Date/Time: Sun, 05 May 2024 21:58:29 +0000
there is such a mistake Rithmic Tradin
View Count: 944
[2014-06-23 18:13:53] |
User85106 - Posts: 2 |
Rithmic Trading - Port for executable: 50658 | 2014-06-23 22:06:58 Rithmic Trading - Starting server: C: \ SierraChart \ Rim \ DTCBridge.exe | 2014-06-23 22:06:58 Rithmic Trading: Connecting to the server 127.0.0.1. Port 50658 | 2014-06-23 22:07:00 Socket (1732) - Connected. | 2014-06-23 22:07:00 Rithmic Trading: Connected to server. | 2014-06-23 22:07:00 Rithmic Trading: Sending logon request message. | 2014-06-23 22:07:00 Rithmic Trading | Starting the connection process to data and trading service. | 2014-06-23 22:07:00 Rithmic Trading | Logging is enabled. Log file: Rithmic.log | 2014-06-23 22:07:00 Rithmic Trading | Connecting to Rithmic 01 US server. | 2014-06-23 22:07:00 Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-06-23 22:07:03 Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-06-23 22:07:03 Rithmic Trading Server Info - Server Name: SC DTC Bridge. Server Version: 1.1. Provider Name: Rithmic DTC. | 2014-06-23 22:07:03 Rithmic Trading - Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-06-23 22:07:03 Rithmic Trading - Logon error from server | 2014-06-23 22:07:03 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-23 22:07:03 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-23 22:07:03 Socket (1732) - Shutdown and closed. | 2014-06-23 22:07:03 Rithmic Trading: Disconnected from the server. | 2014-06-23 22:07:03 |
[2014-06-23 18:31:05] |
Are you connecting to a Rithmic demo account? If so, then Rithmic blocks demo accounts from connecting. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
