Date/Time: Sat, 04 May 2024 07:34:10 +0000
scale in trades consolidates
View Count: 2017
[2014-06-26 12:04:42] |
Cristian.Ivanov - Posts: 9 |
Hi, When I scale in with multiple lots and different TP for each trade, Sierra consolidate my trades and manage the TP in a manner I do not like. How can I keep the trades separate for management and showing separate entry points, too ? |
[2014-06-26 18:58:15] |
What is TP? Sounds like you do not want to use the Scale In option: https://www.sierrachart.com/index.php?l=doc/doc_AttachedOrders.html#ScalingIn Make sure it is unchecked. In Sierra Chart there is only one single Trade Position with an average price for a symbol. There is no way to separate out individual trades on the chart. However, you can display Order Fills: https://www.sierrachart.com/index.php?l=doc/doc_ChartTrading.html#DisplayingOrderFills Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
