Date/Time: Mon, 06 May 2024 11:10:37 +0000
display issue
View Count: 342
[2023-05-12 10:30:33] |
User278398 - Posts: 291 |
hello, 1.how can i force the close price stay in the middle of the chart region(167.8 price, for this example,in region 1) 2.the purple line in region 2 changing and show different values( and the chart follow him)... i want the region will be between -10000 to 30000 as in the example no matter what will be the value of the purple line regards. |
[2023-05-12 13:49:45] |
John - SC Support - Posts: 31379 |
1. We are not sure exactly what option you are wanting, but here are some options. - To keep the last price always in the middle of the chart, set the Scale Settings to "Constant Range" with the Constant Range Scale Mode set to "Recenter to the Last Price on Every Update". - To keep the last bar always in the middle of the chart, set the Scale Settings to "Constant Range" with the Constant Range Scale Mode set to "Re-Center to the Last Bar on Every Update". 2. To do this set the Scale Settings for that region to "Constant Range" with the Constant Range Scale Mode set to "Manual Mode". Then adjust your range to be what you want and it will stay always showing that range. Refer to the following for the information on the above options: Chart Scale and Scale Adjusting: Constant Range (Scale Range) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-14 12:27:14] |
hi, pic 1 is what i get in trading (the values of the purple line is high), in pic 2, manually i change with the "interactive change scale" the values between -80000 to 80000 (approximately) and with the "interactive change move" make the value 0 in the middle ... i want to get fix layout as i get in pic 2 (i dont care if i will not see the purple line over 80000 or below -80000) regards |
[2023-05-18 20:35:30] |
Sierra_Chart Engineering - Posts: 14239 |
Use a User Defined scale: Chart Scale and Scale Adjusting: User Defined (Scale Range) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
