Date/Time: Tue, 07 May 2024 05:46:21 +0000
Triggered Limit w/ Chase Order Type
View Count: 236
[2023-05-09 15:32:49] |
TraderBiku - Posts: 14 |
Hello, I am looking to enter a triggered limit with chase order where the trigger price is in between current price and the limit order (so for example, if ES is currently trading at 4140, to place a trigger order at 4135 which will submit a limit w/ chase buy order at 4130 once the trigger price is hit) - meaning that the chase action would start only once the trigger price is hit, as price approaches the level - is this possible? And if so, which order type should I use? I've gone through the order types section in great detail, but not quite able to figure it out (perhaps because this isn't supported?) Thank you! |
[2023-05-10 14:44:58] |
Sierra_Chart Engineering - Posts: 14252 |
No, this does not sound like it is supported.
