Date/Time: Sun, 05 May 2024 19:13:23 +0000
ZIG ZAG study reset at beginning of ETH and RTH session?
View Count: 180
[2023-04-29 04:52:17] |
User280673 - Posts: 27 |
Is resetting the zig-zag study at the start of RTH and ETH sessions possible? If not would it be possible to add this feature?
[2023-05-01 15:19:33] |
John - SC Support - Posts: 31379 |
The only way to do this would be to have specific charts for those time frames. Otherwise, you could make the changes you want to the study itself. The study is available in the Studies7.cpp file in the ACS_Source folder under your main Sierra Chart installation folder. Refer to the following: How to Build an Advanced Custom Study from Source Code For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
