Date/Time: Thu, 02 May 2024 04:08:09 +0000
# chart numbers
View Count: 157
[2023-05-01 14:28:23] |
User478380 - Posts: 182 |
hi pls refer to the attached file thanks |
number.png / V - Attached On 2023-05-01 14:28:14 UTC - Size: 45.77 KB - 42 views |
[2023-05-01 17:34:39] |
John - SC Support - Posts: 31293 |
That is the Chart Number. You can not change the Chart Number. The only option would be to duplicate the chart to a new one and the next available chart number will be used. You can organize the order of the charts by selecting Window >> Windows and Chartbooks. Refer to the following: Window and CW Menus: Windows and Chartbooks (Window) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
