Date/Time: Wed, 17 Jun 2026 13:13:25 +0000
I want to run Teton
View Count: 698
| [2023-05-09 16:48:08] |
| User716459 - Posts: 200 |
I want to run Teton data and therefore ask for including denali.
| [2023-05-09 16:53:44] |
| John - SC Support - Posts: 46735 |
Teton is an order routing software that is used by certain brokers and FCMs. If you are setup to use Teton for your Order Routing, then you have to get your data from our "Denali Exchange Data Feed". What exactly are you wanting to do? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2023-05-09 17:15:43] |
I will configure Teton and denali alone, but I do not know what trading account number I have. Where does it appear?
| [2023-05-09 21:10:32] |
When you are working with a broker on setting up Teton Order Routing, then only need to know your "Account Name". Your account name can be found by selecting "Help >> About" within the Sierra Chart software. You will see an entry for "Account Name/Username" on that page. That is the information your broker will need. To setup the Teton Order Routing Service, follow the instructions at the following link: Sierra Chart Teton Futures Order Routing: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
