Date/Time: Sat, 04 May 2024 23:31:13 +0000
Would I still need to reconnect once a month?
View Count: 258
[2023-05-17 02:00:30] |
Jack Tops - Posts: 2 |
If I have package 12 with the Denali feed and I get the CME nonprofessional with market depth, would I still need to connect to my broker once a month to get LIVE data?
[2023-05-17 04:00:32] |
Tony - Posts: 460 |
I am pretty sure only when you open a brokerage account with Teton data, then you don't need to connect to live once a month, just be aware that one broker could have multiple choices, i.e. EdgeClear has Rithmic, CQG and Teton.
[2023-05-17 13:45:45] |
John - SC Support - Posts: 31362 |
If you are not staying connected to that live account, then yes - you will need to make that connection at least once a month in order to update your verification date for your non-professional status. You can view the "Verified Until" date at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-18 19:35:05] |
Sierra_Chart Engineering - Posts: 14224 |
Yes this is true in the case of Teton: I am pretty sure only when you open a brokerage account with Teton data, then you don't need to connect to live once a month,
