Date/Time: Wed, 01 May 2024 01:27:58 +0000
[Programming Help] - DTC Submit Market Order
View Count: 361
[2023-05-16 23:55:13] |
fcpauldiaz - Posts: 18 |
I'm trying to send a market order via DTC server 1. enabled authentication 2. enabled allow trading 3. connection is successful { "BracketOrdersSupported": 1, "HistoricalPriceDataSupported": 0, "Integer_1": 0, "MarketDataSupported": 1, "MarketDepthIsSupported": 1, "MarketDepthUpdatesBestBidAndAsk": 0, "OCOOrdersSupported": 1, "OneHistoricalPriceDataRequestPerConnection": 0, "OrderCancelReplaceSupported": 1, "ProtocolVersion": 8, "ReconnectAddress": "", "ResubscribeWhenMarketDataFeedAvailable": 0, "Result": 1, "ResultText": "Connected to SC DTC Protocol server. Service=sc_futures_direct.dtc.trading|SymbolSettings=sc_futures_direct.dtc.trading", "SecurityDefinitionsSupported": 1, "ServerName": "SC DTC Server. Build=45800", "SymbolExchangeDelimiter": "", "TradingIsSupported": 1, "Type": 2, "UsesMultiplePositionsPerSymbolAndTradeAccount": 0 } 4. SubmitNewSingleOrder body { "BuySell": 1, "ClientOrderID": 1, "Exchange": "CME", "IsAutomatedOrder": 1, "IsParentOrder": 0, "MaxShowQuantity": 1, "OpenOrClose": 1, "OrderType": 1, "Quantity": 1, "Symbol": "MESM23_FUT_CME", "TimeInForce": 1, "TradeAccount": "Sim1", "Type": 208 } Am I missing something ? I tried using Live trading and Simulated trading. I don't get any errors on the window log. |
[2023-05-18 13:38:39] |
Sierra_Chart Engineering - Posts: 14160 |
When you submit an order, you will definitely get this DTC message: const uint16_t ORDER_UPDATE = 301; Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-18 22:00:37] |
unfortunately, I'm not getting the ORDER UPDATE (301) after submitting an order (208). If I send OPEN ORDERS REQUEST (300) I do get a 301 like this: { "BuySell": 0, "ClientOrderID": "", "Exchange": "", "ExchangeOrderID": "", "FreeFormText": "", "GoodTillDateTime": 0, "InfoText": "", "LastFillDateTime": 0, "LastFillExecutionID": "", "LatestTransactionDateTime": 0, "MessageNumber": 1, "NoOrders": 1, "OCOLinkedOrderServerOrderID": "", "OpenOrClose": 0, "OrderReceivedDateTime": 0, "OrderStatus": 0, "OrderType": 0, "OrderUpdateReason": 1, "ParentServerOrderID": "", "PreviousClientOrderID": "", "RequestID": 2, "ServerOrderID": "", "Symbol": "", "TimeInForce": 0, "TotalNumMessages": 1, "TradeAccount": "", "Type": 301 } UPDATE/EDIT: If i remove params from the sumbit order body I do get a 301 with the error. Example: { "OpenOrClose": 1, "Symbol": "MESM23_FUT_CME", "TradeAccount": "7PV0862", "Type": 208 } I receive { "BuySell": 0, "ClientOrderID": "9770", "Exchange": "", "ExchangeOrderID": "", "FreeFormText": "", "GoodTillDateTime": 0, "InfoText": "OrderType field is not set", "LastFillDateTime": 0, "LastFillExecutionID": "", "LatestTransactionDateTime": 0, "MessageNumber": 1, "NoOrders": 0, "OCOLinkedOrderServerOrderID": "", "OpenOrClose": 0, "OrderReceivedDateTime": 0, "OrderStatus": 9, "OrderType": 0, "OrderUpdateReason": 8, "ParentServerOrderID": "", "PreviousClientOrderID": "", "RequestID": 0, "ServerOrderID": "", "Symbol": "MESM23_FUT_CME", "TimeInForce": 0, "TotalNumMessages": 1, "TradeAccount": "7PV0862", "Type": 301 } when I add the order type, it stops receiving the order update (301) Also the heartbeat shows 0 dropped messages. { "CurrentDateTime": 1684627983, "NumDroppedMessages": 0, "Type": 3 } Date Time Of Last Edit: 2023-05-21 00:15:04
[2023-05-22 13:36:52] |
There really could not be any problem on the Sierra Chart side regarding this. We do not know what is going on in your particular case. What is the method of encoding that you are using?
[2023-05-22 13:50:15] |
JSON encoding
[2023-08-09 18:16:08] |
AndrewAMD1 - Posts: 31 |
"ClientOrderID": "", Isn't ClientOrderID a required field?
