Date/Time: Sat, 18 May 2024 04:54:33 +0000
color coded volume bars
View Count: 979
[2014-06-25 22:11:09] |
User18128 - Posts: 4 |
I would like my volume bars to be color coded to reflect the close of the price bar. Green when close is up, red when down and black (or any other color) when open and close are equal. Currently set to same as graph, so should not it be the case? I have tried all the built in options. Thanks
[2014-07-01 04:49:32] |
In the next release there will be a custom study added named "Volume With 0 Color" which will accomplish this. You will find it in Analysis >> Studies >> Add Custom Study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-06-16 00:03:44] |
Hi, when is the "volume with 0 color" be available? or is there any other way to achieve this> it is relatively simple feature that used to be available in majority of trading softwares?Thank you
