Date/Time: Mon, 29 Apr 2024 18:51:24 +0000
Text on diagonal dominant side
View Count: 1126
[2014-06-26 16:09:15] |
Dom7364 - Posts: 257 |
What is the way to set up number bars to highlight text on dominant diagonal side when dominant side is 4 or 5 times larger/bigger? I have tried several setups but I get highlights when dominant sie is clearly NOT 4 or 5 times larger, so I must be doing something wrong here. Can you help please? Many thanks |
[2014-06-26 18:25:17] |
This is documented here: http://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#DiagonalComparison and here: http://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#DominantSideColoring You will need to use a Column # Compare Threshold of 400 or 500 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-26 18:26:10
[2014-06-26 19:05:06] |
Exactly what I am doing but I can not see it to be working. Getting lots of "imbalances" which are not 4 times as much..
[2014-06-26 19:22:27] |
Set the Column 1 Compare Threshold input to 400, 500, 1000.
