Date/Time: Fri, 13 Nov 2026 23:16:37 +0000
Chartbook file is not compatible
View Count: 744
[2023-05-20 15:47:15]
User340904 - Posts: 1
I'm unable to open 6 Chartbook files. The Message Log that appears when I try to open them is pasted below. Can you advise on converting/opening them?
Thanks!
*************** Message Log *******************
The Chartbook file is not compatible. Contact Sierra Chart support for help with converting it. File: C:\SierraChart\Data\SZS YM.Cht | 2023-05-20 14:55:35.926 *
The Chartbook file is not compatible. Contact Sierra Chart support for help with converting it. File: C:\SierraChart\Data\SZS CL.Cht | 2023-05-20 14:55:46.965 *
The Chartbook file is not compatible. Contact Sierra Chart support for help with converting it. File: C:\SierraChart\Data\SZS ES.Cht | 2023-05-20 14:55:54.406 *
The Chartbook file is not compatible. Contact Sierra Chart support for help with converting it. File: C:\SierraChart\Data\SZS GC.Cht | 2023-05-20 14:56:03.905 *
The Chartbook file is not compatible. Contact Sierra Chart support for help with converting it. File: C:\SierraChart\Data\SZS NQ.Cht | 2023-05-20 14:56:11.787 *
The Chartbook file is not compatible. Contact Sierra Chart support for help with converting it. File: C:\SierraChart\Data\SZS RTY.Cht | 2023-05-20 14:56:22.444 *
[2023-05-22 14:07:30]
Sierra_Chart Engineering - Posts: 25424
Follow the instructions here:
Chartbooks (Workspaces): Opening Older Chartbooks
