Date/Time: Sat, 04 May 2024 03:17:19 +0000
Alert every 15 minutes
View Count: 230
[2023-05-21 18:26:13] |
User251043 - Posts: 44 |
Hi, How can I have an alert on a 5-min chart every 15 minutes? I know I could have a hidden 15-min chart and play an alert every new bar, but I prefer to have the charts to a minimum. Thank you! |
[2023-05-22 15:04:04] |
John - SC Support - Posts: 31362 |
You would have to check the time of the bar. There are functions for "BARTIME" and you can use the "MINUTE" function as well with Alerts. Therefore, to check if a bar is started on a 15 minute period, you could do the following alert condition: =OR(MINUTE(BARTIME) = 0, MINUTE(BARTIME) = 15, MINUTE(BARTIME) = 30, MINUTE(BARTIME) = 45) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-23 07:38:41] |
Thank you! That was exactly what I needed.
