Date/Time: Sun, 05 May 2024 15:51:21 +0000
pnl field not updating in replay mode
View Count: 329
[2023-04-30 12:03:35] |
User478380 - Posts: 182 |
hi please see attached images thanks |
[2023-04-30 13:29:57] |
Sierra_Chart Engineering - Posts: 14234 |
This is not clear for us. Were there any trades? And it is going to reset every 24 hours.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-04-30 13:30:06
[2023-04-30 13:31:48] |
Can I upload a video to illustrate please ?
[2023-04-30 13:33:48] |
What we recommend you do is do an accelerated chart replay with this study on the chart, and submit an order, to create position and then close that position with Flatten. The study will show at the time you close the position, the same Profit/Loss value you will see on the Trade Window DPL field.
[2023-04-30 14:43:01] |
hi pls see attached video thanks |
Private File |
[2023-04-30 16:42:18] |
You do not have the right Trade Account selected. Notice how position is not even showing when you are trading at the market. There is a rejection which you are not seeing which is logged in the Trade >> Trade Service Log. You must select a simulated trading account like Sim1. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-04-30 16:49:59
[2023-04-30 17:05:45] |
File attached
empty results.png / V - Attached On 2023-04-30 17:05:39 UTC - Size: 46.11 KB - 50 views |
[2023-04-30 17:30:41] |
That is true. The documentation, explains this for those windows: Trading Information Windows More information here: Trade Simulation: Viewing Positions and Current Profit/Loss Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-04-30 17:32:33
[2023-04-30 18:13:07] |
hi so basically in sim mode trade positions and trade account wont populate? instead i need to use the trade activity log and the following tabs to keep track of open positions and pnl: trades and chart stats ? secondly, is it possible to configure what columns i want to view in the trades and chart stats tabs within the trade activity log? lastly, a friend told me that if data/trade service settings was set to trading evaluator, then that would function like a live account but in sim mode. why then cant one use that option when running a playback to get results to display in trade positions and trade account pls ? thanks! |
[2023-04-30 18:16:08] |
i forgot to ask is it possible to clear the trade activity log or does that remain for audit trail purposes ? thanks |
[2023-05-01 15:18:30] |
Regarding post #9, this is comprehensively explained here: Trade Simulation: Viewing Positions and Current Profit/Loss secondly, is it possible to configure what columns i want to view in the trades and chart stats tabs within the trade activity log? The columns can be reordered and you can change the width:Trade Activity Log: Column Widths and Font The columns can be reordered by left clicking on the header lines and dragging them left or right. The Trading Evaluator service has no integration with a chart replay on the users installation of Sierra Chart: why then cant one use that option when running a playback to get results to display in trade positions and trade account pls ?
This would never be supported. is it possible to clear the trade activity log or does that remain for audit trail purposes ?
Trade Activity Log: Clearing Trade Activity Data
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-05-01 15:19:06
