Date/Time: Sun, 28 Apr 2024 16:12:47 +0000
Stock data
View Count: 280
[2023-05-10 10:52:38] |
OriolCasas - Posts: 155 |
Hello, I am testing stock data from denali in my charts. Is the data high quality like it is for futures? Volume profiles and overnight positions are not displayed correctly Thank you! |
[2023-05-10 11:00:15] |
And, can I connect to any other data and still use Sierra for Stocks?
[2023-05-10 11:46:00] |
Sierra_Chart Engineering - Posts: 14121 |
I am testing stock data from denali in my charts. Is the data high quality like it is for futures? Yes.To access the new Sierra Chart US Equities Consolidated Tape data feed you must update Sierra Chart to the current version. Instructions: Software Download: Fast Update can I connect to any other data and still use Sierra for Stocks? Yes you can access this data in any installation of Sierra Chart connected to other services.Just use simple stock symbols. However, you must update Sierra Chart to the current version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-05-10 11:46:27
[2023-05-10 11:57:50] |
Thank you. What do I get for consolidated tape data feed? I am looking for some data I could connect to all stocks inculding small caps tough Thank you |
[2023-05-10 13:38:36] |
The data is delayed for some reason, what can be the cause of it? I paid for live data, but taht's not connected to my broker like the futures data is. Thank you |
[2023-05-10 14:07:34] |
You get NYSE, AMEX and NASDAQ equities. You will not though get OTC BB.
[2023-05-10 14:08:52] |
What symbol are you referring to: The data is delayed for some reason, what can be the cause of it? I paid for live data, but taht's not connected to my broker like the futures data is.
You did not activate the US Equities Consolidated Tape exchange.Thank you And you also need to update Sierra Chart to the current version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
