Date/Time: Tue, 30 Apr 2024 15:25:39 +0000
Support for IB futures strategies - possible?
View Count: 902
[2014-06-23 15:48:43] |
User11942 - Posts: 298 |
You've recently added support for spreads for OEC. I'd like to ask if you are willing to do the same for IB (but with SC feed, this is the key point). Does SC data feed supports market depth, T&S etc for spreads? Particularly NYMEX, CBOT, NYBOT and IPE (both calendar and inter-commodity strategies). I don’t need all the symbols which are available from the exchanges, just some of them. Taking in consideration how spreads are implemented at IB, I understand that it might be not an easy task. Thanks.
Date Time Of Last Edit: 2014-06-23 15:51:15
[2014-06-23 18:37:15] |
We could support market data for spreads/strategies for NYMEX, CBOT with the Sierra Chart Exchange Data Feed. We have not yet done this. However, we cannot support trading spread/strategies with Interactive Brokers. It is way too complicated. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-23 18:52:12] |
That would be great if you could support for SC data feed. What are other trading services besides OEC you can add support to for spreads trading? CTS?
Date Time Of Last Edit: 2014-06-23 18:53:38
[2014-06-23 19:47:26] |
Spreads are supported with CTS T4 and Trading Technologies FIX.
