Date/Time: Thu, 03 Jul 2025 04:30:04 +0000
AAPL Stock Split Question
View Count: 1394
[2014-06-25 02:36:26] |
User53441 - Posts: 17 |
Using Sierra histocial data and it shows the split took place on 5/30 but split actually takes place 6/9. Why is it showing up as 5/30, and the best way to adjust this is use the adjust data feature right? Will this also update indicator studies for example averge true range?
[2014-06-25 05:43:57] |
Are you referring to a Historical Daily or Intraday chart? Scroll the chart to where you see the stock split and then post an an image of the chart by following these instructions here: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image You can adjust the data with Edit >> Adjust Data. When chart data is adjusted, all of the studies will be recalculated. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-25 05:44:51
[2014-06-25 05:54:45] |
We have adjusted the Intraday data for AAPL for the recent stock split. Re-download the data with Edit >> Delete All Data and Download.
[2014-10-25 18:17:30] |
User64213 - Posts: 3 |
Related question, why is stock split not normalized to 7:1 historically. There is a big gap from the 500$ area to the $70's post split. Impossible to do historical daily pattern charting this way. I am using SC Historical Data as data source. Date Time Of Last Edit: 2014-10-25 18:19:37
[2014-10-25 20:08:31] |
To correct this select Edit >> Delete All Data and Download.
[2014-10-25 20:26:05] |
thanks! I thought the chart context menu's Delete and Download data did same as Edit-> Delete All Data and Download. Its now fixed using Edit way! Thanks! |
