Date/Time: Fri, 03 May 2024 06:49:28 +0000
Price Change Counter indicator
View Count: 874
[2014-06-24 15:46:22] |
lotus123 - Posts: 23 |
If anyone can help, I need help with modifying the user study "Price Change Counter". Whenever I change or add an indicator to a chart that the "price change counter" is on, it resets all the previous data (that is, erases them), and starts a new bar, with no previous bars showing. Does anyone have a code to fix this, so that the indicator does not lose any prior data, but saves it all?
[2014-06-24 17:07:57] |
Something like this would be difficult to solve. It would require the study creates its own bars and the underlying chart would need to be set to 1 Number of Trades.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-24 17:08:06
[2014-06-24 17:15:22] |
as you said above - ""It would require the study creates its own bars and the underlying chart would need to be set to 1 Number of Trades. "" Is there a similar user study that you could recommend that would do the job you mention? Then I can look at it myself and try to convert it to what I want. |
[2014-06-24 17:23:55] |
No. In general, it is difficult and not efficient to do what the name of the study is saying.
