Date/Time: Mon, 06 May 2024 16:08:37 +0000
Bar Numbering
View Count: 162
[2023-05-01 09:30:29] |
58LesPaul - Posts: 429 |
How can I get the Bar Numbering study to only number the bars for US open to US close for ES futures? I tried changing to regular session and evening session but it started counting at the start of the evening session. The study description didn't help clarify for me. Thanks |
[2023-05-01 16:53:25] |
John - SC Support - Posts: 31400 |
The only option in the study related to session times is Do Not Reset at Start of New Day. It sounds like you want this to be set to No so that it does reset at the start of a new trading day (which would be the start of the Evening Session). If this is not what you want, then the only option would be to modify the code for this study. It is available in the file Studies2.cpp located in the ACS_Source folder under your main Sierra Chart installation. Also refer to the following: How to Build an Advanced Custom Study from Source Code For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
