Date/Time: Tue, 30 Apr 2024 02:15:58 +0000
Moving Median
View Count: 1589
[2014-06-23 23:09:04] |
joshtrader - Posts: 439 |
If the period of the Moving Median study is set to 100, and there are only 50 bars loaded, it yields a value of 0. However, the "Moving Average - Simple" study will yield the value of the bars loaded, even if there are fewer bars than the period of the moving average. I would like to request that Moving Median be modified to behave the same way as moving average in this respect.
[2014-06-24 10:16:28] |
We should be able to get this to work by internally adjusting the Length in this case.
