-22 06:57:24 UTC - Size: 224.19 KB - 62 views Attachment Deleted. |
[2023-05-22 15:07:14] |
John - SC Support - Posts: 31441 |
Refer to the following: Chartbooks (Workspaces): Opening Older Chartbooks For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
