Date/Time: Thu, 02 May 2024 07:02:20 +0000
EXCHANGE_LIST_REQUEST Client >> Server
View Count: 861
[2014-06-24 19:32:59] |
tickHunter - Posts: 14 |
What action causes SC to send an EXCHANGE_LIST_REQUEST to the server? Thanks |
[2014-06-24 19:42:53] |
There is nothing currently. This might be implemented with TeleTrader but that would require some code review. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-24 19:52:13] |
How does SC populate the 'Find Symbol' window? Does SC maintain a separate database of all the symbols for a given service? or is it obtained from the service in some other way? Thanks |
[2014-06-24 19:54:57] |
The symbols you see in the Find Symbol window come from Global Settings >> Symbol Settings. In the case of the DTC protocol, if you send a s_SecurityDefinitionResponse message for a symbol , then this will add the symbol and its related settings to the Global Symbol Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
