Date/Time: Sun, 05 May 2024 10:51:19 +0000
unhandled exception when doing a bar based backtest
View Count: 947
[2014-06-23 18:33:49] |
Bob77 - Posts: 17 |
Hello, I am trying to backtest a simple trade system using the spreadsheet system for trading study. The system enters long re. short on the close of a daily outside bar, with an attached order for both the stop loss and the take profit. However, once I begin the bar based backtest, the same error message appears numerous times in the message log: An unhandled exception was caught in c_Chart::WindowProc. Message: 32769, wParam: 34003, lParam: 0 | 2014-06-23 20:24:47 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-06-23 20:24:47 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-06-23 20:24:47 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-06-23 20:24:47 An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-06-23 20:24:47 ... Even though there are markers on the chart, where the system would have taken a trade, there are no trades recorded in the trade activity log. Could you have a look please? |
[2014-06-23 19:19:25] |
Are you using the non-CLR version of Sierra Chart? If you are not sure, then most likely you are not. Are you using any non-built-in studies? For more help with this, refer to help topic 17 here: http://www.sierrachart.com/index.php?l=doc/helpdetails17.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-23 19:19:40
[2014-06-23 19:27:49] |
Bob77 - Posts: 17 |
I am using the normal version, and have recently updated to 1149. I am running on Windows 8.1 Also I am not using any non-built-in studies. The only studies that I am using are the volume and ATR one. |
[2014-06-24 18:45:21] |
We tried duplicating the problem but could not. In order to isolate the problem, only open a single chart. And create a new spreadsheet with a different name that you use with the Spreadsheet study and then try running the back test again. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
