Date/Time: Sat, 04 May 2024 22:17:48 +0000
Creating a custom Chart based on multiple range bars
View Count: 222
[2023-05-01 01:28:23] |
SKZ90 - Posts: 74 |
I want to create a Range bar Chart that has a different range setting between different areas of prices. For example, I want the range bar to be $3.30 between $150 and $200 and then the range bar to change to $5 between $201 and $250, on the same Chart. Is this possible with the current Sierra Chart studies and settings? |
[2023-05-01 16:40:43] |
John - SC Support - Posts: 31362 |
There is no support for this directly in the software. You could do this using a custom study. Refer to the following: ACSIL Interface - Custom Chart Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
