Date/Time: Fri, 13 Nov 2026 23:06:39 +0000
André overlay
View Count: 647
| [2023-05-10 19:19:45] |
| User491428 - Posts: 87 |
Hello. If I display the 5 minute candel in the 1 minute chart, they are only displayed as bars. Is it not possible to display them as candels as well? https://www.sierrachart.com/image.php?Image=1683735253851.png |
| [2023-05-10 20:40:47] |
| John - SC Support - Posts: 48527 |
That display style is because you have set the Input for the Study/Price Overlay for "Use MultiColumn Rectangle Style for Price Bars" to "Yes". If you set this to "No" then you will get bars. Refer to the following: Study/Price Overlay Study: Use Multicolumn Rectangle Style for Price Bars If you want both, then you would need to use a second copy of the Study/Price Overlay and set that input one way for one study and the other way for the other study. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
